XtremeSystems Forums
Reply
Old 09-28-2009, 10:01 AM   #1
dnottis
Xtreme Mentor
dnottis's Avatar
Anyone watercooling a HD5870 yet?
I've got a Fuzion, just wondering if the holes use the standard mounting ATI holes or if they are different this generation?
Thanks!
__________________
Q9550 @ 4.003 Ghz
Gigabyte P45 UD3P F4
G.Skill PC2-8800 DDR2-1100 8GB Memory
1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, D-Tek FuZion pro mounted, FuZion GFX 2
Cooler Master UCP 1100 Watt PSU
MSI HD5870 1Ghz (1.16v), 1300Mhz
Lian Li PC V-2000
Acer X222Wbd 22" LCD
3 x WD 640GB WD6400AAKS HD
Pic of my watercooled rig
dnottis is offline   Reply With Quote
Old 09-28-2009, 10:52 AM   #2
Eddy_EK
Xtreme Enthusiast from EK
Eddy_EK's Avatar
Hi!
Holes are standard Radeon.
We will have complete block for final test tomorrow.
__________________
Originally Posted by creidiki
EKs are like waterblock pr0n
Eddy_EK is offline   Reply With Quote
Old 09-28-2009, 12:41 PM   #3
dnottis
Xtreme Mentor
dnottis's Avatar
Originally Posted by Eddy_EK View Post
Hi!
Thanks Eddy! I was just hoping I could use my Fuzion GPU block for now. Looks like I can... Full cover would be nice in the future.
__________________
Q9550 @ 4.003 Ghz
Lian Li PC V-2000
Old 09-28-2009, 12:47 PM   #4
jadeskye
jadeskye's Avatar
damn you work fast eddy. bravo!
__________________
"If we hit that bullseye, the rest of the dominos will fall like a house of cards. Checkmate."
jadeskye is offline   Reply With Quote
Old 09-28-2009, 02:29 PM   #5
lesstutrey
lesstutrey's Avatar
Send a message via AIM to lesstutrey
I guess we figured out who is winning the race for first full cover. Good job eddy.
__________________
Cooling:
Custom SS made by RunMC of under-the-ice.com
80L Cryofab CL80 Dewar
Otternase EEAL.CU
Tried: e8400,q6600,qx9650
Subzero queue: AMD Athlon 64 3000+,3200+,3500+ winchester, 3500+ newcastle, 3500+ Orleans, 3700+, 4000+, 4200x2+ & DFI LP Ultra
Intel P4: 520, 631
w3550+Bloodrage GTI,
asus commando
Inbound: sdumper SS
lesstutrey is offline   Reply With Quote
Old 09-28-2009, 02:47 PM   #6
BlueAqua
I am Xtreme
BlueAqua's Avatar
I hope we don't pressure manufacturers to rush a product. I'd much prefer to wait a few weeks for a higher quality and more thoroughly tested product. Now if they can accomplish that right off the bat, kudos to them. Waiting for new stuff is about half the fun anyways.
BlueAqua is offline   Reply With Quote
Old 09-28-2009, 02:51 PM   #7
JoeBar
Xtreme Mentor
JoeBar's Avatar
After so many gpu blocks Eddy has gained a lot of experience, so new blocks come faster...
__________________
Asus Maximus II Formula
Intel Core2 Duo E8400 E0 Q828A Malay @ 4.50GHz (8.5 X 530mhz) WC'ed
2 x 2GB Mushkin XP2-8500 @ 1060MHz (5-5-5-15)
Asus 4870X2 @ 850/950MHz WC'ed
150gb Western Digital Velociraptor | 2 x 320gb Western Digital Caviar SE16 sataII
SoundBlaster Audigy4 | Logitech Z-5500 | LG W2600HP 26" TFT
MountainMods UFO | Zalman ZM-850HP psu
Watercooling setup:
1st loop -> Radiator: ThermoChill PA 120.3 | Pump: Laing DDC Ultra with Alphacool top | CPU: Swiftech Apogee GTX CU |Chipset: Swiftech MCW-NBMAX | Tubing: PrimoFlex 1/2" Pro LRT
2nd loop -> Radiator: Swiftech MCR-220 | Pump: Laing DDC Pro with Alphacool top |GPU: EK FC-4870X2| Tubing: PrimoFlex 1/2" Pro LRT
JoeBar is offline   Reply With Quote
Old 09-28-2009, 03:58 PM   #8
LC_Nab
LC_Nab's Avatar
Send a message via MSN to LC_Nab
Ill have 2 !!! mmm make it acrylic
__________________
LC_Nab is offline   Reply With Quote
Old 09-28-2009, 05:15 PM   #9
millertime359
Xtreme Mentor
millertime359's Avatar
Well yea, but the final release of the GPU card does help. That way you know there aren't any surprises.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is online now   Reply With Quote
Old 10-02-2009, 06:09 AM   #10
dnottis
Xtreme Mentor
dnottis's Avatar
anyone yet using a core block setup yet on one of these? MCW60? Fuzion GFX?
__________________
Q9550 @ 4.003 Ghz
Lian Li PC V-2000
Old 10-02-2009, 06:19 AM   #11
flopper
flopper's Avatar
Tuesday for me.
I get card on monday.
Its a 5850 but I assume a mcw50 will fit fine.
__________________
Intel i7 i920 4.2ghz 1.4200v ekwater supreme -GA UD5 [F9e] - His 5850 940/1100 24/7 - Kingston valueram 6x1gb cl9 - a-data ssd 3x32gb raid0 Areca 1210 - 22inch Lenovo 220x - haf932 - Corsair 750w-watercooled ekwaterblock-sennheiser hd600 headphones - Asus essence stx - Razer deathadder and G15 - 18k Vantage (40/60c -) WarHammer Rune priest (one of the 26% that isnt confused on xtreme forums)
flopper is offline   Reply With Quote
Old 10-02-2009, 06:29 AM   #12
BrokenArrow
BrokenArrow's Avatar
Hi!
Looks like the Maze4 will be able to be used as well.
BrokenArrow is offline   Reply With Quote
Old 10-05-2009, 01:08 AM   #13
Eddy_EK
Eddy_EK's Avatar
http://www.xtremesystems.org/forums/...&postcount=108
__________________
Old 10-05-2009, 05:28 AM   #14
dnottis
Xtreme Mentor
dnottis's Avatar
http://www.xtremesystems.org/forums/...d.php?t=235947
__________________
Q9550 @ 4.003 Ghz
Lian Li PC V-2000
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
