XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 09-28-2009, 02:24 AM   #1
pump101
pump101's Avatar
Vapochill XE repair - UK
hi, if i have posted in this in the wrong place, apologies.
i have an old vapochill xe that i'd like to get up and running again. looking for anywhere in the UK to get it repaired?
thank you :-)
__________________
VAPOCHILL LIGHTSPEED (MODDED BY GRAY MOLE)
LIAN LI PC 60
INTEL E6420 @ 3GHZ
BFG 680I
80gb Seagate SATA
3 x 15K 18.2gb SCSI DRIVES (ADAPTEC 39160 U160 HBA)
3 x OPTICAL DRIVES
XFX 6800GS
pump101 is offline   Reply With Quote
Old 09-28-2009, 03:15 AM   #2
MeltedDuron
Dothan FTW!
MeltedDuron's Avatar
Send a message via AIM to MeltedDuron Send a message via MSN to MeltedDuron Send a message via Yahoo to MeltedDuron
Really not worth it. They are a poor unit and are 12v. You'd be better off with a 240v compressor and having something custom built. There are builders in the UK but not sure who would build for you as a lot do DIY only. Go to Benchtec and ask there. Evo or Dualist might help
__________________
.:Melted's Hardware:.
.:My Workstation::Sorta Done:.
.:Intel E4300@3ghz(375*8):2gb G.Skill HZ 6400@500mhz:Sapphire X1950pro:Gigabyte GA-G33M-DS2R:550w FSP Blue Storm:80gb and 160gb WD SATA2:Cheap MATX Case:.
.:Panasonic Toughbook CF-T2:.
.:Pentium M 753 (900mhz ULV):256MB:40GB:12.1" Touchscreen:. .:Not too shabby for a 2.4lbs of pwn:.
I've been using Intel ever since AMD put an end to my socket A fun. I was almost going to go back when I saw the cheap AM2 chips, but they suck Viva La Chipzilla!
MeltedDuron is offline   Reply With Quote
Old 09-28-2009, 06:04 AM   #3
Buckeye
Phantom is here :)
Buckeye's Avatar
These units would work great for Core I5 systems.
__________________
Jinu 2 Stage Cascade
http://www.youtube.com/watch?v=-zDu-Xgt400
Phantom LN2 Pot - First Encounter
http://www.youtube.com/watch?v=dLo7Dr_kR2U
How I cool my benching lab
http://www.youtube.com/watch?v=PLgwW...eature=related
Buckeye is offline   Reply With Quote
Old 09-29-2009, 02:09 AM   #4
pump101
pump101's Avatar
thanks for quick response guys.
not really looking for a super cooling unit. the XE is pretty much more than adequate for my needs.
i really like the look of the xe and it really does make a nifty beast-looking case!!
looking forward to getting more responses!!
thank you
__________________
LIAN LI PC 60
INTEL E6420 @ 3GHZ
BFG 680I
80gb Seagate SATA
3 x OPTICAL DRIVES
XFX 6800GS
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
