09-27-2009, 06:53 PM
#1
Obsessed Member
Cutting holes for Rads
I found a clean way of making holes for rads. If you happen to be an Electrician/Modder like me, or know one. You can use a 4" knockout punch to make 120mm holes for fans.
Cutter and sleeve.
Hydraulic pump/draw stud
Test fit
Perfect
Some of you may have already known this, but for those that didn't, just thought I'd share. ; )
btw, the 3" cutter works perfect for 92mm fans
__________________
wEeViL
Browser: Intel QX9650 (3.0GHz) @ 3.6 | Water Cooled by Swiftech | Asus P5E3 Deluxe | 4GB Corsair Dominator DDR3 SDRAM 1800 | eVGA GTX 285 SSC | Customized Lian Li B25B | Antec Signature SG850 PSU | Windows 7 64 RTM
Gamer: Intel i7 920 (2.66) @ 4.0 | Water Cooled by Swiftech | ASUS Rampage 2 Gene | 6GB Corsair Dominator 1866 GT's | 2xGTX 280's | Banchetto 101 Bench Table | Antec Signature SG850 PSU | Windows 7 RC1 x64 Ultimate
09-27-2009, 07:13 PM
#2
Nice work, thanks for sharing, could come in handly for my next build
09-27-2009, 07:58 PM
#3
Hole saws also work.
09-27-2009, 08:08 PM
#4
Obsessed Member
Originally Posted by
faster3200
Indeed they do, but much messier.
__________________
wEeViL
09-27-2009, 08:27 PM
#5
where can u get one of those punch anyway??
09-27-2009, 08:37 PM
#6
09-27-2009, 08:48 PM
#7
Obsessed Member
Kanzy
This one
http://www.toolup.com/greenlee/7310sb.html is similar to the one I have, but they do make non-hydraulic ones that would less expensive, or make friends with an electrician ; )
__________________
wEeViL
09-28-2009, 05:56 AM
#8
Seems the single 4" is gonna prove hard to find, and then it is gonna be over $100..... Good method, just damn expensive......
__________________
Gigabyte X58 UD4P
I7 920@3.8
12gb Gskill DDR3/1200
4850X2 x2
2 120gb seagate 2.5 drives (raid 0)
4 160gb seagate 3.5 drives (raid 0)
X-Fi Titanium
Custom watercooling setup
(proc,chipset,vid cards)
Windows7 Ultimate X64
09-28-2009, 06:32 AM
#9
Obsessed Member
I got my 4" cutter and die for $79 on ebay, I've had the pump and draw stud for years.
BTW, the actual cutter size is 4 1/2", but thats what you cut for a 4" conduit fitting.
__________________
wEeViL
09-28-2009, 09:59 AM
#10
I am Xtreme
I've always preferred this method but it's far too rich for my liking.
http://www.grainger.com/Grainger/items/4A752
I'll either stick with my hole saws or maybe try to make my own slug punches.
__________________
09-28-2009, 10:13 AM
#11
Post Soapbox Destruction
what happened to the good old days and dremel
30 dollar dremel + swiftech template.
accidentally cut too close tho...
not to sound mean or anything...
but asking people to buy 600 dollar punches, and 1000 dollar pneumatics... is kinda silly just to punch holes for rads.
@ that cost, id rather send my case out to bei and he would laser cut/scribe me anything i wanted as well as water punched whatever i wanted.
__________________
Nadeshiko: *Undergoing Rebuild*
Haruhi: i7 975 12GB DDR3 eVGA Classified *Haruhi -> Nadeshiko*
Lind: Dual Gainestown 3.07
09-28-2009, 10:41 AM
#12
i use my hole saw but those knockout punches lok nice if i were rich id have one!
__________________
MAXIMUS RAMPAGE SE::::E8400 E0(1.25V VID)@4500MHZ::::2XHD4870512MB::::8GB CRUCIAL DDR2 800MHZ::::WATERCOOLED::::ULTRA 1KW 12V SINGLE RAIL PSU::::WIN7 X64
http://ocguru.webs.com/
09-28-2009, 05:14 PM
#13
Obsessed Member
NaeKuh
I dont think it sounds mean, thats why I said in my original post, and I quote
"If you happen to be an Electrician/Modder like me, or know one. You can use a 4" knockout punch to make 120mm holes for fans."
That being said, you can get the cutter and die for under $100 on Ebay, and you don't need the pneumatic pump and draw stud, they make a simple draw stud you can turn with a wrench.
I still use a dremil for lots of things, but those two 120mm holes I cut took less than 5 mins and required no filing ; )
__________________
wEeViL
09-28-2009, 05:51 PM
#14
bah, just showing off
very nice, but not for the general public.
__________________
CPU: Core2Quad q6600 G0 3.5GHz@1.4v (highest so far 4.2GHz)
GPU: XFX 9800GTX @ 850/1230
Ram: Samsung 4GB (4x1GB) 700MHz PC5300
Mobo: EVGA-NF68-A1 680i (P32)
PSU: Enermax Galaxy 850Watt DxX
HDD: WD500 1AALS, ST3250 410AS, ST3500 410AS, ST3500 320AS - 1.75TB
DVD: LG H26N,LG GH20LS10 both sata
LCD: Samsung 32" LN32A450, Samsung 226BW 22" wide
Sound: Logtiech Z 5500/Razor Barracuda HP-1 / AC-1
CPU & GPU: 3x Swiftech MCR320, 2x MCP655, MCW60 R2, Dtek Fuzion V2, 18 high speed yates @ 5v
3Dmark06: 17,814 AquaMark: 190,865
09-28-2009, 06:28 PM
#15
Naekuh, is that a cm690?
09-28-2009, 07:15 PM
#16
Weevil
oh .... then i apologize...
I was wondering why someone was asking people to try out 600 dollar hole punches...
Boogerlad
yup... i think i was the second one on this forum to watercool it 100% internally.
__________________
09-29-2009, 12:11 PM
#17
build log please?
09-29-2009, 02:24 PM
#18
Boogerlad
build log please?
http://www.xtremesystems.org/forums/...42#post2649542
__________________
Thread Tools
Display Modes
Rate This Thread
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
