XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 10-10-2009, 04:53 AM   #1
bluewhale1
Prolimatech question
Hey for anyone who installed a prolimatech i wanted to know if you had trouble getting these spring screws
http://www.frozencpu.com/products/96...crews_x_2.html
thru the mounting plate?
http://www.frozencpu.com/products/96...Plate_x_1.html
I had a really hard time and had to push them thru with a good amount of force before placing it on the heatsink.
bluewhale1 is offline   Reply With Quote
Old 10-15-2009, 01:06 PM   #2
jim0ne
the links is not working for me.
jim0ne is offline   Reply With Quote
Old 10-17-2009, 03:52 AM   #3
bluewhale1
I re linked them right now they work
Old 10-19-2009, 08:15 AM   #4
R31Nismoid
Xtreme n00b
Mine went in fine, first go.
Few people have had issues, i think they might be getting it around the wrong way
__________________
CPU: E8400 E0 (Cooled By OCZ Vendetta 2) @ 4.3ghz/1.296vcore
Motherboard: GB EP45-DS4P BIOS F8
Memory: OCZ DDR2 PC2-8500 (1066mhz) 2x2gig - & Corsair Dominator RAM cooler
Graphic: PowerColor PCS+ HD4890
HDD: 2x WD 640GB, 1x Maxtor 180GB
R31Nismoid is offline   Reply With Quote
Old 10-19-2009, 09:31 AM   #5
clone38
clone38's Avatar
Worked a treat for me no problems at all.
clone38 is offline   Reply With Quote
Old 10-20-2009, 02:37 AM   #6
bluewhale1
Ok i ordered an extra set of each and the ones i got went thru ok. The ones that came with the Megahalem are defective. I had to almost hammer them thru. Now the original ones are stuck in the holes. With the replacement bracket and screws i got my Megahalem attached and loving it.
Old 10-20-2009, 09:42 AM   #7
Ar3s
Ar3s's Avatar
Send a message via Skype™ to Ar3s
can't you contact your local distributor for that and get it replaced ?
__________________
Everyday is a NiceDay
Ar3s is offline   Reply With Quote
Old 10-20-2009, 11:12 AM   #8
EagleRock
Xtreme Cruncher
EagleRock's Avatar
I bought Megahalem 2 days ago and when it came, it had a plastic bag on top with extra brackets. It said that some parts inside the box maybe not work well that is why they added the extra ones.
So i guess it is related to your problem some how !
__________________
Asus P5E, Q6600 G0, Thermalright 120 Extreme, 4GB OCZ Reaper, Ati 4870 X2, Corsair TX850W, Coolermaster HAF 932, X-FI XtremeGamer, WD Caviar Black 1 TB, Samsung 500GB.
The world needs your support.
Join The XS WCG team and help cure Cancer, AIDS, and other diseases.
EagleRock is online now   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
