XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 09-29-2009, 04:45 PM   #1
piotres
-100c Club Member
piotres's Avatar
Send a message via ICQ to piotres Send a message via MSN to piotres
Question to overclockers ... (54mm evap would fit ?)
Hi
I plan to use mine new 54mm diam steeper evaporator . And I got it ready to use, only the problem is I'm not 100% sure if it'll fit for ALL newest and older motherboards ?
Please look at this design, can You told if if it won't be making colision with any part of motherboards , like capacitors and simillar ?
Thanks a lot
Regards
Peter
piotres is offline   Reply With Quote
Old 09-29-2009, 05:36 PM   #2
Buckeye
Phantom is here :)
Buckeye's Avatar
Well that is the very same evap enclosure I have and it fits everything so far with out any problems.
Your Evap looks pretty big tho., it fits inside that enclosure with plenty of room for insulation, that foam stuff they use inside ?
never mind I see what your talking about.. the Evap is 54mm Dia.
Yes that would work as there is nothing in the area's around the socket it would hit. It's a bit large tho and will hang over the CPU it self.
__________________
Jinu 2 Stage Cascade
http://www.youtube.com/watch?v=-zDu-Xgt400
Phantom LN2 Pot - First Encounter
http://www.youtube.com/watch?v=dLo7Dr_kR2U
How I cool my benching lab
http://www.youtube.com/watch?v=PLgwW...eature=related
Buckeye is offline   Reply With Quote
Old 09-29-2009, 05:40 PM   #3
sdumper
-100c club
sdumper's Avatar
Man i wish you could sell those evaps cheap here in the us
__________________
http://valid.canardpc.com/show_oc.php?id=606830
Seller/Buyer Reputation:
Heatware: http://www.heatware.com/eval.php?id=50905
Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
sdumper is offline   Reply With Quote
Old 09-29-2009, 06:03 PM   #4
quintus
quintus's Avatar
That's how i thinked about doing the base, something like 5cm diam. for touching the cpu and the rest(that higher ''ring'') of the evap a litle higher to be no problems with caps around the soket area. I'm thinking of making a killer evap lice 7cm in diameter and verry tall too.
The problem is only on the sides of the soket area, usualy parallel with the memory slots, some mobo manufacturers are placing the caps wright next to the soket. A full base without that higher ''ring'' may work on 1366 because of larger cpu.
quintus is offline   Reply With Quote
Old 09-30-2009, 12:20 AM   #5
piotres
-100c Club Member
piotres's Avatar
Yes, I put armaflex tape (adhesive tape) 3mm thick between evaporator sides and enclosure . Really that is not so much space , just bit more than one layer of 3mm thick tape fits there .
One more picutre, so You say that for sure it'll fit everywhere ?
Regards
Peter
Old 09-30-2009, 01:24 AM   #6
Magoa
I am Xtreme
I don’t think it’ll fitt on all boards…. I just measured on my Evga and its awfully close to some caps, the caps are like ~2 are 3mm higher than the socket/cpu IHS.
On Gigabyte for example, the caps are almost against the socket. Think you will have some problems with the metal ring/mount on those.
You could make the evap a bit longer, so you can place the mount(the plastic part incl the metal ring) a bit higher. Then there's always enough space
Are just make the plastic mount a bit smaller and the cut for the metal ring a bit higher…
Magoa is offline   Reply With Quote
Old 09-30-2009, 04:56 AM   #7
quintus
quintus's Avatar
Then we need a bigger difference between the 42mm and the 54mm part.
This difference adds up to the thikness of the evap base so some balance may be needed.
Old 09-30-2009, 09:35 AM   #8
Expat GriZ
Xtreme I am
Expat GriZ's Avatar
Send a message via Skype™ to Expat GriZ
Hhhmmmm...that looks familiar Sorry Pete I'm in the M. East but will have someone I know measure a Classified and get back to you.
__________________
____________________________________________
Lots of very expensive, soon to be obsolete parts!!!
Expat GriZ is offline   Reply With Quote
Old 10-02-2009, 01:09 AM   #9
Magoa
I am Xtreme
I measured on a Classified. It will fit cause the caps are 1mm higher than the socket/IHS. Peter says in his drawing that the bottom and the outside diameter of the evap have a 2mm difference, so it’ll fit on a classified.
Boards like Gigabyte can have some problems cause the have the caps against the socket, maybe it’l fit, but In that case the caps will freeze down to witch of course isn’t a problem
I don’t have a GB anymore so I can’t measure that…
Old 10-02-2009, 07:46 AM   #10
Expat GriZ
Xtreme I am
Expat GriZ's Avatar
Thanks for measuring Magoa!! I was pretty sure it would fit on the Classy. Had my pal back home measure the Classy as well and he figures it will fit. Hope the new 4-way classy has the same layout around the socket. Still waiting for that new Gigabyte board, don't think its out in the wild yet. So Pete, are you going to modify the evap a little or what you see is what you get??
__________________
Old 10-02-2009, 02:20 PM   #11
piotres
-100c Club Member
piotres's Avatar
Thank God it'll fit, Thank Magoa - You roxxx !!! I hope You know that .
@Expat Griz : I think next evaps except this one which is brazed on photo I'll modify on lathe to have 3mm difference between 42mm diam and 54mm diam . I can't cut more because then it'll be too little material under seger ring .
Regards
Peter
Old 10-03-2009, 11:06 AM   #12
Expat GriZ
Xtreme I am
Expat GriZ's Avatar
Regards
Peter
Sounds good Pete, you have PM!!
__________________
Old 10-09-2009, 04:30 AM   #13
tiborrr
-100c Club
tiborrr's Avatar
Send a message via ICQ to tiborrr Send a message via MSN to tiborrr
This evaporator won't fit on Socket-A. Not sure if anyone's still benching them (I know I am) but still - just to let you know.
Best Regards,
Niko
tiborrr is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
