New Swiftech Komodo Waterblocks For Gtx275 And Gtx285
Introducing the new Komodo GTX285-P892 and Komodo GTX275-P897 waterblocks.
As their names indicate, these blocks are for nVidia's latest offerings. The P892 (actual nVidia name for this reference board) is also called GTX285 rev 2 by some vendors.
Both these blocks feature a black acetal top, and a chrome plated copper base.
Here are some pics:
Komodo GTX275-P897
Komodo GTX285-P892
The backside features pre-applied thermal pads with peel-off protection
The 0.6x0.6mm pin matrix
Pressure drop is very similar to that of the MCW60
For those who go to our web site, notice the announcement on the product page of an upcoming version of the Komodo for ATI 5800 series.
The MSRP for both blocks is $134.95
We are shipping to the dealers this week.
Wow, best full cover design I've seen in terms of the cooling patch for the core. Should be very efficient, and I'm shocked by the pressure drop. Very impressive.
Stand offs - check
Chrome plating - check
thermal pads - check ...wait, pre-applied, we don't have to cut up thermal pads.
Impressive pressure drop as well, looks to be a very free flowing block with a focused pin matrix. Kicking myself for buying a GTX260 instead of spending a few dollars more on a GTX275 for my new bench.
__________________ skinnee labs test schedule: In Testing: Too much to list. Writing Reviews: finally getting my backlog cleaned up too. Planned Tests: Plan, what the heck is a plan.
Stand offs - check
yep, I was surprised how well this 275 performs actually.
amazing looking blocks! i recently ordered the 295 "epsilon" block, cant wait to get it installed!
__________________
Blood(Rage) shall be spilt
Intel Core i7 | Enzotech Sapphire
EVGA GTX 295 co-op | Swiftech Epsilon
Foxconn BloodRage | BloodRage Waterblock
OCZ Platinum 6gb DDR3 | GTX 480 QUAD rad
Corsair HX1000W | MCP 655
Silverstone TJ-07 | FrozenQ T-Virus Res
WD 1TB Black | Distilled Water
I also have a Macbook Air
since we are on the subject of Epsilon, here is an EPSILON INSTALLATION TIP: to make sure that you get good contact between block and GPU's:
This particular board, being a dual GPU config, has lots of thermal pads for power mosfets, memory, etc..; it means that there is much more thermal material to compress before a good mate can happen between copper base and GPU. To prevent undue stress on the very small M2screws, AND to get good contact, you want to place the block clear face down on your bench, and while fastening the GPU screws, you want to VERY FIRMLY PUSH DOWN on the board with two fingers positionned in the center of the GPU area (do that twice since it's dual GPU). This is pre-compressing the board against the block, and allows you to get maximum down force without stressing the screw threads or striping the philips head.
Wow, something nice almost came out of naekuh there ! so close..
gorgeous blocks, dont fit my 285gtx though =[
Unless your board is non-reference, there are only two nVidia reference boards for GTX285: the P891, and the P892. We have Komodo water-blocks for both.
thank you for that gabe! ill be sure to do so, should help a fair bit! and btw, nice nails you got there!
__________________
So gabe.. about those heatsinks... any plans for 58xx series? Either waterblock or preferably heatsink?
Year even though these blocks are nice its a tad too late they are not for people buying new cards (Unless your Nvidia fanboy ofc) alternatives for the newest and best cards would be nice
Beautiful blocks. Yeah talk about taking it to the next level in consumer satisfaction....standoff's.....pre applied thermal pads and hell even chrome. Not to mention the great flow as well. Damn if your making the 5870X2 block consider one sold to me!
Very nice blocks with even nicer characteristics...
OT. Now it's time to design a killer of the HeatKiller 3.0...
__________________
Asus Maximus II Formula
Intel Core2 Duo E8400 E0 Q828A Malay @ 4.50GHz (8.5 X 530mhz) WC'ed
2 x 2GB Mushkin XP2-8500 @ 1060MHz (5-5-5-15)
Asus 4870X2 @ 850/950MHz WC'ed
150gb Western Digital Velociraptor | 2 x 320gb Western Digital Caviar SE16 sataII
SoundBlaster Audigy4 | Logitech Z-5500 | LG W2600HP 26" TFT
MountainMods UFO | Zalman ZM-850HP psu
Watercooling setup:
1st loop -> Radiator: ThermoChill PA 120.3 | Pump: Laing DDC Ultra with Alphacool top | CPU: Swiftech Apogee GTX CU |Chipset: Swiftech MCW-NBMAX | Tubing: PrimoFlex 1/2" Pro LRT
2nd loop -> Radiator: Swiftech MCR-220 | Pump: Laing DDC Pro with Alphacool top |GPU: EK FC-4870X2| Tubing: PrimoFlex 1/2" Pro LRT
