XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Dry Ice and Liquid Nitrogen
Reply
Old 10-07-2009, 07:15 PM   #1
joeyw3704
Dice Or ln2 for first time?
Hello guys i'm new here. I have been looking over the forum for a couple of days now. It's very nice. I am thinking of getting into dice and ln2 And start some heavy benching. Should I buy a pot or buy something like kingpins stuff? I am very capable of making my own. Buy I think his will perform better. would you start with dice first or ln2 ? thanks for the help.
joeyw3704 is offline   Reply With Quote
Old 10-07-2009, 07:18 PM   #2
Bobbylite
Bobbylite's Avatar
Dice first, will cost you less than $40 total for eraser, styro cooler and some dice
kingpin pot is a nice 1 time investment but the koolance pot is decent for dice
check out the stickie
__________________
Currently testing:
i920 @ 762 classified 4way 3x1gb Hypers
i670 @ e659 P55 classified 2x2gb 2400 cas7 G.skillz
2x Vapor-X 5870s 1000/1300 1.18v
Sdumper Uber Dual stage cascade -115 @ 304w Load
Bobbylite is online now   Reply With Quote
Old 10-07-2009, 09:36 PM   #3
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
I went straight to LN2 as I knew I would end up on LN2. I purchased an F1EE from K|ngp|n as he has a solid proven product and supports the community with mount revisions. I did however go from benching on cascades to LN2, but I never played with dry ice except for on GPUs.. after I was benching the CPU on LN2. I saved a lot of time/money whacking away at dry ice and I don't regret it.. LN2 is the only way to go
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is online now   Reply With Quote
Old 10-07-2009, 11:31 PM   #4
sofos1990
sofos1990's Avatar
Send a message via MSN to sofos1990
F1EE is undoubtedly one of the best pots
If you'll go straight to LN2 the cost will be high enough. Except the LN2 pot you'll need a decent liquid nitrogen dewar...
My opinion is to start with dice and a decent LN2 pot. For first 5-10 times it would be better to bench with dice, so you can get experience.
Then go to LN2
sofos1990 is online now   Reply With Quote
Old 10-08-2009, 07:36 AM   #5
joeyw3704
I think I will be going with kingpins F1 ee with the extention. I'll dice a couple of runs. then go to ln2 and report back.
Old 10-08-2009, 08:34 AM   #6
sofos1990
sofos1990's Avatar
F1EE extension is helpful for dice
Couple of runs with dice it's the best choice to get the experience you need before LN2
Old 10-08-2009, 09:01 AM   #7
joeyw3704
yea found a place that has dice pretty cheap so i won't be waisting alot of money.
Old 10-08-2009, 09:39 AM   #8
Oliver
HEY HEY
If You dont mind using dice (acetone or other liquid to get it kicking) , dice is a great "spring board" to get learning sub zero benching, whats happening when getting sub ambient on and with the hardware aswell how to prevent and handle eventually condensation.
Take your time and dont be in a rush, step by step...
If you have any questions or similar, dont hesistate to ask
GL and keep pushing it
Oliver is offline   Reply With Quote
Old 10-10-2009, 05:42 PM   #9
joeyw3704
Cpu and np pot on the way ;0
Old 10-10-2009, 06:41 PM   #10
overclocking101
overclocking101's Avatar
I make my own but at the price of the koolance pot you cant go wrong. i almost pulled the trigger on the kingpin pot but still have not though i might soon. but the koolance pot keeps popping up everywhere i look, a sighn maybe?? really on preference, though DICE will get you quite cold -56c was my lowest and that was enough for 5.3ghz on my old E8500 though later that day it did blow up and took my maximus extreme with it, just remember you may kill a cpu/board once or twice so try to have a backup especially when trying cold for the first time
__________________
EVGA P55 FTW::::Ci7-860(1.019 VID)@4000MHZ::::HD4850 ICE-Q4::::4GB CRUCIAL DDR3 1600MHZ::::TUNIW 120XTREME::::ULTRA 1KW 12V SINGLE RAIL PSU::::WIN7 X64
http://ocguru.webs.com/ <<check it out
overclocking101 is offline   Reply With Quote
Old 10-13-2009, 09:05 AM   #11
joeyw3704
pot will be in on thurs.. will insulate and run dice then
Old 10-14-2009, 05:10 AM   #12
Sam__
Sam__'s Avatar
+1 on this. ALWAYS have a backup, you dont wanna be left with 10kgs of DIce and nothing to use it with.
__________________
"Computers in the future may weigh no more than 1.5 tons."
- Popular Mechanics, 1949
"I think there is a world market for maybe five computers."
- Thomas Watson, chairman of IBM, 1943
Heat
Sam__ is offline   Reply With Quote
Old 10-14-2009, 07:47 AM   #13
joeyw3704
Yea i'm running on an old biostar board with AMD athlon 64. LOL just to get started and work on insulation
Old 10-14-2009, 05:17 PM   #14
Sam__
Sam__'s Avatar
very good idea.
__________________
Heat
Old 10-15-2009, 05:27 AM   #15
Onoff312
That happens and you just make Dice bombs
Onoff312 is offline   Reply With Quote
Old 10-15-2009, 06:10 AM   #16
Sam__
Sam__'s Avatar
aha, very true. i ended up doing that just last week.
__________________
Heat
Old 10-15-2009, 06:59 AM   #17
Oj101
Crunching 24/7
Oj101's Avatar
Bad idea for DI, you're probably going to coldbug to hell and back
__________________
Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
chilly1 Prometeia Mach 2 GT
PURE
Originally Posted by saaya to Hipro5 View Post
if there will ever be an event where they seriously keep you from smoking i bet your gonna show up with nicotine plasters all over your face
Oj101 is offline   Reply With Quote
Old 10-15-2009, 04:10 PM   #18
joeyw3704
this board and chip where free so. I really just want to check my insulation skillz. Have to wait for the 4way sli to get in for x58 action. So I can use the vanilla x-58. What do you suggest for first time.
Old 10-15-2009, 06:38 PM   #19
lesstutrey
lesstutrey's Avatar
Send a message via AIM to lesstutrey
I went in head first for my first subzero experience, with my e8400 and my p5q-d (i was only using phase change though, and it was my good 775 setup at the time.. still is). Before you even start with the DICE master your motherboard, meaning go in and max out the FSB on a low multiplier so you know what you're doing with the motherboard voltages. Taking time learning a board while you're using DICE just wastes DICE, know how to max that sucker beforehand. That's my biggest piece of advice. The motherboard plays a large part in overclocking and you can learn to master the mobo without subzero with low multipliers. Do it, and you will be thankful you did.
__________________
Cooling:
Custom SS made by RunMC of under-the-ice.com
80L Cryofab CL80 Dewar
Otternase EEAL.CU
Tried: e8400,q6600,qx9650
Subzero queue: AMD Athlon 64 3000+,3200+,3500+ winchester, 3500+ newcastle, 3500+ Orleans, 3700+, 4000+, 4200x2+ & DFI LP Ultra
Intel P4: 520, 631
w3550+Bloodrage GTI,
asus commando
Inbound: sdumper SS
lesstutrey is offline   Reply With Quote
Old 10-16-2009, 01:51 AM   #20
Oj101
Crunching 24/7
Oj101's Avatar
Don't be TOO surprise if you can't boot with DI on that setup
__________________
PURE
Old 10-16-2009, 06:30 PM   #21
lesstutrey
lesstutrey's Avatar
because of the board or type of chip?
__________________
Cooling:
Otternase EEAL.CU
Intel P4: 520, 631
asus commando
Inbound: sdumper SS
Old 10-17-2009, 04:10 PM   #22
Sam__
Sam__'s Avatar
words of wisdom.
__________________
Heat
Old 10-17-2009, 04:31 PM   #23
Buckeye
Phantom is here :)
Buckeye's Avatar
Also to get the max cold out of DICE bust that stuff up into a powder.
The first frew times that you add DICE to the acetone mix it will foam up, be careful. When the temp of the mix drops the foaming will go down a bit, just dont add a lot at one time. After it gets cold you can add larger pieces of DICE.
Keep the level of acetone up so that the DICE is actually in the acetone, use a piece of wire to mix it up if needed.
__________________
Jinu 2 Stage Cascade
http://www.youtube.com/watch?v=-zDu-Xgt400
Phantom LN2 Pot - First Encounter
http://www.youtube.com/watch?v=dLo7Dr_kR2U
How I cool my benching lab
http://www.youtube.com/watch?v=PLgwW...eature=related
Buckeye is online now   Reply With Quote
Old 10-17-2009, 11:58 PM   #24
Oj101
Crunching 24/7
Oj101's Avatar
The chip. Most Athlon64s cold bug between about -25'c and +10'c
__________________
PURE
Old 10-19-2009, 04:40 PM   #25
joeyw3704
ok. t hanks for alll the input guys. @lesstutrey I gave learned alot about this board i am running now which is an evga x58 vanilla. I have maxed this board with C/0 chip out at 4.2 on air. Haven't got all my parts for h20 yet. but with a c/o thats not to bad. i'm going to use this chip first a purchase a D/0 and try out the c/0 first when i get some experience under my belt.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
