XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 09-30-2009, 12:40 AM   #1
exe163
exe163's Avatar
MOSFET cooler for R2E?
I have a R2E under water atm. Mosfets are cooled by Koolance universal blocks. But I find that having them in the same loop as my CPU and northbridge it might limit my flow rate. I am thinking about replacing them with passive air cooling.
Will these work on my mobo?
http://www.performance-pcs.com/catal...ducts_id=21654
__________________
Armor.exe worklog
Mobo: Asus Rampage 2 Extreme X58
CPU: i7 920
GPU: ATi HD 4870x2
Sound: Auzentech X-Fi Forte 7.1
PSU : Corsair HX1000
RAM: OCZ 3 x 2GB tri channel DDR3-1600
HDD: WD 640 Black RAID 0 + 1
Watercooled
exe163 is offline   Reply With Quote
Old 10-01-2009, 02:26 AM   #2
Sangrak
You'll want HR-09U type 2 for the I/O side mosfet and HR-09S type 3 for the top mosfet. All this information can be found on the Thermalright site.
The quality is very good, at any rate.
__________________
Asus Striker II Extreme | BIOS 1203| Q9650 @ 4.05ghz FSB 1800 Linked/Synced | 4 x 2GB Patriot Viper PC2000 8-8-8-22-2T-1.94v(2.02) P1&P2 Enabled | 2 x EVGA GTX280 | X-Fi Titanium Fatal1ty Pro | 1 x WD Velociraptor, 1 x WD Raptor 150GB, 1 x WD 1TB | Corsair HX1000W PSU | 24" Sony GDM-FW900 CRT | 20" Cintiq 20WSX | OS: Dual Booting XP Pro/Vista 64
Sangrak is offline   Reply With Quote
Old 10-04-2009, 05:45 PM   #3
BababooeyHTJ
I am Xtreme
BababooeyHTJ's Avatar
The compatible HR-09 sinks are listed here. Enzotech MST-88 will fit as well.
__________________
Asus P5Q Deluxe bios 2001m, Intel q9650, True black, 8gb G.Skill 4x2gb PC8500, Evga GTX280 SSC, HR-03 GTX, Pc Power and Cooling 750w silencer, Antec 1200
Originally Posted by LiberalElephant View Post
ASUS actually hates you and wants you to die by way of freak south bridge chipset fire than eventually englufs your entire house while you sleep. The kicker is that ASUS installs a program on your computer that causes it to download gay porn while you are idle until the south bridge over-heats and you die in a gay-porn fireball. Your relatives find your hard drive full of gay porn and the evil empire of ASUS has struck again.
Disclaimer: Being gay is okay. ASUS is not actually trying to kill you in a fireball of gay-porn.
This post was worthless and I am very very bored.
BababooeyHTJ is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
