XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 09-27-2009, 12:16 PM   #1
LS3_Airdale
LS3_Airdale's Avatar
Sunbeam Core Contact Freezer Vibrations
Hello, i just build a new rig, and im getting worried, i changed the sunbeam fan with a Scythe 110cfm fan that i used with a TRUE few years ago, well i lost 5C with it that makes me happy but it vibrate a bit at 1500rpm and still more at 1900rpm thats the max. if it vibrates a bit is that bad for the system ? and since the fan was under a lot of crap for at least a year maybe it damaged it ? tomorrow im receiving a new fan (the same one but brand new) i'll change it and then i'll post if it change something, anyway if it vibrates a bit is it bad for the system ?
Thanks in advance
__________________
CPU: AMD Phenom 2 X4 955 BE @ 3.62Ghz 1.344vcore
HSF: TRUE/Scythe Slipstream fan (110cfm) (41C load)
MB: Gigabyte GA-MA790FXT-UD5P
Ram: 2 x 2GB Patriot G 7-7-7-20-2T @1333mhz 1.7v
HDD: WD 620GB
PSU: Corsair HX 750w
OS: 7 Ultimate x64
GFX: Sapphire HD4850 1GB
LCD: LG Flatron 22" W2261V 1920x1080
Case : Gigabyte iSolo 3134/2 Scythe S-Flex fan
LS3_Airdale is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
