XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Dry Ice and Liquid Nitrogen
Reply
Old 10-01-2009, 01:21 PM   #1
Sil3ntSnip3a
Sil3ntSnip3a's Avatar
Send a message via Skype™ to Sil3ntSnip3a
1st Time DICE Pot
Today I am going to jump into the world of Dry Ice cooling. I told my dad to pick me up a 1/4" Copper Base, and a 10-14" height 1/4" thick 3 1/2" wide copper tube for the pot. I don't know what I want to use for the mounting hardware quite yet though... Thats where I would like some advice. I don't have any fabricating tools around that I have access too and so its just me, my weld torch and dry ice and menthol.
I'll update this as I go, I thought I would get it started for any one to post helpful links etc..
Stay Tune!
Sil3ntSnip3a is offline   Reply With Quote
Old 10-01-2009, 02:14 PM   #2
K404
Banned
K404's Avatar
Welcome to XS If you can find a delrin plate on Ebay, that would make a great hold-down. Easy to work with, rigid (from ~6mm thickness at the size you'll be needing) and doesnt conduct heat
K404 is offline   Reply With Quote
Old 10-01-2009, 07:06 PM   #3
Sil3ntSnip3a
I am trying to spend as little money as possible but still see immense performance increase. Tell me what you think of this kind of a pot set-up.
http://www.youtube.com/watch?v=kQFvid_W4n4
It looked cheap and effective, you tell me though
Old 10-02-2009, 01:36 AM   #4
K404
Banned
K404's Avatar
Im not sure about the fibreglass insulation... id always recommend neoprene. Vince has a great guide in this section, have you read over that?
As for the pot.... if the bottom end cap has a mix of mass and surface area it would work alright
Old 10-02-2009, 01:47 AM   #5
loonym
Xtremely unstable
loonym's Avatar
I did pretty much the same as you. I just sort of made it up as I went along. Here's my thread... http://www.xtremesystems.org/forums/...d.php?t=230427
If I can be of any help just lemme know.
__________________
dx58so
w3520@4100
4x1gb corsair ddr3-1333
gtx 295
TR ultra-x, 2 scythe ultrakaze push/pull
xclio stablepower 1000
vista ultimate
would you crunch if you thought it would save her life?
maybe it will!
loonym is offline   Reply With Quote
Old 10-02-2009, 04:49 PM   #6
Sil3ntSnip3a
Where can I find the supplies to make my first pot? I don't have access to a lathe or a drill press. I just need some recommendations and some links or something. I really want to get into extreme benchmarking via Dry Ice!
__________________
CPU: Athlon 64 x2 6000+
Mobo: Asus M2N32-SLI Deluxe
RAM: Kingston HyperX DDR2 800
GPU: XFX 8600 GT x2 SLI
Heatsink: Asus Arctic Square 92mm | Artic Silver 5 thermal
PSU: Apevia Iceberg 680w
Chassis: Logisys Area 51
Old 10-02-2009, 07:04 PM   #7
loonym
Xtremely unstable
loonym's Avatar
You can get materials from local metal warehouses, or ebay. No special or expensive machine tools are needed as you can see by reading my thread. I used a hand drill, 4 1/2" angle grinder, palm sander, and a cheapo router. For the hold down I used some 14ga steel for the back plate, threaded rod and thumb nuts, and the top is made from a white teflon cutting board I got at a local cooking supply shop. None of this has to be complicated or costly.
__________________
dx58so
w3520@4100
gtx 295
vista ultimate
maybe it will!
Old 10-04-2009, 08:56 PM   #8
Sil3ntSnip3a
where did you get the metal for the pot though, I am having trouble finding 3 1/2" copper tubing for my pot. and maybe 3 1/2" isn't a good size for my cpu, idk... what do you guys think about finding the supplies and the right sizing etc..
__________________
Old 10-05-2009, 03:11 PM   #9
lesstutrey
lesstutrey's Avatar
Send a message via AIM to lesstutrey
3 1/2" is a bit big... the hole spacing on a 775 is only 72mm hole spacing, which is like 2.834" meaning your pot would cover up any ability to mount on a 775 socket, 1156 is 75mm, and 1366 is 80mm... can't tell you what it is on am2/am3 but i know it's slightly larger... i'd consider small tubing if you wanna mount it on anything
__________________
Cooling:
Custom SS made by RunMC of under-the-ice.com
80L Cryofab CL80 Dewar
Otternase EEAL.CU
Tried: e8400,q6600,qx9650
Subzero queue: AMD Athlon 64 3000+,3200+,3500+ winchester, 3500+ newcastle, 3500+ Orleans, 3700+, 4000+, 4200x2+ & DFI LP Ultra
Intel P4: 520, 631
w3550+Bloodrage GTI,
asus commando
Inbound: sdumper SS
lesstutrey is offline   Reply With Quote
Old 10-05-2009, 05:25 PM   #10
voklskier4452
voklskier4452's Avatar
Send a message via AIM to voklskier4452
i agree with lesstutrey 3 1/2" is going to be a bit large, the largest i would go for a round part is 3" diameter.
__________________
New Bench system on the Way!!
Asus Rampage Extreme
Intel E8600 (Q820A405)
Intel E6500K
Team Xtreem (1866)
Asus EAH4890 TOP X2
Corsair HX1000
Custom LN2 pot on the way as well
voklskier4452 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
