XtremeSystems Forums
Reply
Old 09-30-2009, 09:43 PM   #1
Baulten
First leak... I think!
I was playing some Mass Effect earlier, left, and reentered the room, only to notice my reservoir is filled with bubbles! Every fitting is tight, res is tight. I'm assuming this means there is a leak somewhere between the reservoir and pump, because that's the only place the pressure is negative, so a leak would pull air in?
I'm going to leaktest tomorrow, but if I could narrow it down a bit that'd be nice. Luckily I caught it before anything was damaged or leaked on.
__________________
Builds: Old / New
CPU: Phenom II 940 / Phenom II 965
CPU cooler: Xigmatek s1283 / Watercooled
Motherboard: DFI LanParty 790FX-M2RS / MSI 790FX-GD70
RAM: 2x2GB G.Skill DDR2 800 / 2x2GB G.Skill DDR3 1600
Video card: GTX 260 / HD 5870
Hard drive: 2x250 GB Seagates, 1x250 GB Western Digital (SATA), 1 TB WD External
Case: Modded Cooler Master RC-690 Mid Tower / Corsair Obsidian 800D
Baulten is offline   Reply With Quote
Old 09-30-2009, 09:48 PM   #2
pika198
Quick question, first time water cooling and when did you setup your loop?
If you just setup your loop in the past 3-5 days, then this would be normal. There are trapped air bubbles usually inside the CPU water block and/or radiator. Tilt your case at an angle and you'll hear the air bubbles being moved throughout the loop. They will get trapped in the reservoir slowly, and over a period they will disappear. This is VERY common/normal on newly built loops, even on older setups if the case hasn't been tilted.
pika198 is offline   Reply With Quote
Old 09-30-2009, 09:53 PM   #3
Baulten
No, it's been running about two weeks. I shut it off, the bubbles disappear. I turn it on, more build up as it runs. I guess it's possible that there was an air pocket trapped... I'll give it a few good tilts and see if it stops. The res was perfectly clear for the past week after all the air initially got bled out. The fact that more bubbles appear the longer I have it running makes me think it's pulling air in somewhere.
__________________
Builds: Old / New
Old 09-30-2009, 10:53 PM   #4
pika198
Perhaps, but if a trapped air bubble finally came loose, then it will throw your whole entire "still" res off. After the a couple of tilts and using it for another 8 hours or so, you should be good to go. Doesn't hurt to put napkins around the loop just in case til the air is settled
Old 10-01-2009, 04:41 AM   #5
MaByBoI
Xtreme Cable Management Freak
MaByBoI's Avatar
put down some napkins or paper towel, give the case a shake in order to get some bubbles loosened up, and then try again. should be normal.
__________________
Blood(Rage) shall be spilt
Intel Core i7 | Enzotech Sapphire
EVGA GTX 295 co-op | Swiftech Epsilon
Foxconn BloodRage | BloodRage Waterblock
OCZ Platinum 6gb DDR3 | GTX 480 QUAD rad
Corsair HX1000W | MCP 655
Silverstone TJ-07 | FrozenQ T-Virus Res
WD 1TB Black | Distilled Water
I also have a Macbook Air
MaByBoI is offline   Reply With Quote
Old 10-01-2009, 05:35 AM   #6
zeropluszero
zeropluszero's Avatar
Send a message via MSN to zeropluszero
this seems like the thread to ask this question, while were on the subject of bleeding.
my setup has been going for about 3 weeks now, with cycles of off and on, and i'm quite sure the air has been removed from the loop, however my res still goes up and down when i turn the computer on again. is this normal or is there a pressure problem or something?
__________________
Cosmos S - Q9550 E0 - EVGA 780i FTW - 4GB Dominator 8500 - SLI GTX280 - 150GB Velociraptor - Enermax 85+ 1050W
Parallel Loop using EK MultiLink Reservoir
CPU Loop: Heatkiller 3.0 CU (Nickel plated) - Feser 360 (S-Flex G) - MCP350 + EK Plexi Top - EK Reservoir
NB/SB + GPU Loop: EK 280 Nickel Plexi - Bitspower 780i Fullcover - Feser 240 (S-Flex G) - MCP355 + EK Plexi top
zeropluszero is offline   Reply With Quote
Old 10-01-2009, 05:41 AM   #7
Sadasius
Tygon Warrior
Sadasius's Avatar
It's not a leak. Just has air trapped in the loop somewhere. Probably in the rad especially if it's horizontal. Make sure the res is filled and everything is sealed and turn the case around (with it off of course) and get the air to move to the res if possible. Turn it back, plug it in for a minute or two to get the bubbles working loose and do it agian a couple time. After a day or two if it still has bubbles just do it again.
Yeah that's normal. Mine does that all the time as does everyone else's.
__________________
San Ace Awesomeness!
San Ace Awesomeness Part II!
If you cannot handle the truth DO NOT click--> this link!!!
Sadasius is offline   Reply With Quote
Old 10-01-2009, 06:28 AM   #8
BrokenArrow
BrokenArrow's Avatar
I also find it helpful to unscrew the top fitting slightly to let the pressurized air escape out the top.
BrokenArrow is offline   Reply With Quote
Old 10-01-2009, 06:42 AM   #9
millertime359
Xtreme Mentor
millertime359's Avatar
My Swiftech res did the same thing.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 10-01-2009, 06:46 AM   #10
Baulten
Well, I'll drag it out here after chem lab and tilting the case back and forth a few times, then let it run for a bit and see if the bubbles disappear.
__________________
Builds: Old / New
Old 10-01-2009, 07:21 AM   #11
Asylum1
Asylum1's Avatar
Yea i would say it was just air trapped in the loop.
If you had a leak it would just drip some where not suck in air bubbles.
__________________
Killer
Core i7 920 @ 4.2Ghz
EVGA X58 758 SLI
2xGTX295's in SLI
3x2Gig Kingston Hyper X 2100mhz
Corsair HX1000 Watt Modular
Water Cooling
3DMark Vantage 41312
Asylum1 is offline   Reply With Quote
Old 10-01-2009, 07:51 AM   #12
Caoder
Caoder's Avatar
Send a message via MSN to Caoder
well one time i had a leak and it drew in bubbles as the flow went but it was very obvious where it was drawing in air ( loose fitting)
__________________
Core i7 920 D0 @ 4.2 | 2 x GTX 260 | EVGA x58 SLI | 3 x 2 gb GSKILL Perfect Storm 17066CL9|
CPU under WC/ gtz + 2x mcr220
Caoder is offline   Reply With Quote
Old 10-01-2009, 09:38 AM   #13
pika198
Yup, this is normal. You see a lot of it with the Swiftech and EK res. If you use an XSPC pump/res top, you'll still get a little decrease when it is one, but it is much less noticeably.
Old 10-01-2009, 09:51 AM   #14
doox00
make sure res is filled all the way, I just went through the same thing, loop was up for 9ish months and started getting bubbles, tightened the fittings, no change. topped off the res (took very little to top it off) and bubbles went away after a minute.
__________________
Core i7 920 @ 3.8ghz
6gb Mushkin XP3-12800
Asus P6T Deluxe
GTX 260 SLI
Audigy X-Fi
PCPC 750w P75QB
42" Philips 1080p LCD
Windows 7 Pro 64
heat: doox00
doox00 is offline   Reply With Quote
Old 10-01-2009, 03:17 PM   #15
Baulten
Okay, I feel like a bit of a moron now. It was indeed a bit of air trapped in the waterblock; I gave things a good tilt in all directions, booted up, seems clean now. CPU temps dropped by 5C, so... woot.
__________________
Builds: Old / New
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
