XtremeSystems Forums
Reply
Old 10-07-2009, 04:09 PM   #1
primer
Which 120.4 rad?
Thinking of getting a 120.4 rad with Scythe GT 50cmf fans but undecided of which one to get - Feser, TC or XSPC. They all seems to be very close of each other. Have TJ07 case. Cheers
primer is offline   Reply With Quote
Old 10-07-2009, 04:09 PM   #2
shazza
Xtreme Fan
shazza's Avatar
Don't forget about the new Swiftech 420.
__________________
MM#2 : EVGA X58 | i7 920 | Vista 64-bit | Liquid Cooling | Corsair HX1000W PSU | EVGA GTX 285 Tri-SLI | 3x2GB Corsair 12800| WD 750GB | Mountain Mods UFO-CYO
shazza is online now   Reply With Quote
Old 10-07-2009, 04:18 PM   #3
zenix
Yes, and the new Magicool 420 D Radiator.
__________________
Coolermaster Stacker STC-T01
Coolermaster Real Power M850
Gigabyte GA-P35C-DS3R Socket 775 Rev2 Bios F10
Q6600 8MB cache @ 8x450 =3,6Ghz@ 1,48v
Corsair 4GB DDR2 (2X2GB) PC6400 800Mhz CL4 DHX
2x Samsung Spinpoint F1 320GB HD322HJ (SATA II 7200RPM 16MB) RAID 0 | Samsung Spinpoint F1 1TB (7200RPM, SATA II, 32MB)
Sapphire HD4870 1GB GDDR5
Water: D-Tek FuZion v1 washer quad nozzle - Swiftech MCW30 - Swiftech MCP355 XSPC Acrylic reservoir - Swiftech MCR220 - Alphacool NexXxoS Pro II - Tubing Masterkleer 1/2 UV blue
zenix is offline   Reply With Quote
Old 10-07-2009, 04:20 PM   #4
liguhy
liguhy's Avatar
Feser, TC, XSPC, Swiftech (MCR) all do well with GT-type fans, so you're good there. Size wise (big to small) it would go the order I listed, with Swiftech being the only "thin" rad. Same goes with price order. If you're in tight depth contraints, go MCR. If you want hardcore performance, go TC. Bling would be TC. XSPC is in the middle. Don't let any of these descriptions make you think one featured characteristic is worse on all the others though. If you're budget minded or won't overclock too hard, go Swiftech and save the dough. In my opinion, Feser is too overpriced for its performance/size.
If you want to get nit-picky, check out Skinee's "radiator roundup" and other radiator reviews for comparable performance.
__________________
__________________________________________________
Last edited by liguhy; Today at 1/2 second ago. Reason: You can always edit your writing more...and I'm anal-retentive.
liguhy is offline   Reply With Quote
Old 10-07-2009, 04:36 PM   #5
error404
are these one any good?
http://www.performance-pcs.com/catal...ducts_id=25446
Koolance Radiator, 4x120mm... they seem to be the cheapest
would getting 4.something out of a core i7 920 be considered light overclocking ?
error404 is offline   Reply With Quote
Old 10-07-2009, 04:42 PM   #6
SNiiPE_DoGG
I am Xtreme-ly inactive
SNiiPE_DoGG's Avatar
Send a message via AIM to SNiiPE_DoGG Send a message via MSN to SNiiPE_DoGG Send a message via Skype™ to SNiiPE_DoGG
koolance copper rads are 30 fpi and require some ridiculous fans to perform
__________________
Account no longer active, see contact info to get in touch
SNiiPE_DoGG is offline   Reply With Quote
Old 10-07-2009, 06:02 PM   #7
primer
Size wise would be OK. Would fit nicely in my TJ07. Feser seems to be cheaper than TC and XSPC here in oz.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
