XtremeSystems Forums
Reply
Old 10-07-2009, 02:06 AM   #1
exe163
exe163's Avatar
Universal GPU block that fits BP compression?
I am thinking about ditching full covered blocks to universal. I have be absent from WC for a while. Is there any GPU only block that fits 7/16 BP compression?
__________________
Armor.exe worklog
Mobo: Asus Rampage 2 Extreme X58
CPU: i7 920
GPU: ATi HD 4870x2
Sound: Auzentech X-Fi Forte 7.1
PSU : Corsair HX1000
RAM: OCZ 3 x 2GB tri channel DDR3-1600
HDD: WD 640 Black RAID 0 + 1
Watercooled
exe163 is offline   Reply With Quote
Old 10-07-2009, 02:16 AM   #2
zanzabar
I am Xtreme
zanzabar's Avatar
the mcw60 will fit them if u get the 45 rotary and the npsm adapters
__________________
warning i use sarcasm, alot
coming soon duel dual rad p180 the reckoning, 720BE 0912epmw, gd70 and a new liquid revamp
give a man some juice and he has juice for a day, give him a juicer and he will have juice for life if he has something to juice
zanzabar is online now   Reply With Quote
Old 10-07-2009, 03:03 AM   #3
Jamesrt2004
Xtreme Mentor
Jamesrt2004's Avatar
Send a message via MSN to Jamesrt2004
whats the "npsm" adapter, as i was looking into this too
__________________
"Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
//James
Jamesrt2004 is online now   Reply With Quote
Old 10-07-2009, 03:51 AM   #4
Edward88
This ones http://www.sidewindercomputers.com/bi14nptog14s.html
Im actually using the mcw60 with this extenders (2 per channel) with 7/16 5/8 compressions http://www.sidewindercomputers.com/big14shsiex.html
Edward88 is offline   Reply With Quote
Old 10-07-2009, 04:39 AM   #5
exe163
exe163's Avatar
[IMG]http://img191.imageshack.us/img191/279/wc6.jpg[IMG]
Very nice! Do you think it's possible to fit another card with identical configuration right under the one you have?
__________________
Armor.exe worklog
CPU: i7 920
GPU: ATi HD 4870x2
Watercooled
Old 10-07-2009, 06:03 AM   #6
Bojamijams
Bojamijams's Avatar
I would REALLY recommend AGAINST using universal GPU blocks for multi card configurations.. I'm using that now and the bend produced by the tubing (in my case 1/2 ID 3/4 OD) puts so much torgue on the bottom GPU that it actually LIFTS OFF the GPU chip (thats right, it compresses the springs away from the gpu thus lifting it).. I had to shove an 80mm fan underneath the fitting to push it back up to make good contact with the gpu...
If you're going multi card, you need full cover blocks.
__________________
Computer:i7 920 @ 4.0Ghz Turbo ON| X58 Classified @ 200 QPI | OCZ Platinum 6gb @ DDR3-1600 6-7-6-16 1T | D-Tek v2 CPU and Koolance 5850 FC Block| D5 pump w/ EK Top| HWLabs 480 GTX | Silverstone TJ07-BW|
Video: XFX 5850 @ 1000/1150 | Samsung T260 |
Audio: Asus Xonar Essence STX => Audioengine A5
Portable Audio: iPhone 3GS => JH|13 Pro
Bojamijams is offline   Reply With Quote
Old 10-07-2009, 06:17 AM   #7
millertime359
Xtreme Guru
millertime359's Avatar
I actaully run 3/4 comp fittings on mine, NPSM fitting and the 90 triple rotary BP fittings. It also allows you to get a tighter bend when going up to the CPU.
You can run SLI with GPU onlys, but I would suggest planing it out so that you are using BP fittings and D-plugs to make the connection between blocks. It is possible to build it out far enough with G1/4 adapters.
Bo is right though, I would do full cover if you are are W/Cing. I think all the BP fittings you would have to use would cause the cost of the to options to be almost equal.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 10-07-2009, 09:12 PM   #8
exe163
exe163's Avatar
I personally don't think full cover blocks are worth it. On cheaper cards, they could easily cost over a third of the card's cost and offer little advantage over air. Using them only (more) cost effective on highest end cards, which yields bad price/performance ratio to begin with. Also, it's harder to upgrade with full cover blocks.
__________________
Armor.exe worklog
CPU: i7 920
GPU: ATi HD 4870x2
Watercooled
Old 10-08-2009, 04:21 AM   #9
Edward88
Sure, with the right fittings you can do it
Old 10-08-2009, 06:18 AM   #10
millertime359
Xtreme Guru
That's where GPU only blocks come in handy. They don't cost as much as a FC. If your goal is a quiet machine, you may find it is worth the cost to put the GPU under water. I know on my 8800GTS and my GTX260 the stock coolers were not very efficient and they are loud.
__________________
Old 10-08-2009, 07:05 AM   #11
Zehnsucht
Zehnsucht's Avatar
Good input, I've never thought about this, and I use 1/2:3/4 myself.
Seeing that I want to go 5850's when they drop somewhat in price, fullcover seems the way to go then.
__________________
I Are DuneCat
I Controls The Spice
I Controls The Universe
Cooler Master ATCS 840 | Corsair HX 520W | Asus P5Q Pro | Q9550 | HD4870 | Corsair Dominator 4GB PC8500 |
D-Tek FuZion v2 - EK RES 150 - Swiftech MCR-220/320 - Swiftech MCW-60 - DDC 3.2 + Petra's Top
Zehnsucht is offline   Reply With Quote
Old 10-08-2009, 08:41 AM   #12
Edward88
If you use the corrects fittings, mounting a sli/cross configuration with gpu only blocks is easy . . .
If you only use tube that in certain cases could be difficult . . . but not impossible . . . is only a matter of creativity and cleverness, nothing else
Old 10-08-2009, 08:47 AM   #13
DarkCow
DarkCow's Avatar
You can pre-bend tubes using my method here
http://www.xtremesystems.org/forums/...6&postcount=46
Using short SLI fittings, some hose clamps and using a hard mount (not springs) there shouldn't be a problem with little to no torque. I have gotten 3 90 degree NATURAL bends with this method. The tubing wants to be in the shape, the barbs aren't forcing it.
There is no need for the expensive fittings or wasteful FC blocks, just have to get a little creative is all =D
__________________
EVGA 780i - 07 [ FSB:1.4v SPP:1.50v MCP:1.6v SPP<>MCP:1.3v ]
Q6600 G0 L747A [ 400x9:3.6ghz @ 1.38v ]
xFx GTX260 216 Black Edition [ GPU:740Mhz Shader:1515 Ram:1215Mhz ]
6 GB OCZ Reaper DDR2-800 4-4-4-15 [ 990Mhz ]
Tokara IV - Watercooled Wood case work log
DarkCow is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
