New DDC tops from Watercool
I don't think this has been previously posted but sorry if it has. There are two new tops available, one is a double and the other resembles the styling of the Heatkiller v3.0LT:
__________________
"The state must declare the child to be the most precious treasure of the people. As long as the government is perceived as working for the benefit of the children, the people will happily endure almost any curtailment of liberty and almost any deprivation." - Adolph Hitler (Mein Kampf) and most likely Jack Thompson's inspiration.
They don't have any shots of the internals up on their site and knowing them they probably never will. Someone will probably have to get one and post shots here.
__________________
gah! why cant these things be made in plexi!! that aqua computer one seems to be designed to negate the fact that the pumps work better when the inlet is at the top, rather than the side, which is better for putting it in a thin place? (such as between 5.25" devices for example)
Parallel Loop using EK MultiLink Reservoir CPU Loop: Heatkiller 3.0 CU (Nickel plated) - Feser 360 (S-Flex G) - MCP350 + EK Plexi Top - EK Reservoir
NB/SB + GPU Loop: EK 280 Nickel Plexi - Bitspower 780i Fullcover - Feser 240 (S-Flex G) - MCP355 + EK Plexi top
The AC dual top looks deferment than any dual top iv seen, the channels looks weird !
is it because each bump has two inlets/outlets ??
I think this design is nice since it allows the discharge from the first pump to enter the large area inlet to the second pump. I feel this would reduce the sharp 90° turns that choked performance on most dual DDC pump tops. I want to get one and test myself though.
Warning, thread hijack
I just got that AC dual top along with two MCP355's for my upcoming chiller build - what would give me the best performance with that top? Using the in/outlets on top?
__________________ World Community Grid - come join a great team and help us fight for a better tomorrow!
--> 200 Ghz working 24/7 to kick diseases right where it hurts
Envy me already? No problem, I'll send you my power bill and you'll instantly feel better
[sarcasm]Cedric. . .you suck, I mean really really suck. . .there's another ~$50 I need to spend now.[/sarcasm]
How so?
It has;
1 side inlet
1 top inlet
1 side outlet
1 top outlet. . .what more does a pump top need for versatility.
News Flash. . .this topic was jacked the instant Cedric post those AC pics.
Best performance with any DDC top is going to be top inlet/side outlet.
Top: Inlet
Side: Outlet
Yes, I really want both the AC and the new watercool dual tops. Having my two XSPC hooked up in series by a 45 just doesn't cut it anymore.
Originally Posted by NaeKuh
i prefer my dual inlet.
Your hardwareluxx top for the DDC orange impellars?
Jealousy makes my day stink.
__________________
"Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
i7 920 3924A | 4870x2 | EVGA M-ATX X58 | 6GM Corsair Dominator | Corsair HX1000 | Intel X25-M 160 G2 | OCZ Vertex 60 | WD 320 || Apogee GTZ - XSPC FC | (2)DDC3.2 | (2)PA 120.2 | (2)BI SR-1 120 || MM H2G0
E6600 L627B005 | 4870x2 | OCZ Flex II | P5K Deluxe | Corsair HX1000 || (1) Apogee GT - PA 120.2 - DDC3.2 w/ XSPC Restop (2) XSPC FC - PA 120.2 - DDC3.2 w/ XSPC Restop || MM H2G0
