(Revised)..Im planing on turning heads with this project..The whole phase system including the compressor will be painted white and 2 shades of blue to match my motherboard and theme..The whole system will be built to fit inside of my case...its gona be sexy thats why im taking my time so its done Clean and Correct while also staying at a budget..Got a 24lb keg of R134A for free all compressors condensers and some misc copper tubing are salvaged to keep the cost low..most of the tools I already had spent $30 on some hand tools...filter dryer $10..cap tube $10..misc copper parts $20..chilly one evap block $50..flexible suction line $30 ((Total as of now is around $150))
schrader valves with 1/4 3/8 stems
1/4 and 3/8 inch refrigeration grade copper tubing
10 foot of Capillary Tubing..Size: .081 O.D. X .031 I.D.
24 inch flexible bronze suction line with brazed copper ends
http://www.under-the-ice.com/product...products_id=55
18% silver brazing rods
supco bullet style filter dryer
I have two LG electronics rotary compressors QA090CBC...I may or may not use this compressor i have some bigger window AC,s i may chop one up if the compressor looks better..all compressor,s and condensers Are salvaged from AC,s to keep the cost of the project down
Chilly 1 evaporator block
http://www.under-the-ice.com/product...roducts_id=126 "i havent ordered this yet" tried to make my own evaporator but i just dont have the tools needed to fabricate a descent evap block from a solid piece of copper "so the one i made came out like crap" so im going to buy a pre made evaporator probably the chilly 1 for $50
24LB keg or R134A refrigerant
