XtremeSystems Forums
Reply
Old 10-01-2009, 02:18 PM   #1
CodeNinja
CodeNinja's Avatar
Loop Advice, WC Noob.
Originally my system was going to be water cooled when I bought it, but I backed away due to funding and spent more on the hardware instead. Now, 6 months or so later, I'm suffering from random fan failures and my Scythe controller is half dead (channel 1 is iffy, 3 is fried completely).
Ok, well, guess it's time to spend the money and go liquid! Wasn't particularly happy with my temps on air anyhow...
What I have in mind is two loops:
DDC3.2 >> NB >> CPU >> MCR320 >> RES
DDC3.2 >> GPU >> MCR220 >> RES
The CPU would hit 4.0Ghz on air, maybe more, and still be stable but with temps I wasn't comfy with. I'd like to run 4.0Ghz+ 24/7 on a system with fans no louder than the Scythe Slip-Stream's currently installed, I'm looking at either Gentle Typhoons or the S-Flex. 25mm thickness is a must, 38mm won't fit (at least not on the MCR320).
Should I skip cooling the NB? Move it to the GPU loop? Someday I may run SLI, but it'll probably be after a video card upgrade since it seems XFX no longer makes the GTX285 XXX Black anymore.
__________________
Asus P6T | TRUE Extreme Edition | i7 920 @ 3.8Ghz (19x200) | 6GB Corsair DDR3 1600Mhz |
XFX GTX285 Black Edition | 4x WD Caviar Black 640GB RAID10 Array | CoolerMaster Centurion 590 |
Corsair 620HX Modular PSU | Lots and Lots of Fans!
CodeNinja is offline   Reply With Quote
Old 10-01-2009, 02:28 PM   #2
millertime359
Xtreme Mentor
millertime359's Avatar
The NB is not really needed. A quiet fan pointed directly at it will be plenty. A single loop with a MCR320 and some GT 1850s will get the job down for you too.
It also might not be a bad idea to check out a D5 and a typhoon III also.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 10-01-2009, 02:46 PM   #3
rambler358
rambler358's Avatar
If you really want to do 2 loops seperate out the CPU into its own loop, especially if you plan on doing any overclocking on your i7 920 chip. The i7's get quite warm when OC'd, and its own loop will definately help with temps.
__________________
Pandora's Box:
Case - Lian Li PC-343B
Mobo - EVGA X58 Classified (759)
CPU - i7 920 (D0 stepping), watercooled w/Enzotech Luna Rev.A block
RAM - Corsair Dominator GT 2000 (8-8-8-24) w/fan
GPU - EVGA GTX295 quad-SLI, water cooled w/Koolance NX295 blocks
PSU - Corsair HX1000
O/S - Windows 7 RC build 7127
rambler358 is offline   Reply With Quote
Old 10-01-2009, 03:07 PM   #4
CodeNinja
CodeNinja's Avatar
Good advice. I've been iffy on the NB block anyway, since the heatsink doesn't even really get that warm.
I'm pretty set on the DDC3.2s since I already have them, picked them up a while back and never used them. Figure I might as well now
__________________
Old 10-01-2009, 03:14 PM   #5
rambler358
rambler358's Avatar
If you still plan on dual loops, here's the perfect res/top for you:
http://www.frozencpu.com/products/95...?tl=c97s168b49
__________________
Pandora's Box:
Old 10-01-2009, 03:14 PM   #6
Caoder
Caoder's Avatar
Send a message via MSN to Caoder
+1 T3 is nice to have if you're going for 2 loops. The mosfets need more cooling than the NB so investing in a full coverage block wouldn't be a bad idea.
__________________
Core i7 920 D0 @ 4.2 | 2 x GTX 260 | EVGA x58 SLI | 3 x 2 gb GSKILL Perfect Storm 17066CL9|
CPU under WC/ gtz + 2x mcr220
Caoder is offline   Reply With Quote
Old 10-01-2009, 03:16 PM   #7
CodeNinja
CodeNinja's Avatar
I saw that too. It won't work, though. Space limitations.
Unless, maybe, I use a thin DVDRW... hm.
As far as I know, there aren't any for the vanilla P6T. At one point the EK site said they had some, but apparently they didn't -quite- fit and have since been removed.
__________________
Old 10-01-2009, 03:30 PM   #8
millertime359
Xtreme Mentor
You can always use an external drive.
__________________
Old 10-18-2009, 12:34 PM   #9
CodeNinja
CodeNinja's Avatar
Ok, still working on finalizing things, but getting closer to pulling the trigger. Unfortunately I've determined that my HX620 just isn't going to have the juice, so I'm trying to decide between the new 850 or the monster HX1000.
Did order the second video card though, was going to hold off on it, but the XFX GTX285 Black is getting hard to find. Brings up a question, though. Will the MCR220 be enough for 2 video cards? I've heard that you need 1x120 per video card, so if that's true, then I should be fine. Just looking for clarification.
__________________
Old 10-18-2009, 02:35 PM   #10
Xion X2
Xion X2's Avatar
Cooling the NB isn't a bad idea, but you need to switch up the order of your loop to have the CPU first, hitting the cool water.
__________________
Project Link
Xion X2 is offline   Reply With Quote
Old 10-18-2009, 02:52 PM   #11
shazza
Xtreme Fan
shazza's Avatar
CodeNinja - before you invest in water cooling, it would be a good idea to mention what your expectations are for temperatures, and the changes you expect by moving from air to water. Some folks are surprised when they don't get huge drops in Temperature with the i7 platforms (not trying to dissuade you from water cooling, just double checking expectations).
__________________
MM#2 : EVGA X58 | i7 920 | Vista 64-bit | Liquid Cooling | Corsair HX1000W PSU | EVGA GTX 285 Tri-SLI | 3x2GB Corsair 12800| WD 750GB | Mountain Mods UFO-CYO
i7 920 on Air : P6T Deluxe | i7 920 | Noctua NH-U12P SE1366 HSF | Vista 64-bit | Corsair HX1000W PSU | GTX 260 (55nm) x 2 | 3x2GB G-Skill PC3 12800| WD 750GB | Maxtor 500GB | Lian Li PC-A20
shazza is offline   Reply With Quote
Old 10-18-2009, 03:02 PM   #12
CodeNinja
CodeNinja's Avatar
Well right now I'm in the mid-40s on all cores when idle, and pushing 70 under load. GPU is 65 at idle and I've seen it near 80c under load.
I'd like to bring the load temps down some, not so much on CPU I suppose. I was running 3.8Ghz but now I'm stock-clock to keep the temps down (had a few fan failures). Maybe mid-30s idle, 50-60 load? GPU is where I'm needing improvement the most, like to keep her below 70c load.
Oh yeah, and quiet. Quiet is good.
__________________
Old 10-18-2009, 03:33 PM   #13
Jamesrt2004
Xtreme Mentor
Jamesrt2004's Avatar
Send a message via MSN to Jamesrt2004
gpu will go WAYY lower on the 240 rad,
cpu will get a good 10*C off of it i would say
also imo i'd go res - pump - rad - cpu - nb - res
that XSPC rad is perfect for you and what i will now be picking up after looking at reviews of T3... i feel its not as good as its made out and there are some flaws in the graphs people posted here but that could be me..
__________________
"Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
//James
Jamesrt2004 is offline   Reply With Quote
Old 10-28-2009, 06:38 AM   #14
CodeNinja
CodeNinja's Avatar
Kicking around the idea of dropping the dual loop idea and going with one loop for everything.
920 i7 @ 4Ghz
GTX285
GTX285 (Yeah, second one showed up finally)
Thinking an MCR220 and an MCR320 on one loop with either a single DDC 18w (not sure what color top, but it's a year old or so), or 2 of them in series using the XSPC dual top. Both radiators will likely have Gentle Typhoon 1450s on them, might go with the 1800s but they are still somewhat hard to find.
Still haven't ordered parts though, been working late at work trying to get ready for our ITSEC demo next month. And, of course, this is when management decides to make sweeping architecture changes and start changing the hardware up on us.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
