I am drawing up a custom case for a mineral oil submerged computer. I wont actually be building the system for awhile because it is just a fun project for when I have extra time but I need help deciding on radiators for it so I can make sure the case fits them.
I want a low rpm setup that will be able to handle tri-sli and a high overclock on the cpu. I was thinking using two of the TFC XChanger 480s.
If it's going to have oil running through it then you wont need a computer rad. You can use a free flowing aluminum oil cooler for automotive apps like this one. > http://www.summitracing.com/parts/DE...9/?image=large
__________________
i7 920 BATCH 3838B079 4.2GHZ on 1.312v HT on
FOXCONN BLOODRAGE
6G CORSAIR Dominator TR3X6G1600C8D
2x 60GB SSD in raid 0 and 1x 120GB Titan SSD on ICH10R
1x GTX 285 w/ heavily ported AquagraFX fc block
ULTRA X3 1000w
Windows 7 64bit Build 7600 on the raid array
SWIFTECH GTZ
2x DDC3.2 EK tops
2x PA120.3
WESTINGHOUSE LVM-37w3 Donate to XtremeSystems
Use a car radiator. It should present zero restriction if the pump draws from the bottom outlet on the rad and it has plenty of surface area to help dissapate the heat from the oil. I don't think you have to worry about copper/aluminum corrosion so you can use one of the aluminum/plastic rads that are popular these days. I'm putting together a car rad setup for my rig, gonna use 3-4 200mm fans on it. I'm getting tired of my temp gauges showing a 10c delta water-to-ambient so it's time for some overkill!
__________________
Gulftown@4305Mhz 1.376v
Gigabyte EX58-UD3R F8D
3x2GB Dominator GT 1640MHz 6-7-6-18 1T
BFG 8800GTX OC 640/1000 EK full-coverage WB
Windows 7 Ultimate x64
HK 3.0-MCP655-Massive car rad!
X-FI XtremeGamer
Silverstone Strider 850w
120GB OCZ Vertex - OS
2.5TB storage
TT Armor VA8003SWA
I recommended a car rad because it will have way less restriction with oil compared to a PC rad. Also, oil doesn't transfer heat as well as water so having a larger surface area for cooling the oil would be useful. If the rad has to fit into a PC case then yeah, a car rad is out of the question regardless.
Used car rads are fine as long as you get them dipped and flushed at a rad shop, they come out looking new. I chose a used one because the local rad shop has dozens of them in the back and I can just go in there and pick one out that suits my needs. All new rads have to be special ordered which makes it difficult to choose since I can't see it first. I'll post a thread on this when I redo my loop in a week or so.
__________________
X-FI XtremeGamer
2.5TB storage
TT Armor VA8003SWA
Well that makes sense I guess. I look forward to you post =) How did you mount fans to the car rad? I guess I will think about doing an external car rad if it will be much better for oil. I didn't think there would be much of a difference. Or enough of one to make it worth the trouble except for being cool.
I can tell you another reason why you need to consider using a car radiator too: Oil is a very inefficient heat removal medium and with a highly overclocked cpu and a tri-SLI setup you will be putting a massive heat dump into the oil. I work in the offshore drilling industry and the fluids we use for cooling, lubrication and cuttings removal are both water and oil based. And I have drilled wells in the same area to about the same depth with both water based systems and oil based systems and the oil based systems consistently run 25-50 degrees hotter. And that is due to the oil not being able to shed the heat while in the surface system as efficiently as a water based system. As a consequence of this, you will need more surface area on the radiator to handle the heatload. Another few things for you to think about with using mineral or synthetic oils too are it's effect on seals and plastics in the system and also the viscosity of the oil too, which will directly affect the pump you use in the loop. Some oils have a very large viscosity change with temps and the thicker the oil gets when the system is shut down the harder it will be for the pump to catch prime when the system is started. I've seen the 100 hp centrifugal pumps we use offshore have to have 1-2 feet of extra head to prime with oils over water, even when using an oil as thin as diesel or some of the PAO's in synthetic base systems. Also, the specific gravity of oil is much less than water, which also directly affects the pump's ability to prime. A typical oil will weigh around 7 lbs/gal and water is 8.33 lb/gal.
That pudgett system used a Koolance PMP-400 on the second mineral oil pc they made with the MagiCool Radiator and seems to handle being in the oil fine. I was planning on using two of those pumps... one for each rad.
I am not familiar with using a car radiator though... any idea on a good pump for pumping the oil through a car radiator?
@spawn: I think you are talking about the wrong rad. Scroll down the page. The one you were looking at was just the proof of concept. They built a new one and used quality overclocked parts down below with a pc rad with fans
I chose a rad with nice smooth shroud mounting flanges on each side, that way my custom shroud could be a simple piece of 1/2" MDF plywood. I cut the wood to the shape of the rad and then cut 3 holes in it for the Antec 200mm fans I'll be using. The fan/shroud assembly will attach to the rad with 4 small wood screws. For fittings, visit your local hardware store plumbing section. Most car rads have 1.25" hose fittings so you'll need to piece together 2-3 adapters to go from 1.25" to 1/2". I'll have pics of all this later.
Use any pump you want, I'll be using a D5 with ACDetroit top. Have the pump draw fluid from the bottom of the rad and return it to the top. This way it acts as a giant res and presents zero restriction to your loop. Gravity will pull the fluid through the rad so your pump doesn't have to waste power pushing it through.
As stated above, if you really do build it with tri-SLI and do some serious overclocking, you're going to need a massive rad (or multiple smaller ones) to dissapate all that heat.
__________________
X-FI XtremeGamer
2.5TB storage
TT Armor VA8003SWA
They say "no restriction or oil pressure drop" but I am guessing this is relatively speaking. How do you think something like this would do? A lot cheaper than pc radiators and they already work with standard pc tubing sizes.
Plus these would allow me to have pretty good flow rates with mineral oil.
I really have no idea how those trans coolers would perform. But my gut instinct says there's not enough surface area on those tubes. Flow rate should be descent though.
__________________
X-FI XtremeGamer
2.5TB storage
TT Armor VA8003SWA
You want a single pass radiator to reduce restriction through the radiator similar to what Puget used. Their heatload was a lot smaller, so I'd say you'd need atleast 3 of those radiators for best effect. I'd say it'd be a better idea to do this passively, as that's the best thing about an entire system submerged in oil. With fans, you might as well just run a couple water cooling loops, it'll provide lower temperatures without too much hassle for similar effect.
So you want to run it passively. You need a lot of surface area. A lot. More than that single radiator. The radiators you selected would cause a lot of restriction with all those U-bends. It'd be better to have a single pass rad or connect a bunch of metal tubes with fins sticking out and not have too many bends.
If you really want to use fans or need to, I think picking the radiator with the lowest possible restriction is best. Single pass, with large enough channels.
