XtremeSystems Forums
Reply
Old 10-03-2009, 02:10 PM   #1
mobsterc
XSPC Dual Bay Reservoir or res+cover?
What to get? I like the idea that my res would fit into 5.25 bay but also i am concerned about the noise the pump will make when fixated onto reservoir.
So, another option is to get dual bay res and a custom laing cover. I had this one in mind:
OCLabs XPTop Laing DDC Plexi cover black
Price is about the same... (xspc res+xptop combo and xspc db res).
Now, I need opinions on performance (xptop vs bulit in xspc) and noise. Another advantage of xspc is space since the pump is attached directly. Thanks in advance.
edit: I already have the laing pump. Just to make sure that thread does not go in other direction. So anything else can be recommended with a price tag of around 50euros (probably ordering from aquatuning).
mobsterc is offline   Reply With Quote
Old 10-14-2009, 10:18 AM   #2
mobsterc
Anyone?
Old 10-14-2009, 10:32 AM   #3
millertime359
Xtreme Mentor
millertime359's Avatar
It depends on what you want. If you want a bay res, get the the XSPC bay res, if you want to use a regular res, get a top for your pump. The XSPC bay res performs well, and I haven't ever heard of the top you linked, so can't compare performance on it.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
