Originally Posted by CedricFP
I wonder if they perform worse seeing as there is a 90 right before pump inlet. I wish the dual DDC one shared water because then I'd get one (shared water means the shared efficiency of all the radiators).
Well if you can find the original (shouldn't be hard), then it is shared. The one I have (original) supports dual-DDCs and has no divider between.
It also doesn't produce any noise that I can tell, though my MCP-355 is on the noisy side regardless. With all my fans going, I don't notice though.
