XtremeSystems Forums
Reply
Old 10-02-2009, 02:08 PM   #1
Delemon
Question Reservior question
I'm looking at getting a res to mount internally for my first WC build, but I don't particularly care for the look of the bay mounted res. I'm looking at the Bitspower Water Tank Z-Multi 250 - POM/Acetal and as a n00b, I want to make sure I get questions out there before I buy all my stuff and then have no clue how to make it all fit.
I'd like to mount it with the single barb located at the top, and the inlet and outlet in the bottom, with one of the bottom ports used for a Bitspower G 1/4in. Temperature Sensor Stop Fitting to directly measure the res coolant (distilled H2O+ silver) temp. The top barb would be used for a fill port of some sort.
So, fillport at top with inlet, outlet, and temp sensor populating the bottom ports. Sound about right?
__________________
In Progress:
EVGA X58 Classified w/EK-FB full board block | Core i7 920 w/ Enzotech Sapphire | 6GB Gskill Trident F3-16000CL9T-6GBTD | ATI Radeon 4870 1GB | Hitachi 320GB HD x2 | Hitachi 1TB HD x2 | PCP&C Silencer 750W PSU | D5 Vario w/EK-D5 v2 | MCR320-QP w/cheap Yates (for now)
Delemon is offline   Reply With Quote
Old 10-02-2009, 11:11 PM   #2
fallwind
Xtreme Cruncher
fallwind's Avatar
Sounds good. Looking at that res, I think that's the type of configuration they had in mind when they designed it.
__________________
Gulftown@4305Mhz 1.376v
Gigabyte EX58-UD3R F8D
3x2GB Dominator GT 1640MHz 6-7-6-18 1T
BFG 8800GTX OC 640/1000 EK full-coverage WB
Windows 7 Ultimate x64
HK 3.0-MCP655-Massive car rad!
X-FI XtremeGamer
Silverstone Strider 850w
120GB OCZ Vertex - OS
2.5TB storage
TT Armor VA8003SWA
fallwind is online now   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
