XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 10-08-2009, 08:19 PM   #1
MadMan007
Megahalems orientation - facing back or up?
Hi, just looking for some info if anyone has seen a direct comparison. I know the Megahalems is recommended to exhaust out the back of the case, obviously a straight shot out the exhaust is better. But I'm wondering if anyone has used it exhausting upwards toward the top of the case or PSU and compared temps? I'm wondering if the recommendation is for exhausting purposes or because the heatpipes work a lot better when it's aimed toward the back of the case. In some cases (Antec P180) there's a top exhaust too and that's why I wonder..
MadMan007 is offline   Reply With Quote
Old 10-09-2009, 01:06 PM   #2
PsYcHoNo0b727
PsYcHoNo0b727's Avatar
I have seen some ppl use both orientations but IMO, I would use it blowing air to the exhaust. I would think that the heat from a GPU generated a couple inches down might effect the cooling but not enough to change anything drastically.
Also, it depends on wether or not the cooler will fit which way, I know for mine it is a very very close fit with my RAM.
__________________
Core i7 Gaming Machine
CPU: Intel Core i7 920 D0 (Batch: 3849B310) - 4Ghz @ 1.28v HT/Turbo On
Mobo: ASUS Rampage II Extreme
RAM: Corsair Dominator DDR3-1600 6GB
GPU: 2xBFG Tech GTX 295 in SLI
PSU: Corsair HX1000w Modular
HDD1: WD VelociRaptor 300gb - OS/Apps/Games
HDD2: Seagate 1.5TB Baracuda - Storage
Cooler: Prolimatech Megahalems + 2 Enermax Magma Push/Pull
Case: Cooler Master ATCS 840 Black
PsYcHoNo0b727 is offline   Reply With Quote
Old 10-09-2009, 01:16 PM   #3
MadMan007
Yes, of course out the back is better, it's recommended and common sense My main focus was on whether people know, preferably from testing, if heatpipes work better in one orientation or another. Out the back = vertical heatpipes, out the top = horizontal heatpipes and I figure that could affect their operation, I don't know if Polimatech and others recommend an orientation because of case airflow or heatpipe function. (I will email them.) It could apply to any similar design tower heatpipe cooler really.
Old 10-09-2009, 08:22 PM   #4
chew*
No rest for the weary
chew*'s Avatar
For heatpipes to work the most effeciently heatsink must be upright, etc case laying on its side.
__________________
heatware chew*
AMD is Back in Black Lifes more fun at -190C
How To Behave On An Internet Forum
http://www.thewavingcat.com/2008/02/...eed-the-troll/
http://www.livestream.com/chewsdisasterarea
Originally Posted by Sampsa View Post
1) Normal ES: Available to partners and press before the product actually launches. These are usually close to retail parts, maybe one stepping/node before retails. From my experience (I've had access to AMD & Intel ES CPUs before the official launch around 8 years) normal ES CPUs are actually usually worse than retails because manufacturing process develops all the time and retails keep getting better. Every Phenom II press sample (not even marked as ES but couple weeks earlier than retail parts) I've tested so far have been worse than normal retails.
chew* is offline   Reply With Quote
Old 10-10-2009, 08:21 AM   #5
dro
dro's Avatar
Up is only better when you have a vent place on top to similarly exhaust out the air
Hot air rises up too
__________________
dro is offline   Reply With Quote
Old 10-10-2009, 11:48 AM   #6
MadMan007
Well yeah, I *did* know that But barring that, since most cases are tower-style, I'd like to know if one orientation of heatpipes is is known to be inherently better exhaust aside.
Old 10-10-2009, 10:15 PM   #7
chew*
chew*'s Avatar
Aside from the best operating position I would say it's case dependant.
For cases with top exhaust and bottom mounted PSU's i would say fan blowing up.
All other applications fan blowing out rear exhaust.
__________________
heatware chew*
Old 10-14-2009, 07:46 AM   #8
dan7777
ive got this cooler and the haf 932 what fans would be best for the cooler ? also mounting which way would be best useing this case ? cheers
dan7777 is offline   Reply With Quote
Old 10-15-2009, 01:42 PM   #9
chew*
chew*'s Avatar
Haf I would probably face it up as long as it doesn't interfere with your ram configuration/ dimm slots.
I prefer sanyo denki fans for max OC and noise tolerance, however you will have to rubber band it on, the clips are to small.......
I use a server grade high CFM low DBA delta 1600 rpm delta for everyday use however.
__________________
heatware chew*
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
