XtremeSystems Forums
Reply
Old 10-07-2009, 01:51 AM   #1
Barso
Best thermal paste for GTX295?
I am stripping my GTX295 to replace the thermal pads and paste but which paste is the best for the GPU's?
Arctic silver ceramique maybe?
Barso is offline   Reply With Quote
Old 10-07-2009, 01:54 AM   #2
WaterFlex
WaterFlex's Avatar
Arctic Cooling MX-2
__________________
Intel E8400 500x9MHz@1,37V LinX 64bit mode stable
Asus Maximus II Formula 2202 Bios
OCZ Blade Series PC2-9600 4GB 1200MHz/5-5-5-15/PL8/1,8V
Seagate RAID0 2x Barracuda 7200.12 500Gb
Asus Radeon HD5870
Iiyama ProLite E1902S-B1 Black
Thermaltake Xaser VI BWS
Seasonic M12-700 Watts
M-Audio Audiophile 192
Liquid Cooling System :
Swiftech Apogee XT, Swiftech MCW-NBMAX Northbridge
EK Water Blocks EK-FC5870 Acetal+Nickel with EK-FC5850/5870 RAM Backplate
ThermoChill PA120.3, Laing 12V DDC-1Plus, XSPC Laing DDC Reservoir Top
Arctic Cooling MX-3, 3x Scythe S-FLEX "F", 3x Scythe Gentle Typhoon "15", 2x 140mm Noiseblocker NB-BlackSilentPRO PK3, Scythe Kaze Master Ace 5,25''
WaterFlex is offline   Reply With Quote
Old 10-07-2009, 02:04 AM   #3
PiLsY
Technician
PiLsY's Avatar
OCZ Freeze is good and very cheap too. I get a couple degrees better temps with Freeze over MX-2 and AK-455 paste, plus its £2 a tube.
PiLsY is offline   Reply With Quote
Old 10-07-2009, 04:33 AM   #4
MaByBoI
Xtreme Cable Management Freak
MaByBoI's Avatar
i just use mx-2 for everything, and it works really well
__________________
Blood(Rage) shall be spilt
Intel Core i7 | Enzotech Sapphire
EVGA GTX 295 co-op | Swiftech Epsilon
Foxconn BloodRage | BloodRage Waterblock
OCZ Platinum 6gb DDR3 | GTX 480 QUAD rad
Corsair HX1000W | MCP 655
Silverstone TJ-07 | FrozenQ T-Virus Res
Intel X25-M G2 SSD 80GB | Primochill UV Red Tubing 1/2"ID-3/4"OD
WD 1TB Black | Distilled Water
I also have a Macbook Air
MaByBoI is offline   Reply With Quote
Old 10-07-2009, 06:34 AM   #5
zeropluszero
zeropluszero's Avatar
Send a message via MSN to zeropluszero
why oh why must every australian store only stock mx-3 now?
__________________
Watercooling Worklog
Q9550/Cel 347/E6500K : Rampage Formula : GTX280 : 4GB Dom 8500/2GB Gskill HZ 1000 : Enermax 1050 : HSPC Top Deck Station
Originally Posted by ryan92084 View Post
i dunno man that pussy doesn't look too thrilled
zeropluszero is offline   Reply With Quote
Old 10-07-2009, 06:50 AM   #6
millertime359
Xtreme Guru
millertime359's Avatar
MX-3 is suppose to be better if you can get it to apply right. I've heard it is a pain to get a good mount with it. MX-2 still holds its weight well. AS-5 is showing its age compared to the rest, but seeing GPUs don't really care about a degree or 2 difference, you really don't need the "best" TIM. I would just use MX-2 though.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 10-07-2009, 07:00 AM   #7
Sadasius
Tygon Warrior
Sadasius's Avatar
Same here. Even use it on my toothbrush, coffee etc...
__________________
San Ace Awesomeness!
San Ace Awesomeness Part II!
If you cannot handle the truth DO NOT click--> this link!!!
Sadasius is offline   Reply With Quote
Old 10-07-2009, 07:09 AM   #8
Hondacity
http://www.driverheaven.net/reviews....d=798&pageid=6
http://www.dragonsteelmods.com/index...14825&Itemid=1
__________________
Hondacity is online now   Reply With Quote
Old 10-07-2009, 08:06 AM   #9
eponymous
eponymous's Avatar
Yup, I use MX-2. Got one of the huge syringes of it. :P
__________________
[Project] : Altair | A Lian-Li PC-P80, dual loop, all internal build.
Hardware
Core i7 920 D0 | 12GB Corsair Dominator 1600MHz CL8 RAM | 2x EVGA GTX 285 SLI | ASUS P6T Deluxe V2 | ASUS Xonar D2X
2x Intel X-25M SSD | Corsair HX-1000W | Lian-Li PC-P80 | Dell 3008WFP 30"
Watercooling Gear (Dual Loop)
Koolance 350AT (CPU Loop) | 2x Koolance VID-NX285 (GPU Loop) | 2x Laing DDC 3.2 / XSPC Acrylic top Rev. 3 | 2x EK Multioption 150 Res Ver. 2 | 2x Thermochill PA 120.3 |
6x Scythe S-Flex 1200 RPM Fans | 7/16" Primochill Pro Green LRT | 7/16" Primochill Pro Blue LRT | B.P. Silver Shiny 1\2" Barbs | Alphacool Ball Valve / B.P. M-M Rotary fill-port / drain | Bitspower Black Freezer AIX58NS NB/SB (GPU Loop)| Black Freezer MOS AMOSII POM Version (GPU Loop)| Bitspower Black Freezer MOS AMOSIII POM Version (GPU Loop)
eponymous is offline   Reply With Quote
Old 10-07-2009, 08:25 AM   #10
MaByBoI
MaByBoI's Avatar
I hear it makes good lube too
__________________
Old 10-07-2009, 09:45 AM   #11
millertime359
Xtreme Guru
I sent it to him in a PM. Mom's (Shazza) makes me behave a little more.
__________________
Old 10-07-2009, 11:36 AM   #12
jim0ne
LMAO
jim0ne is offline   Reply With Quote
Old 10-07-2009, 02:30 PM   #13
anzial
Are you having relations with your waterblocks?
__________________
Sig is under construction
anzial is offline   Reply With Quote
Old 10-07-2009, 02:38 PM   #14
Sadasius
Tygon Warrior
Sadasius's Avatar
Nope just a strongly dedicated LC'er!
__________________
Old 10-07-2009, 05:06 PM   #15
MaByBoI
MaByBoI's Avatar
well you know, have a very good relationship with your waterblock will only increase performance! sometimes i let my waterblocks sleep in my bed with me.... the odd thing is that every morning i wake up with the bed wet.... then realised i should have emptied the block....
in short: love your waterblock, and it will love you.
__________________
Old 10-07-2009, 05:29 PM   #16
RADCOM
Xtreme Waterbaby
RADCOM's Avatar
Do you change your block every time better performer comes out though
__________________
Respec'
System:Bunch of crappy overclocked PC's that cost an arm and a leg
"A Caesarean Milks Stops Wort"-anagram
RADCOM is offline   Reply With Quote
Old 10-07-2009, 05:37 PM   #17
Sadasius
Tygon Warrior
Sadasius's Avatar
__________________
Old 10-07-2009, 05:47 PM   #18
MaByBoI
MaByBoI's Avatar
no i dont, they always say theres a prettier one just sitting around the corner. but you know what, if you love your block, they'll last a lifetime... and give great performance!
(god i sound like a weirdo)
__________________
Old 10-20-2009, 06:59 AM   #19
WaterFlex
WaterFlex's Avatar
I got Arctic Cooling MX-3! Deleted MX2 from my chip and used MX3. Wow! My temps are better, 2 degrees drop!
__________________
Asus Radeon HD5870
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
