XtremeSystems Forums
Reply
Old 09-28-2009, 01:09 AM   #1
Titan7171
Home remedy for biocide for short term use?
I forgot to order biocide and the last parts of my watercooling is coming tomorrow. Is there anything I could use for the short term to add to the distilled water to prevent any growth?
__________________
Phenom 965 BE@4.1ghz
Enzotech sapphire/Mo-Ra extreme rad
Asus M3A79-T Deluxe
ht 2200mhz / nb 2800mhz
2x2gb Gskill ddr1066 5,5,5,15,24,2T
Sapphire 4850x2
Enermax Infinity 650 crossfire
case: XCLIO A380PLUS-BK
4.44ghz air
4.4ghz superpi 1M 15.694
http://s271.photobucket.com/albums/j...1569444ghz.jpg
22,949 06 Phenom 965@ 4.2ghz Sapphire 4850X2@700/1150
13,954 Vantage, Phenom 940 4.1ghz Sapphire 4850X2@700/1180
If I dont get every single drop out of my cpu I feel like someone is stealing from me
Titan7171 is online now   Reply With Quote
Old 09-28-2009, 01:53 AM   #2
alacheesu
You could pick up some biocide from a pet store. I bought a bottle containing copper sulfate pentahydrate (same as used in PT Nuke). I've been running distilled water with a drop of that for a year now. No growth or other problems. Just don't add too much.
Alternatively you can steal some silver jewelry from a loved one and put that in your loop.
alacheesu is offline   Reply With Quote
Old 09-28-2009, 01:55 AM   #3
Titan7171
awsome theres a pet store near by
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-28-2009, 10:18 AM   #4
NaeKuh
Post Soapbox Destruction
NaeKuh's Avatar
2 drops of iodine will do it also.
__________________
Nadeshiko: *Undergoing Rebuild*
Haruhi: i7 975 12GB DDR3 eVGA Classified *Haruhi -> Nadeshiko*
Lind: Dual Gainestown 3.07
NaeKuh is offline   Reply With Quote
Old 09-28-2009, 10:28 AM   #5
SoulsCollective
Xtreme Cruncher
SoulsCollective's Avatar
Bleach. Been using it for years.
You want actual bleach, though, not cleaners that contain bleach, as those will cause your loop to foam up.
__________________
Rig specs
CPU:
i7 920 @ 3.8GHz Mobo: eVGA Classified 760 RAM: 3x2GB OCZ DDR3-1866 Reapers @ 1,800, CAS-8 VGA: Sapphire HD5870 @ Core 900 Mem 1,250
HDD: 6x WD6400AAKS in RAID-6 powered by Highpoint RocketRaid 3520 SFX: Auzentech X-Fi Prelude
PSU: Corsair HX-1000 Case: Silverstone TJ-09 modded for WC OS: Win7 RTM x64
Liquid-cooled
Sub-loop One
: EK-Supreme -=- MCR320, 3x Scythe S-FLEX "F" fans -=- 7/16" Pro-LRT -=- 7/16" BP compressions-=- MCP655 w. Typhoon III
Sub-loop Two: EK Classified FC -=- 2x MCR120, Scythe S-FLEX "F" fans -=- 7/16" Pro-LRT -=- 7/16" BP compressions-=- MCP655 w. Typhoon III
Peripherals
Dell 2408WFP rev.A01 -=- Audio Technica ATH-AD1000 -=- Razer Mamba -=- Microsoft "Natural Ergonomic 7000" keyboard -=-
Foundational Falsehoods of Creationism
SoulsCollective is offline   Reply With Quote
Old 09-28-2009, 10:30 AM   #6
NaeKuh
NaeKuh's Avatar
that will stain your tubing yellow also.
But yes, chlorine of some form will do it.
__________________
Old 09-28-2009, 12:55 PM   #7
Flip_Lx
Flip_Lx's Avatar
Send a message via AIM to Flip_Lx
antifreeze
__________________
Q9450 @3.4 (for now)
Asus P5Q-E
8gb Corsair XMS
Asus 4830 700/1184
Corsair HX520
D-Tek Fuzion V2 w/ quadplate+MCR220+DDC3.1w/XSPC restop
Flip_Lx is offline   Reply With Quote
Old 09-28-2009, 01:18 PM   #8
millertime359
Xtreme Mentor
millertime359's Avatar
If it is just going to be a week or 2, and you are going to get silver or something other than PT Nuke. You should be able to get away with straight distilled.
If you were wanting to use PT Nuke, then the pet store biocide is same thing.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 09-28-2009, 02:22 PM   #9
lesstutrey
lesstutrey's Avatar
Send a message via AIM to lesstutrey
Like Naekuh, i use povidone iodine, a trick i learned from mycology. couple drops last a loops lifetime. Pick it up at your local drugstore next to alcohol and hydrogen peroxide
__________________
Cooling:
Custom SS made by RunMC of under-the-ice.com
80L Cryofab CL80 Dewar
Otternase EEAL.CU
Tried: e8400,q6600,qx9650
Subzero queue: AMD Athlon 64 3000+,3200+,3500+ winchester, 3500+ newcastle, 3500+ Orleans, 3700+, 4000+, 4200x2+ & DFI LP Ultra
Intel P4: 520, 631
w3550+Bloodrage GTI,
asus commando
Inbound: sdumper SS
lesstutrey is offline   Reply With Quote
Old 09-28-2009, 02:45 PM   #10
Otter
Originally Posted by Flip_Lx View Post
antifreeze
Antifreeze will kill animals with kidneys (like us), but it's not an effective biocide. The reason algae doesn't grow in your car's cooling system is that the coolant gets killing hot every time you drive, and there is no light. And if you're lucky, you can run without a biocide at all, which gives the illusion that antifreeze is killing off the microbes. But I wouldn't rely on it.
Otter is offline   Reply With Quote
Old 09-28-2009, 02:50 PM   #11
BiNGE
Colloidal Silver water. It's safe to ingest, kills bacteria/algae, and is simply distilled with microscopic silver particles which do not result in sediment. A warning is that it's slightly more conductive than regular distilled water, but it will have no adverse effect on temps. It can be used short or long term. I make my own in my basement next to the rum
BiNGE is offline   Reply With Quote
Old 09-28-2009, 06:15 PM   #12
Titan7171
Thanks for all the replies lots of ideas... I got iodine and clorox bleach here now .....
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-29-2009, 10:34 AM   #13
Johnmark
I hope you used the idodine!
If you used bleach (I wouldn't) check the ph of your loop. If it's over 8 get it out of your loop before you damage the metal.
__________________
Mobo: Asus Rampage Gene II
CPU: i7 920 at 3700 Mhz, NO increased volts anywhere.
GPU: Sapphire 4890 Vapor-X
RAM: G.SKILL Trident DDR3 2000 (PC3 16000) 6x2GB
HD's: 2 Velioci Raptor 300 gig + several others
Blu-Ray Writer: Pioneer BDR-203BK
DVD Scanner: Liteon SHW-165H6S DVD
PSU: Corsair HX1000
Case: Obsidian 800D
GPU Cooling: Ek Water Block CF Acetal Full Cover GPU Block 1/2IN G1/4
CPU Cooling: Heatkiller v3
Water Res: Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir
Radiator: Feser 360
Pump: Swiftech MCP350 with XSPC top
Fittings: Danger Den G1/4 to 3/8IN High Flow Barb Chrome Fittings
Tubing: 3/8" I.D. Tygon
Cooling Water Conditioning: Petra's Tech Shop ,PT-Nuke and Pentosin G11
OS: Windows Vista Ultimate x64
Johnmark is offline   Reply With Quote
Old 09-29-2009, 11:14 AM   #14
Titan7171
you see this is the type of info that helps people....lucky I didnt run and put the bleach in.
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-29-2009, 12:29 PM   #15
Johnmark
Thanks.
One thing I've noticed with computer water cooling enthusiasts is that they are into computers and have limited knowledge about water chemistry.
Did you guys realize that water chemistry is a engineering disciple of it's own? Yup guys go to school for many years just to understand how water behaves under various conditions.
I'm fortunate to be working in the Petrochemcial industry (for MANY years) where we see all kinds of problems with various water systems. Closed loop and otherwise. And we still see surprises that cause the experts to scratch their heads then head off to the Labs using sophisticated analysis to figure out what is happening. In a large plant millions of $$ damage can occur within a few hours of a water excursion. And we don't always's know what caused it, this is with several experts working on the problem!
One common misconception I see here frequently is that algae will not grow unless it has light. WRONG, it will grow just fine, even when using distilled water!
Anyway that my two bits worth
__________________
PSU: Corsair HX1000
Case: Obsidian 800D
Radiator: Feser 360
Old 09-29-2009, 12:33 PM   #16
Titan7171
Thanks.
Thats awsome, so can I use just the iodine or should I go and buy the biocide?
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-29-2009, 05:22 PM   #17
Johnmark
Personally I'd buy the biocide (Copper Sulfate) and mix 2 drops into 1 liter of water. That will give you about 1 ppm of of Copper Sulfate in solution, which will kill most bugs.
I don't know how much Iodine is needed to kill bugs and have never heard of it used in a water loop. Not to say it can't be, just not used in industry.
__________________
PSU: Corsair HX1000
Case: Obsidian 800D
Radiator: Feser 360
Old 09-29-2009, 05:25 PM   #18
NaeKuh
NaeKuh's Avatar
thats called cyanbacteria ...
http://en.wikipedia.org/wiki/Cyanobacteria
its not really an algae... And it can grow in almost no light...
Real Algae needs light to grow. Otherwise no photosynthesis, which means no growth.
Which is also why it never grows in black tubing.
Use 2 drops for now... and then try to add silver as soon as possible.
http://www.petrastechshop.com/sikibyia.html
OR
http://www.jab-tech.com/Bitspower-Tr...1-pr-4397.html
__________________
Old 09-29-2009, 05:37 PM   #19
BiNGE
NaeKuh is right about the silver and algae not being able to grow in light. I don't like those kill coils or fittings because of the silver oxidizing. It completely ruins the anti-microbial properties of the silver once it starts to form a hearty tarnish.
Old 09-29-2009, 09:44 PM   #20
Computurd
Computurd's Avatar
Mouthwash
__________________
"Lurking" Since 1977
Computurd is online now   Reply With Quote
Old 09-29-2009, 09:49 PM   #21
NaeKuh
NaeKuh's Avatar
Originally Posted by Computurd View Post
Mouthwash
has alcohol.
Need we remind u what alcohol does to acrylic?
__________________
Old 09-29-2009, 10:00 PM   #22
Computurd
Computurd's Avatar
not in a concentrated form. One teaspoon per gallon of distilled water is something i have seen around...
should have been more clear i guess
__________________
Old 09-29-2009, 10:03 PM   #23
NaeKuh
NaeKuh's Avatar
not in a concentrated form. One teaspoon per gallon of distilled water is something i have heard around...
really?
because this is new to me...
Well alcohol ends up drying the acrylic...
I can understand while in solution but what happens after u drain?
The acrylic will dry out from the alcohol and the result is a crack, or many many micro cracks which look very ugly.
Are you sure its okey in mouthwash? because the alcohol concentration is 20% in most mouth washes.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
