It's funny how they captured the two ends of the spectrum here. They are the new 600 rpm holders as well as anything with 1800 rpm and higher. Nice review Skinny and thank you for taking the time. This rad is not for me though. Too quiet....I like my case to hover and my water .5 degrees of ambient...
That is what i thought it would be, nothing special but overpriced. $135 + Shipping for a 360 rad is not what i have in mind. The 480 was like $160. I guess some people will never own a SR1
As Skinnee noted in another thread, he's using water average instead of water out to calculate his delta, unlike in previous tests. This will skew the results slightly in favor of the other rads. I did a quick calculation of the SR1 at 1000RPM using the old method and got 358W at 10C instead of 352W with the new method. Not a huge difference, but the difference between the rads is not huge to begin with.
Curiously, Skinnee has either made a typo or miscalculated in the RX360 review at 1000RPM. He calculates a delta of 7.54C when it should be 7.88C using the numbers in his table. Carrying out the rest of the calculation using these numbers drops the RX360 from 368W to 360W.
Given this, the difference between the RX360 and SR1 at 1000RPM would be 2W instead of the 16W.
No..
XSPC = Full Copper Radiator... (just like feser, its the midman's feser to be exact).
Vs.
Stealth = Not A Full Copper Radiator...
which brings back the question..
Why is a non full copper radiator cost more then a full copper radiator when there both made outside the USA.
millertime for posting, with my work schedule and personal life things just take me a bit longer. The lab site always gets info first...then the forum versions come after that... but you're going to see a different forum version than I have used in the past. The idea I have in mind is similar to the news releases (think the News Section here at XS and the starter posts) that point to the main article on the lab site.
One thing to note about the review that I hope people are catching before going to the thermal results page and just reading the plots... The SR1 (and TFC360) calcs use Water Avg-Air In for Delta T and C/W. The current update I'm working on with change all the rad tables and charts over to Water Avg as well as the Triples Comparison will be updated. This took a lot longer because I had to fix the data storage problem...my template and workbook solution just wasn't very manageable and a lot of data had to be moved to the new workbook structure, I could really use some assistance from a web developer who can handle Content Management Systems, PHP, Ajax and MySQL <- hint, hint
Well, I took long enough typing out this reply that alacheesu got in before me...glad you caught the analysis difference, means you do actually read the write-up. I went diggin back through the RX data, and you're right the chart was wrong. The dT referenced the proper cell on the equation worksheet, but the water out cell was one too low (referenced row 8 instead of row 7). So the dT was right, the Water out was wrong. I did have to go through my new work books and make sure all was correct though. Either way, thanks for catching it and bringing it up... I'm human and screw up too, just ask my wife.
Enough blabbering from me...I'll keep chugging along, I have a lot of work to do in order to keep information coming from the tests and reviews I signed up for. Just know I'm not disappearing...just trying to keep my sanity. Although, with Vapor keeping such a feverish pace we may have to rename the site soon.
edit:
alacheesu, I proudly give you a to swing at Naekuh's soapbox when necessary.
__________________ skinnee labs test schedule: In Testing: Too much to list. Writing Reviews: finally getting my backlog cleaned up too. Planned Tests: Plan, what the heck is a plan.
do you think it will cool a i7 920 D0 (good batch) to 4.2 or maby even higher
thanks in advance
__________________
asus p6t7 ws supercomputer
i7 920 D0
4870 (waiting for new videocard's to come out)
Corsair Triple3X Dominator 6GB DDR3-1866 CL9 triple kit
Corsair HX1000W
windows 7 rc
thanks in advance
pleassssss can somebody help me
__________________
i7 920 D0
Corsair HX1000W
windows 7 rc
That's possible with most triple radiators (and even a dual), so shouldn't be a problem. Of course, it depends on what else you're putting in your loop, on pump / water blocks / ambient temp / etc. And, of course, your CPU processor.
Let's just say the SR1 won't be a roadblock in your quest for 4.2 GHz, but neither will it be a guarantee.
__________________
i7 920 D0
Corsair HX1000W
windows 7 rc
so why does this rad cost more then a RX360 when it performs less then it?
Didn't you get the memo? If it costs more it is has to be better.
__________________
*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
Q6600 @ 3.7Ghz / Maximus Formula X38 / 4GB Supertalent 6400 / 4870 HD
PC Power & Cooling 750W
Mountain Mods U2-UFO Cube
GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
Win7
"Artificial intelligence is no match for natural stupidity."
Originally Posted by ranker
Did you just get hit in the head with a heavy object? Because obviously you're failing at reading comprehension.
Well, I do agree from the photos I have seen, the SR1s do look awesome and if I was building a rig for a competition I could see using them. As for raw performance though, I haven't heard any issues on here about XSPC rads prematurely failing on people and they seem to perform better according to Skinnee's results.
i may get flamed on this but :
the build quality is 10x better than XSPC rads
No flame, that is a very legitimate observation... But for me personally, it has always been function over form. In my old age, I'm starting to care less though...
__________________
Win7
They look and feel amazing. Since I am using them to supplement 2 PA 120.2's, I am less worried about looks. I was going to go XSPC, but decided to splash out and try something new.
They are pretty amazing looking / feeling rads. Certainly better than my TC's in that department.
__________________
"Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
i7 920 3924A | 4870x2 | EVGA M-ATX X58 | 6GM Corsair Dominator | Corsair HX1000 | Intel X25-M 160 G2 | OCZ Vertex 60 | WD 320 || Apogee GTZ - XSPC FC | (2)DDC3.2 | (2)PA 120.2 | (2)BI SR-1 120 || MM H2G0
E6600 L627B005 | 4870x2 | OCZ Flex II | P5K Deluxe | Corsair HX1000 || (1) Apogee GT - PA 120.2 - DDC3.2 w/ XSPC Restop (2) XSPC FC - PA 120.2 - DDC3.2 w/ XSPC Restop || MM H2G0
