10-05-2009, 01:18 PM
#1
Loop/Rad/Pump Config. Issue
On the weekend I installed a new Feser 360 Rad horizontally on the top of an Obsidian case.
Just for kicks I cracked open the bleed valve on the rad while the loop was pumping. Instead of water spewing out all over I got a couple of burps of water and then air actually sucked into the loop.
The Pump is a new MCP350 with an XSPC top and is about 22" lower than the rad (so is the Res.), routed res>pump>HK3 CPU>swiftechNB>EK VGA>rad>res.
It would appear this pump can't generate enough head press. to fill the Rad. after going through all the loop components.
Does anyone see a problem in running the loop res>pump>rad>CPU>N.B.>GPU>res ?
I've tested this pump configuration against a MCP655 and with the modded top the performance seemed excellent. Developed 23 kPa discharge in an open loop so I was surprised to find it does not appear to develop sufficient head to fill the rad.
My temps are good, water running about 6c above ambient using 1850rpm G.T.'s running at 900 rpm, but I don't like the fact the rad doesn't completely fill.
__________________
Mobo: Asus Rampage Gene II
CPU: i7 920 at 3700 Mhz, NO increased volts anywhere.
GPU: Sapphire 4890 Vapor-X
RAM: G.SKILL Trident DDR3 2000 (PC3 16000) 6x2GB
HD's: 2 Velioci Raptor 300 gig + several others
Blu-Ray Writer: Pioneer BDR-203BK
DVD Scanner: Liteon SHW-165H6S DVD
PSU: Corsair HX1000
Case: Obsidian 800D
GPU Cooling: Ek Water Block CF Acetal Full Cover GPU Block 1/2IN G1/4
CPU Cooling: Heatkiller v3
Water Res: Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir
Radiator: Feser 360
Pump: Swiftech MCP350 with XSPC top
Fittings: Danger Den G1/4 to 3/8IN High Flow Barb Chrome Fittings
Tubing: 3/8" I.D. Tygon
Cooling Water Conditioning: Petra's Tech Shop ,PT-Nuke and Pentosin G11
OS: Windows Vista Ultimate x64
10-05-2009, 01:27 PM
#2
To me it sounds more likely that you had a pocket of air in the radiator.
10-05-2009, 01:32 PM
#3
That's what I thought until I removed the screw completely and let it sit for a few minutes ! No water coming out, no decrease in res. level, just lots of air being sucked into the loop.
__________________
PSU: Corsair HX1000
Case: Obsidian 800D
Radiator: Feser 360
10-05-2009, 04:15 PM
#4
Did You tiltover the case aside for a while , presumably to evacuate air through outlet barb of the rad when pomp`s on. You should add some more liquid into the rig, guess.
__________________
GA X48 DS5 , CPU INTEL core2 duo 5200+ @4Ghz.( water cooled) ,VIDEO - 8800GTS320MB PSU-FORTRON 550W + 300W booster(150Wx2)
10-05-2009, 05:36 PM
#5
Just had the same issue with my new build with rad in the top, and vertical rad in the front. Was a PITA to bleed, until I turned the whole pc upside down, and used a bridged, old psu to rapidly on/off the pump, until both the rads filled, and all the air travelled up the drain Tee!
Give it a shot, it may be your best bet!! Good Luck!
__________________
10-05-2009, 09:38 PM
#6
Yes I did tilt it side to side and got some air out. The res. has extra liquid in it.
__________________
PSU: Corsair HX1000
Case: Obsidian 800D
Radiator: Feser 360
10-05-2009, 09:44 PM
#7
Did your top rad have a bleed valve built in like the Feser's do?
I could try and turn over this 50+lb beast, however if nothing comes out the bleed valve which is on the top of the rad (even lying vertical) then I'm not sure if I'll have much luck turning it upside down.
I would think the pump should have enough jam to fill the rad when the bleed valve is removed? Or am I missing something?
Man this build with the new Obsidian case has been the biggest pain in the @##@$ EVER!
__________________
PSU: Corsair HX1000
Case: Obsidian 800D
Radiator: Feser 360
10-05-2009, 09:54 PM
#8
I am Xtreme
Just an FYI, Steve (former owner of TC) had decided to get rid of the bleed valve before he sold the company, the reason?. . .it apparently didn't work well.
__________________
10-05-2009, 10:17 PM
#9
I am Xtreme
Remove 3-4oz from the res, then use that 3-4oz to fill at the bleed off outlet.
Or add a barb on the res fill port with piece of tube taller than the bleed off(do not cap) and fill the loop from the bleed off.
__________________
MSI GD-70|AMD 965C3
mushkin advanced 7-7-6-18 1600
XFX 5870
Coolermaster UCP 1100w.
Custom liquid cooled (CPU only)
Vista 64/ 7x64
10-06-2009, 07:10 AM
#10
No, no bleed valve on the rad, and no res either, just a Tee line.
__________________
10-06-2009, 10:11 AM
#11
Interesting.
When I think about it, the rad will probably never fill totally. Unless your pump discharges to the rad. The pump can take the unrestricted return flow from the rad faster than it can pump though all the blocks then onto the rad.
I'll be putting a vario 655 pump on once I get this pig of a build stable, which may help?
Problem with this build so far
Does anyone run pump>rad config.?
Thanks for your input peeps.
__________________
PSU: Corsair HX1000
Case: Obsidian 800D
Radiator: Feser 360
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
