XtremeSystems Forums
Reply
Old 09-28-2009, 07:00 PM   #1
Titan7171
Thumbs up Watercooling is the :banana::banana::banana::banana:!
So this is the stuff I got
6 x *** NEW *** Bitspower Premium G1/4" High Flow 1/2" Fitting - Black Matte Finish $17.94
10 x Reuseable Clamps - For 1/2" Tubing (3/4" O.D.) - Black $9.90
10 x Tygon 3603 1/2" ID (3/4" OD) Clear Tubing $34.90
1 x *** NEW *** Watercool MO-RA 2 Extreme Performance 9 X 120mm Radiator Core
- Fitting Size: 1/2" OD $124.95
for the above $201 shipped
Enzotech Sapphire $43 shipped
XSPC dual bay res/pump $47 shipped
Set everything up outside the case to test the pump ran it for 30 minutes then went to set up in the case when I took everything apart I saw this inside the block, some black metal pieces prolly from the rad
anyway I cleaned it out and hooked everything up quick
XSPC res/pump is doing a great job even though the MO-RA is restrictive.....Im getting idle temps of 29-31c and load temps of 48c at 1.55v during prime. A quick test of cinebench had it loading at 41c.........with air I was in hitting like 52c and prime was out of the question.
__________________
Phenom 965 BE@4.1ghz
Enzotech sapphire/Mo-Ra extreme rad
Asus M3A79-T Deluxe
ht 2200mhz / nb 2800mhz
2x2gb Gskill ddr1066 5,5,5,15,24,2T
Sapphire 4850x2
Enermax Infinity 650 crossfire
case: XCLIO A380PLUS-BK
4.44ghz air
4.4ghz superpi 1M 15.694
http://s271.photobucket.com/albums/j...1569444ghz.jpg
22,949 06 Phenom 965@ 4.2ghz Sapphire 4850X2@700/1150
13,954 Vantage, Phenom 940 4.1ghz Sapphire 4850X2@700/1180
If I dont get every single drop out of my cpu I feel like someone is stealing from me
Titan7171 is offline   Reply With Quote
Old 09-28-2009, 08:05 PM   #2
Titan7171
heres 30 minutes of prime at 1.55v....windows shows it a bit higher
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-28-2009, 08:23 PM   #3
Titan7171
heres some pics of the stuff
so nothing exciting for you pros but exciting for me Im liking my temps its really unbelievable 4ghz prime stable 1.55v load at 47c. On air Id be hitting 60+c at 1.55v and getting a bsod.
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-28-2009, 08:29 PM   #4
millertime359
Xtreme Mentor
millertime359's Avatar
Nothing wrong with those temps. Figure out what the black stuff was?
Glad your happy with it. The bay looks good all lit up.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is online now   Reply With Quote
Old 09-28-2009, 08:40 PM   #5
Titan7171
The black stuff was metal, I guess from the rad it stuck to my magnetised screwdriver.
Im idling at 28c now and my room temp is 24c 1.5v.
Gonna play some games and see how it does temp wise.
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-28-2009, 08:44 PM   #6
millertime359
Xtreme Mentor
You did flush that rad right? I'm worried there might be some more. It would suck if it got stuck in your pump.
Glad to hear you like it. It wasn't that the pump wouldn't work, just might not be optimal. I would still switch it out if you want to add some GPUs to that loop, but till then enjoy.
BTW, where did you mount that Mo-Ra?
__________________
Old 09-28-2009, 09:57 PM   #7
Titan7171
No I didnt flush it..........I just ran it for 30 minutes while testing the loop outside the case
I did lay it fla and flip it while it was running while trying to get the air bubbles out when testing and trying bleeding the system for the first time.
so maybe that was it?
As for the MO-RA Im not mounting it.......I got lots of tests I got to run before I finalize where or how its going to go.
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-29-2009, 12:05 AM   #8
hewi
In your pics it seems that ur running the MoRa passive, if so ur temps are pretty awesome. Now strap 9 yates to it or 4 x 140mm scythes or something
and u'll see a nice improvement
Now I want a MoRa2 too......
__________________
Intel Q6600 @ 3.6Ghz
Maximus Formula X38
4gb Corsair Dominator DHX
4870X2
Intel X-25M 80gb + 300gb VR
Corsair HX1000w
Samsung 305T+
hewi is offline   Reply With Quote
Old 09-29-2009, 12:39 AM   #9
Titan7171
right now Im running ghetto style.........Im using my dual window fan to blow air at it.
Its right beside my desk
crap photobucket is running maintenance now
The 360mm fan I had here left way to much area open on the rad so I scrapped that idea.
next I might get 4 180mm fans from here http://www.newegg.com/Product/Produc...82E16835220037
and if Im crazy I might do 8 in push pull........I have an idea for a slide on bracket I can make for the Mo-Ra for 8 fans in push pull........but thats $160 plus for 8 fans
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-29-2009, 07:33 AM   #10
jim0ne
Nice work... Nice temps too... makes me want a MoRa
jim0ne is offline   Reply With Quote
Old 09-29-2009, 07:53 AM   #11
Mech0z
Mech0z's Avatar
Send a message via MSN to Mech0z
How is that pump doing? The Mora is known to be abit restrictive and its not the most powerful pump, but if it can take that setup then its awesome enough for me^^
But do you have anyway to meassure your flow?
__________________
Q6600 @ 3800Mhz
Gigabyte EP45-UD3P F4
Asus 8800GTS 512
4 x 1Gb HyperX PC6400 (800Mhz 4-4-4-12)
60Gb OCZ Vertex
24" Dell UltraSharp (2407)
EK Supreme LT
XSPC RX360 @ Yate Loon Medium
XSPC Duel Res with 18W DDC
Mech0z is online now   Reply With Quote
Old 09-29-2009, 09:32 AM   #12
Titan7171
Here the pic...... its Ghetto style
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-29-2009, 09:37 AM   #13
Titan7171
The pump seems to be doing fine.........I dont think Id get these excellent temps if the pump wasnt able to handle the restrictive Mo-Ra.........but its possible that a stronger pump will produce better temps.
But for right now I idle at 28c at 1.58v.......its sick! yesterday I was playing the new NFS at 4.1ghz and the temps didnt break 37c.
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-29-2009, 10:10 AM   #14
bigx333
Wouldn't be better just buy 3 MCP320? :p (and cheaper lol)
bigx333 is offline   Reply With Quote
Old 09-29-2009, 10:24 AM   #15
Johnmark
Wow 4c between room temp. and CPU !, darn near too good to be true. Is that the core temps. your giving us, the lowest of core temps, CPU or? What program are you measuring with?
__________________
Mobo: Asus Rampage Gene II
CPU: i7 920 at 3700 Mhz, NO increased volts anywhere.
GPU: Sapphire 4890 Vapor-X
RAM: G.SKILL Trident DDR3 2000 (PC3 16000) 6x2GB
HD's: 2 Velioci Raptor 300 gig + several others
Blu-Ray Writer: Pioneer BDR-203BK
DVD Scanner: Liteon SHW-165H6S DVD
PSU: Corsair HX1000
Case: Obsidian 800D
GPU Cooling: Ek Water Block CF Acetal Full Cover GPU Block 1/2IN G1/4
CPU Cooling: Heatkiller v3
Water Res: Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir
Radiator: Feser 360
Pump: Swiftech MCP350 with XSPC top
Fittings: Danger Den G1/4 to 3/8IN High Flow Barb Chrome Fittings
Tubing: 3/8" I.D. Tygon
Cooling Water Conditioning: Petra's Tech Shop ,PT-Nuke and Pentosin G11
OS: Windows Vista Ultimate x64
Johnmark is offline   Reply With Quote
Old 09-29-2009, 12:26 PM   #16
Titan7171
thats at 1.5v the spread increases as I raise the voltage I will show my stock voltage temps in a bit
Im using cpuid HWmonitor,coretemp and AMDOD........Ive been trying out win7 and AMDOD doesnt run on it?\
anyway...heres a pic of my room temp and cpu temp at stock voltage
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-29-2009, 02:21 PM   #17
millertime359
Xtreme Mentor
Sweet setup dude.
__________________
Old 09-29-2009, 03:23 PM   #18
Titan7171
Sweet setup dude.
why you laughing man.......my window fan?
I will hook it up soon.
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-29-2009, 03:41 PM   #19
Titan7171
Originally Posted by bigx333 View Post
Wouldn't be better just buy 3MCP320 ? :p (and cheaper lol)
how is 3x$50 MCP320 rads cheaper than $125 I paid for the Mo-Ra? then I got to worry about 6 rad connections instead of 2....nah much better like this.
Isnt it the MCR320...?
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-29-2009, 04:02 PM   #20
millertime359
Xtreme Mentor
I like it though. Way to use what you got.
__________________
Old 09-29-2009, 04:31 PM   #21
Titan7171
haha yea man.....the fans I want are $22 each and Im gonna need at least 4
You know that desperate feeling to try something no matter what you have to do to accomplish it......thats the way I felt about this watercooling setup
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-29-2009, 04:57 PM   #22
bigx333
IIRC, if you want to use fans you need to buy the exhaust screen which is more $49.95 (totalizing $174.90), you can get 3 MCR320 for $149.85 and they should be less restrictive, already ready to get fans, accept push n' pull, etc.
But I'm not sure if they would have better performance with the same number of fans and connecting the rads would be a bit tricky .
BTW, your temps are wonderful .
Old 09-29-2009, 05:20 PM   #23
millertime359
Xtreme Mentor
If your going to back a rad cluster like the Mo-Ra, you would probably needsome BP fittings and d-plugs to interconnect it. You could do it with tubing, but think the hard line would look nicer. This will probably get you close to the $175. Then you would also need a bracket to connect the 3 rads together. (Once again comparing it to the Mo-Ra and his build).
I think the price tag is a bit closer than you think. NTM, you probably could make a bracket for the fans that will cost less than the $50.
__________________
Old 09-29-2009, 05:46 PM   #24
Titan7171
I didnt get the screen because I really dont want 9 120mm fans.....18 in push pull
Thanks Im loving the temps also!
The plan is to make a custom bracket to mount 4x180mm fans.....Ill post pics once I get started on it.
Im wondering how my temps compare to others running just a cpu loop.....but thats prolly rare except for other beginers
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-29-2009, 06:16 PM   #25
millertime359
Xtreme Mentor
Well, it is hard to compare seeing you do have different varibles at play. Just be confident that they are great temps. If you do plan on adding GPUs, you probably should keep a pump upgrade in the back of your mind. You could always add it and see how the temps are. You should have enough rad space for a couple of GPUs. You might be testing the pump there though.
Once again, Great job.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
