XtremeSystems Forums
Reply
Old 10-01-2009, 07:40 AM   #1
moiraesfate
Does a waterblock for the Biostar mosfets actually exist?
It is really really hot to the touch. So hot that I'm surprised the plastic hasn't melted. But I can't seem to find a waterblock for it.
Suggestions?
Mobo is in sig.
__________________
Antec Twelve Hundred - Corsair TX750 - WD Caviar Black 640GB - Logitech MX518 - G.SKILL PI Black 4GB (2 x 2GB) DDR2 800 - XIGMATEK HDT-S1283 - BIOSTAR TFORCE TA790GX - Vista Home Premium SP1 64-bit - AMD Phenom II X4 940 - EVGA 55nm GTX260 Core 216 - RAZER Lycosa
Here's the thing about freedom... yours ends where mine begins, and I have the right to be free from other peoples garbage on my lawn. If you can keep your own garbage on your own lawn, good for you, if you can't, then you can just suck it up.
moiraesfate is offline   Reply With Quote
Old 10-01-2009, 07:44 AM   #2
eponymous
eponymous's Avatar
Koolance have a pretty large selection for waterblocks of MOSFETS. They use blocks that have plates to allow them to fit to most boards. I'd check their site out.
__________________
[Project] : Altair | A Lian-Li PC-P80, dual loop, all internal build.
Hardware
Core i7 920 D0 | Corsair Dominator 1600MHz CL8 RAM | 2x EVGA GTX 285 SLI | ASUS P6T Deluxe V2 | ASUS Xonar D2X
2x Intel X-25M SSD | WD RE3 1TB (WD1002FBYS) | Corsair HX-1000W | Lian-Li PC-P80 | Dell 3008WFP 30"
Watercooling Gear (Dual Loop)
Koolance 350AT (CPU Loop) | 2x Koolance VID-NX285 (GPU Loop) | 2x Laing DDC 3.2 / XSPC Acrylic top Rev. 3 | 2x EK Multioption 150 Res Ver. 2 | 2x Thermochill PA 120.3 |
6x Scythe S-Flex 1200 RPM Fans | 7/16" Primochill Pro Green LRT | 7/16" Primochill Pro Blue LRT | B.P. Silver Shiny 1\2" Barbs | Alphacool Ball Valve / B.P. M-M Rotary fill-port / drain | Bitspower Black Freezer AIX58NS NB/SB (GPU Loop)| Black Freezer MOS AMOSII POM Version (GPU Loop)| Bitspower Black Freezer MOS AMOSIII POM Version (GPU Loop)
eponymous is online now   Reply With Quote
Old 10-01-2009, 07:56 AM   #3
moiraesfate
ooo, thanks. Thats exactly what I needed.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
