XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Chilled Liquid Cooling
Reply
Old 10-01-2009, 01:41 AM   #1
gordy
JBJ aquarium chillers
Considering one of these aquarium chillers. Would the 1/15hp be sufficient to cool an i7 and pair of gtx 290s? Also, is an MPC-355 enough to pump the water through it?
edit: linky
http://www.jbjnanocubes.com/contents...-Chillers.html
gordy is offline   Reply With Quote
Old 10-01-2009, 02:29 AM   #2
billdavis
billdavis's Avatar
Send a message via Yahoo to billdavis
1/15 hp
no bro
__________________
De oppresso liber
Nous Defions
Nothing follows
cpu PXA310 memmory 197.36mb
billdavis is offline   Reply With Quote
Old 10-01-2009, 03:12 AM   #3
Sam__
Sam__'s Avatar
1/15hp really isnt much.
__________________
"Computers in the future may weigh no more than 1.5 tons."
- Popular Mechanics, 1949
"I think there is a world market for maybe five computers."
- Thomas Watson, chairman of IBM, 1943
Heat
Sam__ is offline   Reply With Quote
Old 10-01-2009, 11:42 AM   #4
gordy
how much power is required? the 1/15hp is the smallest, but they also have 1/10, 1/5, 1/3/ etc. they get expensive and large at that power level. It seems like it would be overkill for a pc. Removing around 400 watts of heat from around 100ml of fluid?
Old 10-01-2009, 01:51 PM   #5
chew*
No rest for the weary
chew*'s Avatar
I used those for salwater tanks.....they are good for maintaining temps at about 78F........thats about it.
__________________
heatware chew*
AMD is Back in Black Lifes more fun at -190C
How To Behave On An Internet Forum
http://www.thewavingcat.com/2008/02/...eed-the-troll/
Originally Posted by Sampsa View Post
1) Normal ES: Available to partners and press before the product actually launches. These are usually close to retail parts, maybe one stepping/node before retails. From my experience (I've had access to AMD & Intel ES CPUs before the official launch around 8 years) normal ES CPUs are actually usually worse than retails because manufacturing process develops all the time and retails keep getting better. Every Phenom II press sample (not even marked as ES but couple weeks earlier than retail parts) I've tested so far have been worse than normal retails.
chew* is offline   Reply With Quote
Old 10-01-2009, 03:17 PM   #6
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
Let's use our noggin for a second. You want to use a fluid, in this case water, to remove heat from your PC. You mention a Core i7 and a pair of GTX290s. GTX290s don't exist so I'm going to assume you meant GTX295s. The CPU when overclocked will be in the range of 200w and each GPU is something like 250w, so you are looking at 700w of heat. Adding 700w of heat into the water requires removing 700w heat from the water somewhere else or the temperature of the water will increase.
So in closing, unless your chiller can remove maximum load I would suggest sticking with air or traditional water cooling. There are chillers that can handle this load, they just are large and expensive.
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is offline   Reply With Quote
Old 10-01-2009, 04:33 PM   #7
gordy
sorry my cards are actually gtx 280, so far less wattage. My PSU is only 650w so I'm sure total draw is under 700. My i7 @3.8ghz (1.2v) is producing ~155w according to hwmonitor.
I'm currently using two 120mm rads and the system will approach 80c at load. I thought that a chiller might be more effective at removing heat than rads. I guess that's not the case?
You guys building chilled water setups, do you use rads as well and chill in a separate loop or does the chiller dissipate all of the heat? I have a dual pump dual res and two loops so I could definitely keep the rads and use the 2nd pump to circulate the chiller. Is there a rough correlation to hp and the amount of heat in watts it can remove?
Old 10-01-2009, 05:24 PM   #8
[XC] gomeler
The chiller dissipates all the heat and typically below ambient temperatures.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
