XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 10-05-2009, 04:10 AM   #1
nigelke
nigelke's Avatar
Send a message via MSN to nigelke
Question Information about Vapor Phase Change Cooling units
hi all,
I've been looking around for an way to go sub zero. I have been looking at dice. But I am also very intrested in Phase Change units. But I would like to have a litle bit more information about this.
1) If its a single stage how low are these temps load? Around -75°C
2) Is it easy to use?
3) do you have to change the gas insinde often?
4) And last but not least How much does this cost? I now that I need to send out pm's. But I would like to have a reference
Like is a single stage 500USD? And is it hard to get in the EU
thanks all in advance ^^
nigelke
__________________
press and reviewer
http://hardpoint.net/
proud to be from Belguim ^^
nigelke is offline   Reply With Quote
Old 10-05-2009, 04:18 AM   #2
thijs
I am Xtreme
thijs's Avatar
Hi, dont know it all, but i can help you in the right direction:
1) A typical Single Stage will get you to around - 30 / - 35 load with a core i7 ( 250 watt or so )
2) It's easy to use, power it up and go!
3) You dont have to, unless its leaking or you've been fiddling with it yourself and opened a valve or so
4) realistich price is 400/500 EU , ask Littledevil or Duniek in EU
thijs is offline   Reply With Quote
Old 10-05-2009, 04:26 AM   #3
tiborrr
-100c Club
tiborrr's Avatar
Send a message via ICQ to tiborrr Send a message via MSN to tiborrr
Other option for -75°C club (-60°C loaded) is an auto-cascade which is more complicated and expensive, but it can get you into DICE temperature range for 24/7. Power draw isn't that bad either. There is a link to one in my signature.
Otherwise I would recommend LittleDevil, Duniek or Piotres!
Best Regards,
Niko
tiborrr is offline   Reply With Quote
Old 10-05-2009, 09:38 AM   #4
nigelke
nigelke's Avatar
@thijs:
thats excellent
@tiborrr:
Thanks for the heads up. I was unsure about those temps.
Sow I think I have a battle plan
Going to send out a pm to get accurate prices.
And its going to be single stage to begin with ^^
If I am used to working sub zero then I will look in to a auto-cascade
__________________
press and reviewer
Old 10-05-2009, 11:42 AM   #5
SexyMF
Needs more time
SexyMF's Avatar
2) Moderate. Insulating the motherboard can be very different depending on the make and model of the board.
If you can't afford to replace the computer hardware you stand to break, then don't go phase change. I don't know any phase-change enthusiast who has not broken decent gear in the pursuit of low temps.
4) Totally varies. There are obviously people who will build them for you. Or you can purchase company mass produced units. Personally I think anybody who gets customers from here should post the unit specs and sell price on this board.
SexyMF is offline   Reply With Quote
Old 10-05-2009, 12:31 PM   #6
nigelke
nigelke's Avatar
yeah i don't mind killing some hardware in the process
I mean thats just the risk of our hobby.
And yeah it would be easy if all of the units and specs were online but hey i am just an XS noob sow i play by the rules ^^
__________________
press and reviewer
Old 10-05-2009, 12:54 PM   #7
fatguy1992
I'v broken nothing from sub zero, and i'v used my SS on several different boards/sockets for heaps of time. Also a few times on cascade too
fatguy1992 is offline   Reply With Quote
Old 10-05-2009, 01:18 PM   #8
Rembulan
Send a message via Yahoo to Rembulan
you must be very lucky man careful too and I must very sloppy I have kill one MB and one VGA just for water chiller at +5
blame to tropical climate
Rembulan is offline   Reply With Quote
Old 10-05-2009, 10:19 PM   #9
nigelke
nigelke's Avatar
hmmm
I am going to get me one ^^ I hope in 2010 you wil see my first results sub zero
And about that motherboard killing wel I will just have to light a candle every time i bench sub zero :P
__________________
press and reviewer
Old 10-06-2009, 05:38 AM   #10
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
Nah you aren't sloppy. I have a high humidity climate and even with a few years doing this I still kill boards from time to time. I have a very long list of dead boards.. doesn't make me too happy to think about
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
