XtremeSystems Forums
Reply
Old 09-27-2009, 09:47 PM   #1
adskiracerad
Gtx 295 What is the best water block?
I have a BFG GTX295 http://www.newegg.com/Product/Produc...-192-_-Product i was wondering what the best water block would be i was thinking EK-FC295 http://www.performance-pcs.com/catal...ducts_id=25902 if there is somting better please show me the light lol.
adskiracerad is offline   Reply With Quote
Old 09-28-2009, 12:14 AM   #2
eponymous
eponymous's Avatar
http://www.koolance.com/water-coolin...product_id=857
This is the block I'd buy. I can't say one is better than the other though as I've not got a 295 I bought the Koolance blocks for my 285's however and they're great.
__________________
[Project] : Altair | A Lian-Li PC-P80, dual loop, all internal build.
Hardware
Core i7 920 D0 | Corsair Dominator 1600MHz CL8 RAM | 2x EVGA GTX 285 SLI | ASUS P6T Deluxe V2 | ASUS Xonar D2X
2x Intel X-25M SSD | WD RE3 1TB (WD1002FBYS) | Corsair HX-1000W | Lian-Li PC-P80 | Dell 3008WFP 30"
Watercooling Gear (Dual Loop)
Koolance 350AT (CPU Loop) | 2x Koolance VID-NX285 (GPU Loop) | 2x Laing DDC 3.2 / XSPC Acrylic top Rev. 3 | 2x EK Multioption 150 Res Ver. 2 | 2x Thermochill PA 120.3 |
6x Scythe S-Flex 1200 RPM Fans | 7/16" Primochill Pro Green LRT | 7/16" Primochill Pro Blue LRT | B.P. Silver Shiny 1\2" Barbs | Alphacool Ball Valve / B.P. M-M Rotary fill-port / drain | Bitspower Black Freezer AIX58NS NB/SB (GPU Loop)| Black Freezer MOS AMOSII POM Version (GPU Loop)| Bitspower Black Freezer MOS AMOSIII POM Version (GPU Loop)
eponymous is offline   Reply With Quote
Old 09-28-2009, 04:01 AM   #3
millertime359
Xtreme Mentor
millertime359's Avatar
Most of the gpu blocks seem to preform pretty close to each other. Iwould get whichever you like the best.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 09-28-2009, 09:13 AM   #4
Aphellyon
Aphellyon's Avatar
Yea, I'm trying to decide on this as well for my 2x 295s. Koolance, EK or swiftech? Tuff decision that.
http://www.performance-pcs.com/catal...ducts_id=25772
Koolance looks pretty cool and comes with a back plate. I think you can see the coolant (if colored) through the logo cutouts on the front plate. I'd really love to see how this one looks mounted and/or lighted. Anybody got any pics out there?
EK also looks pretty cool, but I think you have to buy the back plate seperately (if you want one). Did they fix their problem with poor standoffs, or was that just an issue with the dual PCB cards? Again, I'd love to actually see some good pics of this mounted... anybody out there with some decent snappys?
http://www.performance-pcs.com/catal...ducts_id=25949
The swiftech one... also cool, but perhaps not as much as EK's. Plus, I don't think it has a back plate option at all, (could be wrong on that).
*sigh* decisions, decisions....
Aphellyon is offline   Reply With Quote
Old 09-28-2009, 09:46 AM   #5
adskiracerad
lol i agree. that was a great post you did thanks very much! im in the same boat as you!! Im tempted to try and get a hold of Heat killer and ask if they have a singe board 295 water block coming soon or i just might go for the EK. Thanks very much tho for your post.
Old 09-28-2009, 09:46 AM   #6
Ketzer7
Ketzer7's Avatar
FYI, gabe @ Swiftech commented somewhere on these boards that their 295 block reuses the backplates that come on the 295, so it does have one just to clarify what you said.
I'm not sure about EK's block reusing the stock backplates or not, maybe Eddy can comment that. EK's upside is that they also offer an FC block for the back of the board that mates together with the front and still allows you to maintain a single inlet/outlet config on it.
Like millertime said, just pick whichever you one you think you like best.
Ketzer7 is offline   Reply With Quote
Old 09-28-2009, 10:11 AM   #7
Edward88
BP also have one for 295 too.
All perform well, like everyone said, just pick the one you like more
Edward88 is offline   Reply With Quote
Old 09-28-2009, 10:56 AM   #8
MaByBoI
Xtreme Cable Management Freak
MaByBoI's Avatar
personally i love the look of the swiftech epsilon block, does anyone have any pictures of the back plates of the other water blocks? i like how the swiftech block keeps the original backplate, does anyone have a picture of that backplate of the ek block? i need to buy one for my EVGA gtx 295 some time this week.
__________________
Blood(Rage) shall be spilt
Intel Core i7 | Enzotech Sapphire
EVGA GTX 295 co-op | Swiftech Epsilon
Foxconn BloodRage | BloodRage Waterblock
OCZ Platinum 6gb DDR3 | GTX 480 QUAD rad
Corsair HX1000W | MCP 655
Silverstone TJ-07 | FrozenQ T-Virus Res
WD 1TB Black | Distilled Water
I also have a Macbook Air
MaByBoI is offline   Reply With Quote
Old 09-28-2009, 11:36 AM   #9
adskiracerad
i agree some pics of the blocks with back plates would be awesome. i also am going to be buying a block this week along with a solid state drive any have a recommendation on one of those
Old 09-28-2009, 12:06 PM   #10
MaByBoI
MaByBoI's Avatar
well i have found out that for me, the swiftech epsilon is the only block available at directcanada.com, and its 30$ less than everything else. so im quite content
__________________
Old 09-28-2009, 12:06 PM   #11
Aphellyon
Aphellyon's Avatar
Here's the EK back block... pretty slick... but pricey for ~125 bucks.
Like Ketzer said, the swifty block uses the existing back plate.
And to round it off... Koolance comes with this back plate... which looks a bit more stealthy than stock.
Yea, I just didn't like that one as much as the others, (wouldn't mind seeing it all mounted up with the black sparkle rotories on there though)
Old 09-28-2009, 12:13 PM   #12
Aphellyon
Aphellyon's Avatar
Hmmm.... SSDs.... anything with the Indilinx/Intel controller... OCZ Vertex comes to mind... avoid ones with older JMicron controllers.
Useful linky vv
http://www.pcper.com/article.php?aid=736
Old 09-28-2009, 12:14 PM   #13
MaByBoI
MaByBoI's Avatar
im sure the koolance back plate could be used on the swiftech block? makes it look a little bit nicer
__________________
Old 09-28-2009, 12:23 PM   #14
Aphellyon
Aphellyon's Avatar
Heh, maybe... I think you'd have to buy the KL full block to get it though. Anyway, I'm not sure how the Swifty block "fastens" to the existing stock plate. But, I agree, the KL back plate does look better... I have an open case, so the backs of these cards will need to be stealth'd as much as possible.
rear shot of a swifty mount vv
Old 09-28-2009, 12:49 PM   #15
MaByBoI
MaByBoI's Avatar
yeah i think it would look really nice with the koolance backplate on there, i hate seing the back of the pcb on my cards, after i put so much effort into everything else..
__________________
Old 09-28-2009, 01:26 PM   #16
Aphellyon
Aphellyon's Avatar
Sorry OT: How's your t-virus res hold'n up? I've been waiting on mine forever.
Old 09-28-2009, 01:57 PM   #17
adskiracerad
wow this is a really great thread guys. im staring to think i want to go with the Koolance water block i love the back plate.
Also here is a link to my build log
http://www.xtremesystems.org/forums/...50#post4024650
Old 09-28-2009, 02:05 PM   #18
MaByBoI
MaByBoI's Avatar
havnt got it yet, still waiting. just like you
__________________
Old 09-28-2009, 02:40 PM   #19
Aphellyon
Aphellyon's Avatar
Heh, I'm at the point now where I think I'll just slap a coupl'a coke bottles on my rig'n lite'em up with some glow sticks. I feel your pain bro.
Cool beans.
Sub'd your log... nice start, by the way. Reminds me, I need to get my sleeving ordered. I noticed you have a 260 in there... you got your 295 stashed away somewheres?
Old 09-28-2009, 02:57 PM   #20
justin.kerr
I am Xtreme
justin.kerr's Avatar
I really like the Swiftech blocks.
Build is in progress, so dirty, lol,fingerprints, and my photo skills resemble a geriatric orgy, but they do perform very well, very easy install, have had no problems with these blocks.!
__________________
MM Ascension case,
Classified, 920 @ 4.6Ghz,
(2) toxic 4890's @ 1000,
Mushkin redline ascents 6gb, 1768 Mhz 7-7-6-19
(8) intel x25m RAID 0 on LSI 9260
heat killer, 2 swiftech mcr 320's, feser 360, Xspc Rx360, EK full coverage MB WB. 655 with detroit top, 355 with Xspc top
justin.kerr is offline   Reply With Quote
Old 09-28-2009, 04:17 PM   #21
MaByBoI
MaByBoI's Avatar
those blocks are SOOO nice!, thank god im buying one
__________________
Old 09-28-2009, 04:29 PM   #22
justin.kerr
I am Xtreme
been able to run vantage with 730Mhz on the core on both 295's, temps with Vantage run 40C-45C.
__________________
MM Ascension case,
Old 09-28-2009, 05:15 PM   #23
MaByBoI
MaByBoI's Avatar
*sigh* i just bit the bullet and bought a swiftech epsilon. beautiful block. but 160$ CAD...
__________________
Old 09-29-2009, 08:46 AM   #24
Aphellyon
Aphellyon's Avatar
@Justin: Thanks for the post... very nice.
Anybody want to share some KL, or EK snappys? (guess I could dig through the work log section)
Old 09-29-2009, 09:36 PM   #25
Aphellyon
Aphellyon's Avatar
How's your gaming with quad sli going... any stuttering or other issues?
EDIT: Ahh... never mind, I just noticed you still working on the build.
Also, what voltage are you pushing to hit 4.6 on your 920?
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
