XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 10-02-2009, 10:18 PM   #1
[200]
Adding another stage to a S.S.
Hi there,
I recently took delivery of one of Kayl's 2hp S.S. system. I am very happy with it - a little bit noisy but I am now curious on how to make it run colder....
Pics of the unit here,
I am managing to get around the -46 c on load for the CPU - the unit is a dual head item so I am also able to cool a GPU.
I had been looking up some details of the compressor and found it here,
http://www.lanhaicomp.com/EN/QXR.html
It is the QXR-33E model - seems to be around the $350 mark from what I have seen...
Would I be able to add another in a parallel set up? I am still doing a bit of research on it all but I was hoping to get it to around the -100c
Any advice would be great.
[200] is offline   Reply With Quote
Old 10-03-2009, 07:08 AM   #2
sdumper
-100c club
sdumper's Avatar
I know your not a builder and have no way of knowing this so heres the scoop:
The temps you are showing are phenomenal for a two headed single stage unit and your not going to make it run colder without sacrificing load. If you want colder your going to need to consider some variety of cascade.
On a side note Kayl has some really nice cases and I would consider enclosing that some or at least enclosing the run cap so you dont shock yourself.
__________________
http://valid.canardpc.com/show_oc.php?id=606830
Seller/Buyer Reputation:
Heatware: http://www.heatware.com/eval.php?id=50905
Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
sdumper is offline   Reply With Quote
Old 10-03-2009, 07:35 AM   #3
[200]
Yep, he gave me similar advice.
Thanks, I am going to use DICE / LN2
Old 10-04-2009, 11:53 AM   #4
gosmeyer
gosmeyer's Avatar
The addiction has set in
gosmeyer is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
