Im going to be watercooling my core i7 D0, my bloodrage north bridge, and my gtx 295 co-op.... there shouldnt be a problem right? gtx 480 + 4 high speed yate loons....
thanks!
__________________
Blood(Rage) shall be spilt
Intel Core i7 | Enzotech Sapphire
EVGA GTX 295 co-op | Swiftech Epsilon
Foxconn BloodRage | BloodRage Waterblock
OCZ Platinum 6gb DDR3 | GTX 480 QUAD rad
Corsair HX1000W | MCP 655
Silverstone TJ-07 | FrozenQ T-Virus Res
WD 1TB Black | Distilled Water
I also have a Macbook Air
Skinee's article on the GTX360 says you can achieve a 10 degrees C delta for 700 watts of heat on 1800rpm fans. I see no problem with the GTX480 for your setup.
__________________
Banchetto
Intel i7 920 @ 4.20|Asus P6T6 Revolution|G.Skill 6gb DDR3 1600|Sapphire 4890 Toxic|Intel x-25 E 64GB H2O
HK 3.0 Block|Koolance P6T6 Block|355 w/ XSPC Res Top|Dual MCR320's|EK Acrylic/Nickel 4890 Block
well i have the fans wired to a fan controller, and when im not gaming i have them down really low, ill probly plan to overclock, so may need to bump em up, when im gaming noise isnt an issue, im just concerned about destroying my precious equipment
__________________
with 3krpm fans... the GTX is a MONSTER.
As i said if u dont mind the noise, grab 38mm fans to pair it up, or push pull config on it, and you'll be fine.
awesome! sounds good to me! ill check out my temps when im all done and see what i think from there! thanks for the answers!
__________________
well that makes me happy to hear! good thing i got it for half price then!
thanks!
__________________
Well don't we have the water cooled world by the balls... Best 120mm rad and you got it half price. The world is smiling upon you.
ahaha, well i can thank Linus for that!
__________________
I was just looking at the review on Martin's old site of the Feser 480 rad and the interesting thing about it was how close or better it performed compared to the 480GTX until you got above ~1800RPM fan speed. I've seen hints that there is some animosity towards Feser in the community though, is that the case? Seems the Feser 480 is also pretty $$$ comparatively as well.
"Hints of animosity towards Fester"?. . .I've tried to be as blatant about it as possible.
Where would you like me to start?
That's what I thought. Feel free to start at the beginning, I have popcorn in hand
But at the same time, that TFC 480 rad has some decent performance from Martin's test. I'm trying to decide on a quad right now and I've gone back and forth between 480GTX, TC PA120.4, and now the TFC 480 I guess it doesn't really matter between them all, but I'm obsessing heh
When I had the GTX 480 on my test bench with 3,000 RPM kaze's I was always amazed at the cooling power. Even the little GTX 240 with the same fans will cool a surprising amount. But if you are looking for low noise levels, I would look elsewhere.
I am becoming more and more of a fan of swiftech radiators, very hard to beat for the price must be why I have 5 of them in use at my house.
__________________
MM Ascension case,
Classified, 920 @ 4.6Ghz,
(2) toxic 4890's @ 1000,
Mushkin redline ascents 6gb, 1768 Mhz 7-7-6-19
(8) intel x25m RAID 0 on LSI 9260
heat killer, 2 swiftech mcr 320's, feser 360, Xspc Rx360, EK full coverage MB WB. 655 with detroit top, 355 with Xspc top
well i already have the rad you see, i was just making sure before i install my components next week..
__________________
It will be more than enough. I had i7 920 do, bloodrage NB and 4870x2 in same loop before. And I had one crappy 360 radiator, no problems with the temps...It was named Mist Extreme 360. So your 480GTX will do well
__________________ Hardware
Core i7 920 D0 stepping @ 4.2 Gigahurtz 24/7 1.2v |Lapped Mirror finish|
EVGA Classified 760 w/ EK Classified Fullcover and Foxconn Bloodrage x58
Dominator GT 2000Mhz CL8 3x2GB
2x Crossfired Sapphire 4890 Toxic 1000/1050
Corsair HX1000w PSU
Samsung SpinPoint F1 500GB *Shame*
Case: A+ Black Pearl WCR; Powder Coated in metallic Black
Asus Commando
OCZ Flex 9600 2GB
And a lot of random chips
Kingpin F1 w/Extender incoming
TFC Monsta and Stinger V8.
