XtremeSystems Forums
Reply
Old 10-07-2009, 01:18 PM   #1
Mech0z
Mech0z's Avatar
Send a message via MSN to Mech0z
Mod to make give 18W DDC 10W/18W switch?
I have heard from a friend that there is a mod to make my 18W switchable between 18W and 10W, I find my 18W too noisy sitting in my XSPC Duel res two so this mod would be appreciated.
__________________
Mech0z is offline   Reply With Quote
Old 10-07-2009, 05:38 PM   #2
MpG
MpG's Avatar
Google the DDC solder mod. All you're doing is connecting two points with a blob of solder to make it an 18W unit. But you can just as easily attach wires to the two points, and put a switch in-between to choose whether you want it connected or not. As I understand it though, the switching only works when the pump is off - you can't do it on the fly.
__________________
i7 920 | Foxconn Bloodrage | GTX280 | Corsair DDR3-1600 2x3GB
MpG is offline   Reply With Quote
Old 10-07-2009, 11:10 PM   #3
Mech0z
Mech0z's Avatar
Well I want to make my 18W do 10W as I find it too noisy and all the mods I have found was going 10W -> 18W
__________________
Old 10-07-2009, 11:35 PM   #4
Waterlogged
I am Xtreme
Waterlogged's Avatar
For 18W to 10W, just undo the blob of solder. If you wish to switch back and forth, that is when you'll need a switch.
__________________
Waterlogged is offline   Reply With Quote
Old 10-08-2009, 01:42 AM   #5
Mech0z
Mech0z's Avatar
I just have issues atm as my 18W wont start unless it gets like 10V and its annyoing having to remember to speed up your pump each time you turn on the pc after you slowed it down when it was running. So if I could put it in 10W mode and then if I want to OC or add more parts later then I can put it back to 18W if needed.
But I suppose the "blob" of solder is just there standard on the 18W then? (Havent opened mine yet)
__________________
Old 10-08-2009, 01:54 AM   #6
Nickel020
Nickel020's Avatar
Here's a nice tutorial showing how it's done.
You should know though that you cannot change the speed while it's running, you have to cut the power as well, as it will determine whether it's running as a 3.1 or 3.2 at startup and stick with it.
Nickel020 is offline   Reply With Quote
Old 10-08-2009, 02:47 AM   #7
Kibbler
Kibbler's Avatar
What about a rhoebus or fan controller?
I can drop both my 3.2s down to 60% (roughly 11W?) via software/Koolance TMS200. It's a convenient but expensive option.
Kibbler is offline   Reply With Quote
Old 10-08-2009, 03:46 AM   #8
Mech0z
Mech0z's Avatar
I have a Rhebus (For some reason they only cost 10$ atm in Denmark ), but if I put it down to a nice volume output it wont start the next time I turn on the computer as it needs high startup voltage.
__________________
Old 10-08-2009, 03:55 AM   #9
6a6an
6a6an's Avatar
http://www.youtube.com/watch?v=K42ksWKbvFA
just do it in reverse (from 18W to 10W)
__________________
p.s. sorry for my bad english and gramatical mistakes
6a6an is offline   Reply With Quote
Old 10-08-2009, 04:08 AM   #10
Mech0z
Mech0z's Avatar
Anyone that can tell if its a noticeable difference in noise 10W compared to 18W? And if the 18W should be around the same noise level as Yate Loon Medium.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
