XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 10-02-2009, 06:43 AM   #1
Roch
Send a message via MSN to Roch
Best pwm fans for Mega Shadow?
I'm about to receive a Promilatech Mega Shadow and wanted to run a push/pull setup on it. I've not got a fan controller and would ideally like to run them both via pwm from the motherboard CPU fan header. My questions are;
Would this adapter allow me to do this?
Which pwm enabled fans would anyone recommend? Are there any good 38mm pwm fans out that would perform a good price/performance ratio?
Thanks in advance.
__________________
Roch is offline   Reply With Quote
Old 10-02-2009, 07:05 AM   #2
Jamesrt2004
Xtreme Mentor
Jamesrt2004's Avatar
Send a message via MSN to Jamesrt2004
seems like it would actually!! the adapter that is, and cant really help on fans
i love those Noiseblocker 120mm NB-BlackSilentFan XL2 Fan's though... there only 25mm thick
imo i'd get them for looks
or gentle typhoons in push/pull, as the mobo header will still regulate them
__________________
"Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
//James
Jamesrt2004 is offline   Reply With Quote
Old 10-02-2009, 07:32 AM   #3
Roch
Thanks for the reply, those fans seem nice, from what I've read it seems that the fans have to be 4 wire pwm, I don't think standard 3 pin ones will regulate, the adapter just lets you do multiple fans simultaneously from a single header and not power it on the motherboard.
__________________
Old 10-02-2009, 08:03 AM   #4
demonkevy666
demonkevy666's Avatar
Send a message via MSN to demonkevy666 Send a message via Yahoo to demonkevy666
you only need 1 pwm fan on connectors like that.
the rest can be 3 pin, it looks like this can use a molex connector too.
__________________
http://www.youtube.com/user/golem720.../0/GKiZtsEVb8I
^ EVIL BUNNY
HTPC coming soon
UD3H 790GX
Sempron 140
demonkevy666 is offline   Reply With Quote
Old 10-02-2009, 08:42 AM   #6
R31Nismoid
Xtreme n00b
25mm IMO isn't worth it.
I had a 25mm push/pull on my Megahalems, not a single degree gain over a single push, but a lot more noise (2,100rpm Scythe SlipStreams)
So 38mm you might, it's one thing i wanna try myself actually. Just waiting a decent AUS stockish to get some decent 38's in
__________________
CPU: E8400 E0 (Cooled By OCZ Vendetta 2) @ 4.3ghz/1.296vcore
Motherboard: GB EP45-DS4P BIOS F8
Memory: OCZ DDR2 PC2-8500 (1066mhz) 2x2gig - & Corsair Dominator RAM cooler
Graphic: PowerColor PCS+ HD4890
HDD: 2x WD 640GB, 1x Maxtor 180GB
R31Nismoid is offline   Reply With Quote
Old 10-02-2009, 09:13 AM   #7
Roch
So I could use one pwn case fan and 2 standard three pin fans on the Mega Shadow and get them all to work from the header with pwm? Sounds perfect if so, I could strap 2 38mm panaflos on the mega and a noiseblocker on the exhaust.
Originally Posted by Andrea deluxe View Post
Coolink SWiF2-120P Retail 120mm - PWM
http://img.ampletech.it/i/hardware/a...2-frontale.jpg
Akasa Apache 120mm PWM
http://www.overclockers.co.uk/pimg/HS-056-AK_400.jpg
Noiseblocker BlackSilent Fan XLP - 120mm PWM
http://i26.tinypic.com/23t2scp.jpg
Thanks!
__________________
Old 10-02-2009, 09:40 AM   #8
clone38
clone38's Avatar
Can i ask what shop you are getting the Promilatech Mega Shadow from mate.
Im running 2 enermax magma 120mm`s on mine plugged into psu and getting 34c idle on my 920 DO @ stock.
clone38 is offline   Reply With Quote
Old 10-02-2009, 10:38 AM   #9
Nelly
Nelly's Avatar
Would also be interested to know . . .
As far as I've noticed the Mega Shadow wont be available in the UK till the end of October.
Can always order it from the USA for about £80 if your desperate, the delivery cost kills the deal not to mention import duty fees.
__________________
Biostar TPower I55, i5 750, Corsair Dominator GT 4GB 2000MHz,
Corsair HX 750 Modular PSU, Sapphire HD 4890 Vapor-X 2GB,
WD VelociRaptor 300GB, X-Fi Titanium, Corsair H50 CPU Cooler,
NEC 24WMGX3 24" TFT, Akasa Eclipse-62
Nelly is offline   Reply With Quote
Old 10-02-2009, 03:31 PM   #10
Roch
Clone and Nelly, fellow OCUKers?
I bit the bullet and paid through the nose for someone to ship it from the states, about £70ish delivered. I couldn't stand it not matching my black case...lol.
__________________
Old 10-02-2009, 05:46 PM   #11
Nelly
Nelly's Avatar
Haha yes indeed, madness!!!! its crap having to wait another 30days for it I was so tempted to do the same myself actually!!
The Megahalem with 1156 bracket is available at Scan for £50 in limited quantitys but I wanted the black one.
__________________
Old 10-05-2009, 12:22 AM   #12
clone38
clone38's Avatar
Hehe im trying not to buy from the US myself its so hard not to
Old 10-05-2009, 07:46 AM   #13
Nelly
Nelly's Avatar
Might just go watercooling, I thought you had a water cooling setup? going back to Air?
__________________
Old 10-05-2009, 10:24 AM   #14
clone38
clone38's Avatar
Back on air sold all my bits.
Old 10-06-2009, 02:11 AM   #15
gatecrasherlok
gatecrasherlok's Avatar
You guys are like me, waiting for the megashadow to arrive over our shores. Price is not great when getting it shipped over to the UK but it is tempting me.
__________________
EVGA X58 Classified
Intel Core i7 920 @ 3.8ghz
EVGA 295 GTX x2 Quad SLI (0.C)
Corsair Dominator DDR3 6GB PC3-12800C8
Western Digital 150 GB Velociraptor
Thermaltake Toughpower 1200 watt
Thermalright True (Push/Pull Config)
Lian Li Pc-P80 Armoursuit
Scythe Kaze Master Fan Control
Imon VFD Display and Control
gatecrasherlok is offline   Reply With Quote
Old 10-06-2009, 02:28 AM   #16
mav2000
mav2000's Avatar
I just got my GT's and they are extremely silent. You cant hear them at full blast. Push pull with these should be very comfortable. Only thing is that they weigh a lot.
__________________
AMD Phenom II 965 BE - 4 cores @ 4 Ghz:
Thermolab baram with 2X GT's:
MSI GD70 @ 1.5b4
OCZ Platinum AMD Edition @ 1333 6-6-5-18:
Sapphire Vapor X 4870 @ 820/1125:
OCZ Modextreme 700W PSU
mav2000 is offline   Reply With Quote
Old 10-07-2009, 03:14 PM   #17
Roch
Thumbs up
The new toys have arrived! No customs nastiness either, door to door, 5 days from the US.
Now I've just got to buy the rest of it, lol.
Hey mav, What are GT's? Have you got a link to them please?
__________________
Old 10-07-2009, 03:54 PM   #18
zalbard
zalbard's Avatar
Gentle Typhoons.
__________________
Donate to XS forums
>> Join Intel 4.5GHz LinX Stable Club <<
Originally Posted by Mechromancer View Post
Bulldozer can't show up fast enough either. Bulldozer better live up to THIS: Image
It will either make history or make AMD history if it doesn't. Intel's thread count is getting higher than Fugger's bed sheets!
Undergoing rebuild:
CPU: Core i7 920 (batch # 3910A732) | Heatsink: Prolimatech Megashadow | TIM: Indigo Xtreme | MB: EVGA Classified E760 | RAM: G.Skill Trident 3x2GB DD3-2000 | GFX: Sapphire Radeon HD 5870 1GB GDDR5 | HDD: Samsung Spinpoint F3 1TB | SB: Auzentech X-Fi Forte | PSU: Corsair HX1000 | Case: open stand till Silverstone Raven RV02 arrives | Monitor: LG Flatron W2452T | Keyboard: Razer Lycosa Mirror Edition | Mouse: Logitech MX518 (screaming for an upgrade) | OS: Windows 7 x64 Professional
zalbard is offline   Reply With Quote
Old 10-07-2009, 10:21 PM   #19
mav2000
mav2000's Avatar
Yup thats right Gentle Typhoons. Am getting a new cooler probably by next week beginning and then will put some pics up. Mine coming in from the states too.
__________________
MSI GD70 @ 1.5b4
Old 10-08-2009, 01:28 AM   #20
Roch
Thanks, they seem to get good reviews, Martin rated them really highly in his last fan roundup, which speed did you go for?
__________________
Old 10-08-2009, 03:07 AM   #21
Jamesrt2004
Xtreme Mentor
also if im honest i was running push pull 38mm thick fans and i only got like 1 degree diff lol imo not worth it :/
__________________
//James
Old 10-08-2009, 03:09 AM   #22
Jamesrt2004
Xtreme Mentor
always 1850's :P then dial em down
__________________
//James
Old 10-08-2009, 03:37 AM   #23
mav2000
mav2000's Avatar
1850's are just not available, so went for the 1450's. They push a pretty decent amount of air is what i understood from my 5 minutes of testing.
__________________
MSI GD70 @ 1.5b4
Old 10-08-2009, 07:33 PM   #24
demonkevy666
anyone try these coolink fans from frozen cpu ?
http://www.frozencpu.com/search.html...go.x=15&go.y=5
__________________
^ EVIL BUNNY
HTPC coming soon
UD3H 790GX
Sempron 140
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
