XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 10-11-2009, 11:12 AM   #1
sdumper
-100c club
sdumper's Avatar
Tecumseh Question
Not sure if this is a screw or scroll how can I tell?
Tecumseh AKA5512EXA
http://www.tecumsehcoolproducts.com/...AK111AT-004-J7
What are the drawbacks if any from using a scroll as apposed to a screw? I plan on using two of these in a cascade I am starting soon.
__________________
http://valid.canardpc.com/show_oc.php?id=606830
Seller/Buyer Reputation:
Heatware: http://www.heatware.com/eval.php?id=50905
Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
sdumper is offline   Reply With Quote
Old 10-11-2009, 06:43 PM   #2
ruffus
no it is a hermetic i have 1 of them and it works ok not the best but i never messed with it much. i have a tecumseh book that tells me everything even the starting hard ware
ruffus is offline   Reply With Quote
Old 10-11-2009, 07:17 PM   #3
lesstutrey
lesstutrey's Avatar
Send a message via AIM to lesstutrey
Thought hermetic = it's in a hermetic container, not indicative at all what type of compressor it is, other than the type you replace not repair (hermetic means air tight seal, therefor a hermetic compressor is just a weld sealed compressor) and they are usually reciprocating type compressors....
__________________
Cooling:
Custom SS made by RunMC of under-the-ice.com
80L Cryofab CL80 Dewar
Otternase EEAL.CU
Tried: e8400,q6600,qx9650
Subzero queue: AMD Athlon 64 3000+,3200+,3500+ winchester, 3500+ newcastle, 3500+ Orleans, 3700+, 4000+, 4200x2+ & DFI LP Ultra
Intel P4: 520, 631
w3550+Bloodrage GTI,
asus commando
Inbound: sdumper SS
lesstutrey is offline   Reply With Quote
Old 10-11-2009, 08:19 PM   #4
sdumper
-100c club
sdumper's Avatar
Hey so you have used this model compressor?
__________________
Old 10-11-2009, 08:31 PM   #5
sdumper
-100c club
sdumper's Avatar
Correct...
For example here is a spec sheet for a hermetically sealed rotary...
http://sysdoc.doors.ch/LG/QK141C.pdf
Im sure Ruffus meant reciprocating...
__________________
Old 10-11-2009, 08:41 PM   #6
ruffus
sorryya i ment reciprocating and yes i have used one before but it was something i was just messing with so could not tell u much about it as well i have a AJA5512XE as the first stage in this cascade and it works real good so give it a try i know i would
Old 10-12-2009, 01:38 AM   #7
chilly1
HVAC/R Engineer
chilly1's Avatar
AJA5512XE
Critical data.... 5512 EXA
the first letters are family and config
second five, decimal places in BTU rating
12 is the first two numbers in the btu rating
so 12,000 BTU or one ton of refrigeration
This is an 1 hp hermetic compressor the last 2 digits is oil and voltage
__________________
heatware
chilly1 is offline   Reply With Quote
Old 10-12-2009, 05:35 AM   #8
sdumper
-100c club
sdumper's Avatar
Originally Posted by chilly1 View Post
AJA5512XE
Still cant tell if its a scroll or not though but will call and check tomorrow.
__________________
Old 10-12-2009, 08:59 AM   #9
ultralo1
ultralo1's Avatar
99% sure its a recip.
__________________
Quoted from SoddemFX:
"I frankly have no idea what you are trying to do. I have received more comprehensible correspondence from Mr Obuwonga Mwahahu, who i believe wishes to give me a 10% share of his $12M fortune held in the royal bank of Nigeria."
ultralo1 is offline   Reply With Quote
Old 10-12-2009, 10:27 AM   #10
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
Agreed. I'd say it isn't large enough to get into scroll territory, or at least the scrolls I've seen.
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is offline   Reply With Quote
Old 10-12-2009, 11:32 AM   #11
sdumper
-100c club
sdumper's Avatar
Bummer thanks guys
__________________
Old 10-12-2009, 04:33 PM   #12
ruffus
y do u want a scroll i will give u one but it is 220v i have never seen a 120v one
Old 10-12-2009, 06:45 PM   #13
sdumper
-100c club
sdumper's Avatar
Thanks for the offer but 220v would be tough to sell when it goes in a cascade.
Any way I found a 13k btu for my first and a 12k btu for my second at a reasonable price so im set for the build im starting.
__________________
Old 10-13-2009, 12:51 PM   #14
ruffus
where did u get some that big and can i get some
Old 10-13-2009, 01:13 PM   #15
chilly1
HVAC/R Engineer
chilly1's Avatar
Put the larger compressor in the second stage and add a large air cooled condenser before the HX it will increase the effeciency
__________________
heatware
Old 10-13-2009, 07:11 PM   #16
sdumper
-100c club
sdumper's Avatar
Thanks Chilly im glad you posted because i was thinking the larger compressor should go as the anchor.
I normally do the following:
Largest compressor->Large fan air cooled Condenser->Filter Drier->Reciever->sight glass (optional)->TXV->HX->Smaller compressor->floated oilsep->desuper condeser->filter drier->HX->ect...
But I will try the 13k as the second and the 12k as the first.
Its awesome to have you back posting!!!
__________________
Old 10-13-2009, 07:51 PM   #17
ruffus
hey man u should really put the oil sep after the de-superheater coil so that u don't burn up the oil sep
Old 10-14-2009, 05:38 AM   #18
sdumper
-100c club
sdumper's Avatar
It can go either way without hurting the oil sep...
__________________
Old 10-21-2009, 08:53 AM   #19
sdumper
-100c club
sdumper's Avatar
Tecumseh question
http://www.tecumsehcoolproducts.com/...RK147AT-021-J7
Ok I bought this compressor and its now arrived and it looks a bit smaller than I expected.
I bought it for the first stage of a 2 stager thinking it was close to 12k BTU and around 16cc.
Well the spec sheet states its 11700 btu but then it gets weird:
Displacement 0.993
Is the displacement in Cubic Inches?
__________________
Old 10-21-2009, 09:21 AM   #20
[XC] gomeler
No need to make two threads about the same compressor, merged threads.
0.993 cubic inches is 16.27 cubic centimeters.
__________________
Old 10-21-2009, 09:22 AM   #21
sdumper
-100c club
sdumper's Avatar
nvm
I was mixing lra and rla numbers
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
