Hey guys... this will be some type of work log with plenty of questions
and some pics
Last computer that I built from the ground up was a pentium 4
(back when HT didn't even exist)
Since then I have been conformed which whatever my company gave me, but now is time to build my own computer!
List of parts so far:
Intel Core i7 920
EVGA classified E760
CORSAIR CMPSU-1000HX 1000W
OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3
ZALMAN CNPS9700 LED 110mm 2 Ball CPU Cooler
EVGA GTX 260
TJ07 (silver)
The idea is to Air Cool it on stage I and later water cool it (stage II)
I also, did some small modifictions while installing everything, like inverting the MB tray, and installing a custom bezel to match the case
THE BUILD:
Test fitting the mb tray upside down (without the rails)
and here with the rails on (there was no way I could fit the top rail)... The bottom rail (which used to be the top rail, had to be reconfigured to be a little taller)
checking the lian li bezel (to see how I was going to fit it)
some cuttings
Test fitting
And here is a quick photoshop of what I'm planning to do once I water cool it
checking the manual
Double checking the manual
Triple checking the manual!!
a couple of adjustment!
Some cable management
I was very unhappy with the lengths of the cables that came on my PSU (CORSAIR modular -1000W)
Does anyone know what would I need to create custom length cables? the 24 was fine, but the 6 pin ones for the video card were to short!!!
