XtremeSystems Forums
Reply
Old 10-02-2009, 06:45 PM   #1
dylskee
dylskee's Avatar
Connecting 285 GTX SLI
Ok, started putting together my new build tonight and looks like I made yet another mistake with fittings. I have an eVGA X58 Classified motherboard and two BFG 285 GTX with EK FC water blocks. I bought THIS assuming the 30MM from thread to thread was when the fitting were screwed into the blocks but it looks like I was wrong. It looks like I need THIS. Can anyone here running a classified in SLI confirm this before I buy another useless fitting?
Here's a shot of the cards and the spacing between the fittings.
__________________
i7 920 @4200/1.268V----Classified X58 760
2X BFG GTX 285 2GB SLI /EK Full Coverage Water Blocks
APOGEE GTZ -MCR220- MCR320- XSPC Dual Bay Res/Pump Combo MCP350s
Gentle Typhoon 1850s
12GB 6x2GB Corsair Dominator 1600
2x 750GB Seagates - 1TB External HDD
850W CoolerMaster RS-850-EMBA PSU
Dell 2209WA 22" Chimei 22"
Windows 7 Ultimate 64bit
Heatware 90-0-0
dylskee is offline   Reply With Quote
Old 10-02-2009, 06:47 PM   #2
dingdong555
Send a message via MSN to dingdong555
One of these should work - http://www.sidewindercomputers.com/big14shsiex.html
__________________
Silverstone TJ07 - HULK
Silverstone TJ07 - Mortal
Seen an AWESOME rig? Report it at Million Dollar PC now!
dingdong555 is offline   Reply With Quote
Old 10-02-2009, 07:24 PM   #3
dylskee
dylskee's Avatar
Originally Posted by dingdong555 View Post
I was looking at that fitting but I figured I would be multiplying my chances of a leak if i add another piece. I'll give it a try though, thanks for the reply dingdong!
__________________
Heatware 90-0-0
Old 10-02-2009, 08:14 PM   #4
MaByBoI
Xtreme Cable Management Freak
MaByBoI's Avatar
+1
__________________
Blood(Rage) shall be spilt
Intel Core i7 | Enzotech Sapphire
EVGA GTX 295 co-op | Swiftech Epsilon
Foxconn BloodRage | BloodRage Waterblock
OCZ Platinum 6gb DDR3 | GTX 480 QUAD rad
Corsair HX1000W | MCP 655
Silverstone TJ-07 | FrozenQ T-Virus Res
WD 1TB Black | Distilled Water
I also have a Macbook Air
MaByBoI is offline   Reply With Quote
Old 10-03-2009, 07:32 AM   #5
dylskee
dylskee's Avatar
Originally Posted by MaByBoI View Post
+1
Yeah, looks like I'm going that route. Thanks for the replies, I just wish I could buy some of this stuff local so I don't have to wait another week to put this together. I was hoping to get this done last night, oh well..........
__________________
Heatware 90-0-0
Old 10-03-2009, 08:36 AM   #6
MaByBoI
MaByBoI's Avatar
yeah i know the feeling, all my stuff comes from vancouver bc, takes a few days to get it in... nothing really local.
__________________
Old 10-03-2009, 08:45 AM   #7
millertime359
Xtreme Mentor
millertime359's Avatar
Maybe someday MicroCenter will get more fittings in stock. I would order a few extra of those extenders though. Sidewinders also has the measurements of those, so if you have a set of calipers or a ruler you can check to be certain.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 10-03-2009, 10:18 AM   #8
dylskee
dylskee's Avatar
I only had one water block at the time when I bought all my fittings, the second block was on back order for 3 weeks. I was browsing through some pictures in the work logs and I some some pictures of the classified and a couple of koolance blocks in SLI and it only required the short connector so I figured it would be the same for the EK blocks.
Yeah I have a set of calipers and it measure close to an inch from block to block so that one extender should do the trick but I'm buying two any way!!
__________________
Heatware 90-0-0
Old 10-03-2009, 10:28 AM   #9
millertime359
Xtreme Mentor
Yea, I figured that. I was more referring to measuring it now so you don't have a third order for fittings.
i've learned it is best to have some extra fittings on hand for just that reason. I sucks when one little fitting is what is holding up your build and shipping it out costs more than the fitting does.
__________________
Old 10-03-2009, 01:40 PM   #10
dylskee
dylskee's Avatar
I measured it a little while ago and it measures about .980" so 1 extender should work but the shipping is nearly $5.00 so I'll get a couple of them to justify shipping charges. And you're right, if I had ordered a couple in the first place I would be finding my max overclock on my i7 rig as we speak!
__________________
Heatware 90-0-0
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
