XtremeSystems Forums
Reply
Old 10-04-2009, 03:47 PM   #1
rmorse27
rmorse27's Avatar
4890 block so close to 5870
I just got done checking to see if my old heatkiller 4890 water blocks would fit my new 5870 cards. The 4 holes around gpu line up perfect but the 2 near end of blocks are just off enough where you cant get screws in.The block itself fit perfect over everything its to bad because I love Heatkiller blocks. I was thinking maybe I could drill the holes in cards just big enough to use the screws.
__________________
Antec 1200 Case
E8500
Asus Rampage Formula
8 Gigs Mushkin 1066 Ram
2 x 640 Black WD Drives Raid 0
2 x Lightscribe Dvd Burners
2 x Ati 5870 xfire
EK 5870 Water Blocks
Corsair HX 1000 Watt Pws
Heatkiller 3.0 775 Water Block
Bitspower Nb/Sb Block
2 Xspc Dual Bay Pump/Res Combo
Xfi Sound Card
Black Ice 240mm Radiator
Antec 200mm Radiator
180mm Fan
rmorse27 is offline   Reply With Quote
Old 10-04-2009, 04:14 PM   #2
millertime359
Xtreme Guru
millertime359's Avatar
The contact points over the VRMs and memory line up perfect? The only concern about drilling the holes out are drilling into the water channel and causing a leak.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 10-04-2009, 04:25 PM   #3
rmorse27
rmorse27's Avatar
no you got it wrong dude, I am talking about making the holes on the card itself a little bit bigger so screws will line up.
__________________
Antec 1200 Case
E8500
2 x Ati 5870 xfire
Xfi Sound Card
180mm Fan
Old 10-04-2009, 04:38 PM   #4
millertime359
Xtreme Guru
Can do that, but you would void the warranty for sure.
__________________
Old 10-04-2009, 05:25 PM   #5
SNiiPE_DoGG
I am Xtreme-ly inactive
SNiiPE_DoGG's Avatar
Send a message via AIM to SNiiPE_DoGG Send a message via MSN to SNiiPE_DoGG Send a message via Skype™ to SNiiPE_DoGG
dont touch that PCB with any drills, you run a very high risk of ruining it.
__________________
Account no longer active, see contact info to get in touch
SNiiPE_DoGG is offline   Reply With Quote
Old 10-04-2009, 06:08 PM   #6
dnottis
Xtreme Mentor
dnottis's Avatar
+1.
__________________
Q9550 @ 4.105 Ghz
Gigabyte P45 UD3P F9
G.Skill PC2-8800 DDR2-1100 8GB Memory
1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, D-Tek FuZion pro mounted, FuZion GFX 2
Cooler Master UCP 1100 Watt PSU
MSI HD5870 1Ghz (1.16v), 1300Mhz
Lian Li PC V-2000
Acer X222Wbd 22" LCD
3 x WD 640GB WD6400AAKS HD
Pic of my watercooled rig
dnottis is offline   Reply With Quote
Old 10-04-2009, 06:44 PM   #7
Blizzy
Send a message via MSN to Blizzy
Just use some tape around the block and PCB :P
Blizzy is offline   Reply With Quote
Old 10-04-2009, 08:06 PM   #8
rmorse27
rmorse27's Avatar
I am gonna wait for new ones at this point.
__________________
Antec 1200 Case
E8500
2 x Ati 5870 xfire
Xfi Sound Card
180mm Fan
Old 10-04-2009, 08:10 PM   #9
millertime359
Xtreme Guru
Probably best idea. I though Eddy said the EKs should be in stores within the next 2 weeks. If you can't wait, it seems the GPU only blocks with some of the sticker style heatsinks work too.
__________________
Old 10-04-2009, 09:18 PM   #10
rmorse27
rmorse27's Avatar
I am going to use my heatkiller water blocks after all for the gpu and memory coverage.If you are familiar with heatkiller for the 4890 it has a small piece thats held on by 3 screws. I am going to remove that piece and place heatsinks in its place. I bought 4 of the items below with some thermale tape.I paid to much for these water blocks just to have them lying around.Will have pictures as soon I installed them on 5870.
http://www.performance-pcs.com/catal...ducts_id=25453
__________________
Antec 1200 Case
E8500
2 x Ati 5870 xfire
Xfi Sound Card
180mm Fan
Old 10-05-2009, 01:00 AM   #11
Jamesrt2004
Xtreme Mentor
Jamesrt2004's Avatar
Send a message via MSN to Jamesrt2004
4 of them? one covers the VRMS :/ meh I think your not going to very satisfied with your results.. :/ your reason (they are expensive so dont want to buy new ones) is why people dont like FC waterblocks.. just get mcw-60 + full heatsink for the card(comes out in 2/3 weeks iirc) much cheaper as can keep the mcw for most cards and the sink is only $30 if that
__________________
"Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
//James
Jamesrt2004 is offline   Reply With Quote
Old 10-05-2009, 08:41 AM   #12
millertime359
Xtreme Guru
+1
I think gabe said that MCW60 was introduced back in 2002 and it still fits the new cards.
I wouldn't try making that old heatsink work. Just sell it and get some money out of it and get the GPU only heatsinks solution instead. You can't even be certain if the blocks will properly mount on the card and apply the proper pressure to the GPU and ram areas.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
