XtremeSystems Forums
Reply
Old 10-02-2009, 10:53 AM   #1
lzxhenry
Rusty Radiator
Dear WC bros out there.. Need some advice from you guys.
I bought a used rad from VRZ and got to know that the rad is damn rusty from the inlet and outlet.... Should I continue to use it for my WC setup or get a new one?
Is there any ways to clean up the rad?
Appreciate your feedback and advices... Thanks
lzxhenry is offline   Reply With Quote
Old 10-02-2009, 12:48 PM   #2
jim0ne
what kind of rad did you buy? Cause copper does not rust. But it does oxidize and turn a dark brown/green
jim0ne is offline   Reply With Quote
Old 10-02-2009, 01:38 PM   #3
lzxhenry
I bought a Black Ice GT240
Old 10-02-2009, 02:01 PM   #4
jim0ne
Try cleaning it. I would believe it should be fine since it is a cooper rad. I would use 1part distilled vinegar and 3 part water. Scrub the inlet/outlet with a toothbrush or something and rinse it well with distilled water. Don't let the vinegar/water sit in the rad.
Old 10-02-2009, 02:14 PM   #5
larrabee
larrabee's Avatar
Also, ketchup is a great cleaner for copper WC equipment!
EDIT: For blocks, not rads :P
larrabee is offline   Reply With Quote
Old 10-02-2009, 02:19 PM   #6
Delemon
Indeed, ketchup does work, as it is the vinegar that does the cleaning. Not sure I'd want to clean a used rad with ketchup though!
__________________
In Progress:
EVGA X58 Classified w/EK-FB full board block | Core i7 920 w/ Enzotech Sapphire | 6GB Gskill Trident F3-16000CL9T-6GBTD | ATI Radeon 4870 1GB | Hitachi 320GB HD x2 | Hitachi 1TB HD x2 | PCP&C Silencer 750W PSU | D5 Vario w/EK-D5 v2 | MCR320-QP w/cheap Yates (for now)
Delemon is offline   Reply With Quote
Old 10-02-2009, 06:26 PM   #7
Conumdrum
Conumdrum's Avatar
Yea, clean it the best you can. Boy that is an OLD rad. Hope it was really cheap.
Use scrubbing bubbles, vinegar in short cycles in the sink, fill, skake for 5 min, drain, rinse, inspect inside. You'll never get it perfectly clean, hopefully enough to make it usable. Use a toothbrush on the fittings?
__________________
All stock for now
i7 965 ES D0 step
Corsair 1600 6 gig
GTX 280 x 2
Giga Xtreme mobo
Two 120x3 loops
DDC3.2 XSPC restops
XSPC 360RX and PA120.3 Rads
GTZ CPU and Tieton GPU blocks
Banchetto Tech Station
And the rest of the normal stuff
Conumdrum is offline   Reply With Quote
Old 10-04-2009, 10:35 PM   #8
anzial
Is it normal for a PA120.3 (old style) to develop oxidization after 6-7 months of use? I've got a pair and one shows a lot of crap (dark bluish stuff) that's inside it after I flashed it hot water and vinegar... The other one, although used longer, doesn't have that problem, at least I didn't notice it.
__________________
Sig is under construction
anzial is offline   Reply With Quote
Old 10-04-2009, 10:54 PM   #9
DeathWalking
What about some CLR?
DeathWalking is offline   Reply With Quote
Old 10-05-2009, 06:57 AM   #10
Sadasius
Tygon Warrior
Sadasius's Avatar
I was thinking the same thing. Use that rinse it out a couple times and voila...all gone!
__________________
San Ace Awesomeness!
San Ace Awesomeness Part II!
If you cannot handle the truth DO NOT click--> this link!!!
Sadasius is offline   Reply With Quote
Old 10-05-2009, 09:08 AM   #11
anzial
What's a CLR?
__________________
Old 10-05-2009, 09:25 AM   #12
rge
I am Xtreme
rge's Avatar
Originally Posted by anzial View Post
What's a CLR?
A readily available cleaner that dissolves
Calcium Lime and Rust, ie CLR, find it at home depot, lowes, walmarts, etc.
__________________
i950 4.5 Ghz prime stable - Windows 7 64 - GB X58Ex - OCZ Plat 6gb - PCP&C 910 - Intel X25m SSD - 295 GTX - 26 inch Samsung LCD
Lian Li G70 WC - 3dmark 6 29K - i950 5 Ghz water - 8.27sp1M @ 4.92ghz
rge is offline   Reply With Quote
Old 10-05-2009, 09:36 AM   #13
anzial
__________________
Old 10-05-2009, 03:01 PM   #14
jim0ne
LoL.. am i the only one on the forum that bought a kid's toothbrush to scrub the hole that the fitting goes in?
Old 10-05-2009, 03:21 PM   #15
stangracin3
i just use old ones
__________________
Originally Posted by hellcamino View Post
If you can't scrape off what grew in your block and spread it on a cracker it ain't THAT bad.
P II 720 with a GTZ
M4A79-T
crucial 1800
2x 4850 2x mcw 60
stangracin3 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
