1) Normal ES: Available to partners and press before the product actually launches. These are usually close to retail parts, maybe one stepping/node before retails. From my experience (I've had access to AMD & Intel ES CPUs before the official launch around 8 years) normal ES CPUs are actually usually worse than retails because manufacturing process develops all the time and retails keep getting better. Every Phenom II press sample (not even marked as ES but couple weeks earlier than retail parts) I've tested so far have been worse than normal retails.
Should Be, it is used to cool very large server rooms/data base centers......it has a very high capacity......If i had to scale it lets say you could replace your Central air in your house and freeze yourself out.
For $4,600 USD.....it better.
Debating on what to do with it atm.....would make a sweet chiller.....If i sell it ( it's new with a couple scratches ) I can also have my other chiller reworked with the funds.
If you acquired that for far less than retail I'd try to resell it for close to retail. You'd barely be able to put a dent into that thing's capacity with AMD
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
I was commissioned to remove destroy it by APC when I delivered a non scratched one....the rich people refused delivery due to a scratch ( not done by me ).
That said I have nothing invested.....actually I was paid to remove it..
You obviuosly don't know me that well....how much you want to bet I could have this and vents and ducts all installed in a day in my house It can sit in the basement, no need to be outside. I can control via software and ethernet from my pc up stairs.......
