XtremeSystems Forums
Reply
Old 10-07-2009, 07:37 PM   #1
Johnmark
Koolance, TMS-200 Software Thermal Interface Controller
Is anyone using this product on their setup along with Koolances sensors?
Looking for some feedback on the system and software.
It looks pretty cool and seems to be a better idea than a 5.25" bay device.
Although its pricey once you add an expansion board and all the sensors.
TIA
__________________
Mobo: Asus Rampage Gene II
CPU: i7 920 at 3700 Mhz, NO increased volts anywhere.
GPU: Sapphire 4890 Vapor-X
RAM: G.SKILL Trident DDR3 2000 (PC3 16000) 6x2GB
HD's: 2 Velioci Raptor 300 gig + several others
Blu-Ray Writer: Pioneer BDR-203BK
DVD Scanner: Liteon SHW-165H6S DVD
PSU: Corsair HX1000
Case: Obsidian 800D
GPU Cooling: Ek Water Block CF Acetal Full Cover GPU Block 1/2IN G1/4
CPU Cooling: Heatkiller v3
Water Res: Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir
Radiator: Feser 360
Pump: Swiftech MCP350 with XSPC top
Fittings: Danger Den G1/4 to 3/8IN High Flow Barb Chrome Fittings
Tubing: 3/8" I.D. Tygon
Cooling Water Conditioning: Petra's Tech Shop ,PT-Nuke and Pentosin G11
OS: Windows Vista Ultimate x64
Johnmark is offline   Reply With Quote
Old 10-07-2009, 08:11 PM   #2
FuryoftheStars
I've been considering on using this myself and am kind of interested as well.
FuryoftheStars is offline   Reply With Quote
Old 10-07-2009, 08:29 PM   #3
Waterlogged
I am Xtreme
Waterlogged's Avatar
2 best topics on it that I can recall.
http://www.xtremesystems.org/forums/...d.php?t=221648
http://www.xtremesystems.org/forums/...d.php?t=225585
Doing a search for "TMS-200" (sans quotes) will reveal more topics.
__________________
Waterlogged is offline   Reply With Quote
Old 10-08-2009, 08:00 PM   #4
Johnmark
Thanks for the links.
Looks to me like there are still some bugs to be worked out before it is ready for prime time. Although the alternatives aren't any better!
Think I might just as well spend far fewer $$ and buy the new Lampton FC-5 when it becomes available(anyone know when that might be?). That gives me speed/control as well as temp. indications.
__________________
PSU: Corsair HX1000
Case: Obsidian 800D
Radiator: Feser 360
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
