XtremeSystems Forums
Reply
Old 10-01-2009, 08:37 PM   #1
xREDMAN
final problem
when i first booted up, i was greeted with a no blue light on my gtx 295
what is the cause of this?
i have tried 4 times to make it work and now im very close to just give up and sell all my w/c stuff
The blue light blink very quick once i booted it up and then it don't blink again
__________________
Red Addiction:
EVGA P55 FTW
i5 750 @ 4ghz
4GB CORSAIR XMS3 ddr3 1600mhz
HD5850 stock
300gb VelociRaptor
1tb WD Caviar Green
Topower 900w
xREDMAN is offline   Reply With Quote
Old 10-02-2009, 01:21 AM   #2
bundymania
bundymania's Avatar
Location: near Cebit Town / Germany / Function: Reviewer
Is the SLI Link cable installed properly ? I have issues with it sometimes, when i installed several blocks on my gtx 295 for reviewing...it´s a bit tricky
__________________
Black Attack: Corsair Obsidian 800D Intel Core i7 920@4Ghz EVGA X58 SLI LE Mushkin 6GB DDR3-2000 Kit Palit GTX 295@Bitspower Waterblock Samsung 2 x 1 TB F1 SATA HDD Creative X-Fi Xtreme Music Cougar S700 PSU HP w2408h - MORA 2 Pro Laing DDC Ultra @Zern P12 Top Watercool Heatkiller 3.0 Chrome Edition Aqua Computer Aquaero VFD Alphacool Cyclone 200 Res.
Testmachine: Banchetto 101 Gigabyte GA-EX58 Extreme Intel Core i7 920 EVGA GTX 275 Patriot 6GB DDR3 1600Mhz 2TB SATA HDD
HTPC: Antec NSK 2480 GB GA-MA69GM-S2H AMD BE-2350@2.4Ghz Aeneon 2GB DDR2-800 GeForce 7600GT 2TB HDD TT Media LAB Samsung LE-40M86BD Denon AVR-1802
NB 1: Samsung 17" SE11 Aura P8400 Donato - NB2: IBM T60 // XBOX 360 Elite
bundymania is offline   Reply With Quote
Old 10-02-2009, 06:51 AM   #3
xREDMAN
i checked twice
__________________
Red Addiction:
EVGA P55 FTW
i5 750 @ 4ghz
HD5850 stock
300gb VelociRaptor
1tb WD Caviar Green
Topower 900w
Old 10-02-2009, 07:13 AM   #4
Jamesrt2004
Xtreme Mentor
Jamesrt2004's Avatar
Send a message via MSN to Jamesrt2004
sounds like its shorting on something :/
__________________
"Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
//James
Jamesrt2004 is offline   Reply With Quote
Old 10-02-2009, 08:08 AM   #5
shazza
Xtreme Fan
shazza's Avatar
Not sure what's going on. Have you searched for other threads with issues on the GTX 295 water blocks causing problems? I recall seeing issues with various water blocks / GPUs where shorting (as James said) can occur. Possibly something as simple as over tightening.
If you have another video card, try that in your system to make sure everything else is working. While it's a pain, one thing to do is replace your stock heat sink on the card and see if it works then. That at least narrows it down to the water block.
Anything else you can tells us? Is it possible you ran the computer without the pump circulating? This can overheat the GPU (I know - I did this once ).
I know it's frustrating, but hope you solve your problem and get everything going to your satisfaction.
__________________
MM#2 : EVGA X58 | i7 920 | Vista 64-bit | Liquid Cooling | Corsair HX1000W PSU | EVGA GTX 285 Tri-SLI | 3x2GB Corsair 12800| WD 750GB | Mountain Mods UFO-CYO
i7 920 on Air : P6T Deluxe | i7 920 | Noctua NH-U12P SE1366 HSF | Vista 64-bit | Corsair HX1000W PSU | GTX 260 (55nm) x 2 | 3x2GB G-Skill PC3 12800| WD 750GB | Maxtor 500GB | Lian Li PC-A20
shazza is online now   Reply With Quote
Old 10-02-2009, 09:13 AM   #6
Wolf132
Wolf132's Avatar
Other than checking the obvious things with the waterblock on, the only way to tell if you bricked it would be to install the original heatsink back on and see if it works that way.
__________________
Asus P5Q-Delux, Q6600 @ 3.7
2x 120.2PA Thermochill
MM H2GO
EVGA GTX 260
OCZ vertex 60g w/Win 7 Pro
Corsair 850HX
NEC 20wmgx2
Wolf132 is offline   Reply With Quote
Old 10-02-2009, 11:58 AM   #7
atomic ferret
atomic ferret's Avatar
I assume you tested it without a waterblock installed on it. If it worked before and not now, you may have damaged it during installation.
__________________
heat
P4 2.4C@3.2-P4P800-E Deluxe-1gb Corsair RAM-Radeon 9800pro-Hiper 580W-LianLi PC65-MCP-655-'77 Bonneville Heater Core w/ 2 Panaflo 114cfm-Apogee GT
atomic ferret is offline   Reply With Quote
Old 10-02-2009, 02:50 PM   #8
xREDMAN
@atomic i tested it WITH the block installed
everything is running great pumps working no leak at all
only my graphics card is not doing so great
is it true that my card is not really "dead" because the green light shows up?
i checked my power connection
__________________
Red Addiction:
EVGA P55 FTW
i5 750 @ 4ghz
HD5850 stock
300gb VelociRaptor
1tb WD Caviar Green
Topower 900w
Old 10-02-2009, 04:17 PM   #9
xREDMAN
i got a blue light for 2 seconds and then its gone
i think the gtx 295 is playing me
__________________
Red Addiction:
EVGA P55 FTW
i5 750 @ 4ghz
HD5850 stock
300gb VelociRaptor
1tb WD Caviar Green
Topower 900w
Old 10-02-2009, 04:48 PM   #10
NaeKuh
Post Soapbox Destruction
NaeKuh's Avatar
Originally Posted by xREDMAN View Post
i checked twice
You know its not flipable...
meaning even tho it fits both ways, it can only go 1 way.
__________________
Nadeshiko: *Undergoing Rebuild*
Haruhi: i7 975 12GB DDR3 eVGA Classified *Haruhi -> Nadeshiko*
Lind: Dual Gainestown 3.07
NaeKuh is offline   Reply With Quote
Old 10-02-2009, 05:01 PM   #11
xREDMAN
im pretty sure its the right way
__________________
Red Addiction:
EVGA P55 FTW
i5 750 @ 4ghz
HD5850 stock
300gb VelociRaptor
1tb WD Caviar Green
Topower 900w
Old 10-02-2009, 06:12 PM   #12
Sadasius
Tygon Warrior
Sadasius's Avatar
HAHA had that happen to me before as well on another card and found the block shorting against something on the card (tightened too far down). I changed out my thermal tape for thicker stuff and it went away. Just keep playing with it and hope you don't go blind! It can be frustrating but you will get it. Every damn build there is something like this happening. You get right to the end, take a deep breath, flick the switch and hope for the best! It's usually something small too.
__________________
San Ace Awesomeness!
San Ace Awesomeness Part II!
If you cannot handle the truth DO NOT click--> this link!!!
Sadasius is offline   Reply With Quote
Old 10-03-2009, 06:54 PM   #13
xREDMAN
its alright people im done with water cooling its not for me i tried everything wouldn't work
__________________
Red Addiction:
EVGA P55 FTW
i5 750 @ 4ghz
HD5850 stock
300gb VelociRaptor
1tb WD Caviar Green
Topower 900w
Old 10-03-2009, 08:22 PM   #14
Sir_Justin
Don't give up!
__________________
"Red Dawn" || EVGA X58 || i7 920 @ 4.05Ghz w/ HK 3.0 || 6GB OcZ || EVGA GTX260 || Tecnofront HWD || 850TX || XSPC 360 Rad || MCP655 w/ BP Top and Housing || More mod's on the way!
Sir_Justin is offline   Reply With Quote
Old 10-03-2009, 09:15 PM   #15
xREDMAN
i wasted so much water and thermal paste its ridiculous im tired of trying so damn hard
my dad said to give up and buy me another graphics card
i really don't want another card because this card is good
__________________
Red Addiction:
EVGA P55 FTW
i5 750 @ 4ghz
HD5850 stock
300gb VelociRaptor
1tb WD Caviar Green
Topower 900w
Old 10-03-2009, 10:16 PM   #16
Utnorris
Utnorris's Avatar
I wouldn't give up. Just like everything in life, if it's easy everyone will do it. Water cooling is not hard, but it isn't always plug and play. Try remounting the water block on the card, you may have simply tightened it too tight, it just needs to be hand tight. Also, make sure your thermal pads are making contact where they are supposed to, you should see them flatten at the contact points.
__________________
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Mountain Mod UF2O
I7 920 (3849B018)/Blood Rage/ XFX HD5870/ 6Gb (3x2Gb) OCZ 1866 Ram @ 1600 6-6-6-16-1t timings / Inte M-25 80Gb SSD x 2 RAID 0
W/C System
(CPU) Phase (GPU) EK Water Block and Water Chiller / B*P/Koolance Compression Fittings.
Utnorris is offline   Reply With Quote
Old 10-03-2009, 10:57 PM   #17
Baulten
Yeah, don't give up. Obviously the block is not making proper contact. It's shorting something, or not cooling something. Check EVERYTHING. Make sure it's not hitting anything. Check for any "burnt" areas which could be caused by shorting. Check to make sure the thermal tape lines up.
Giving up is not the right choice.
__________________
Builds: Old / New
CPU: Phenom II 940 / Phenom II 965
CPU cooler: Xigmatek s1283 / Watercooled
Motherboard: DFI LanParty 790FX-M2RS / MSI 790FX-GD70
RAM: 2x2GB G.Skill DDR2 800 / 2x2GB G.Skill DDR3 1600
Video card: GTX 260 / HD 5870
Hard drive: 2x250 GB Seagates, 1x250 GB Western Digital (SATA), 1 TB WD External
Case: Modded Cooler Master RC-690 Mid Tower / Corsair Obsidian 800D
Baulten is online now   Reply With Quote
Old 10-03-2009, 11:20 PM   #18
Fafeifa
Fafeifa's Avatar
just send the blocks and the card to me if u decide to give up, i'll cover the shipping expenses
__________________
Fafeifa is offline   Reply With Quote
Old 10-04-2009, 12:27 AM   #19
Sadasius
Tygon Warrior
Sadasius's Avatar
Perhaps if you have pics on how you have it setup so we can analyze it and help you out there. Don't give up. Stand up to the challenge!
__________________
Old 10-04-2009, 06:33 AM   #20
denali
Nothing worth doing is easy. If it were, everyone would do it.
__________________
New system in the process of being designed.
Old system ain't worth talking about.
denali is offline   Reply With Quote
Old 10-04-2009, 09:29 AM   #21
shazza
Xtreme Fan
shazza's Avatar
I know how frustrating it is when stuff doesn't work, so only you can make the decision if quitting (or maybe postponing?) water cooling is the right thing for you.
I am still confused as to whether you have removed the water block and replaced the stock heatsink on the card? If so, what happene?
This is worth the effort because if it still doesn't work, you can possibly RMA the card and get a replacement. I'm not suggesting you scam the vendor - I had a similar issue with a Sapphire Radeon 4870X2. I told them I water cooled it - was told just to replace the stock heatsink and they would RMA it. I've since received a replacement that I can torture all over again
__________________
Old 10-04-2009, 09:56 AM   #22
Equinediver
Equinediver's Avatar
As others have said, please don't give up, you will get such an amazing feeling of accomplishment when you get it all working!
However, what thermal paste did you use and how much? Using too much is worse than not using enough, also some pastes, like AS5 should not be used as they contain metal and can be conductive.
If your card still doesn't work with the stock heatsinks you should be able to RMA it, then when you get your replacement card, check it works before you put the WC block on it
__________________
i7 975 EVGA X58 Classified 6Gb Corsair Dominator GT 2 x EVGA 285 FTW 2x 300Gb Velociraptor in RAID 0 WD Black 500Gb
WC loop 1: HK 3.0 Fesser 360 BP VREG BP NB D5 pump
loop 2: 2 x EVGA HC's Fesser 240 D5 pump
Equinediver is online now   Reply With Quote
Old 10-04-2009, 10:11 AM   #23
xREDMAN
i used AS5 i guess i have to get mx-2 then
i already took off the sticker though how will i be able to rma it
can i use koolance thermal pads on my block? if i can i might have a better chance of it working
__________________
Red Addiction:
EVGA P55 FTW
i5 750 @ 4ghz
HD5850 stock
300gb VelociRaptor
1tb WD Caviar Green
Topower 900w
Old 10-04-2009, 10:15 AM   #24
AndrewZorn
Xτræmε ÇruñcheΓ
AndrewZorn's Avatar
the good news is that theres no reason to go back to air now, if its dead, youve already ruined it
more details on your setup
and yes
the most paste you should have on any one component should be the size of a piece of rice
__________________
ABANDON THE MODERN WARFARE 2 BOYCOTT.
Infinity Ward has promised revolutionary Mouse Control™ and Graphical Settings™ in the PC version of COD:MW2. Nothing more to complain about.
AndrewZorn is offline   Reply With Quote
Old 10-04-2009, 11:08 AM   #25
xREDMAN
http://www.flickr.com/photos/43247703@N06/3981025230/
http://www.flickr.com/photos/43247703@N06/3980263255/
some pics
__________________
Red Addiction:
EVGA P55 FTW
i5 750 @ 4ghz
HD5850 stock
300gb VelociRaptor
1tb WD Caviar Green
Topower 900w
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
