I'd need to get a 3-pin to 2-pin adapter so I could plug it into the card. Not sure if the additon of LEDs on the fan would draw too much power /current from the card's fan power header.
if u think that the zalman sinks are loud then i would suggest not getting another one. look at something like a trad and just drop a 120mm 1200-1500rpm fan on it and plug it into the psu.
any small fan will need a good 2500-3000 rpm and that should be alot more noisy than a low-mid 120mm
__________________
warning i use sarcasm, alot
coming soon duel dual rad p180 the reckoning, 720BE 0912epmw, gd70 and a new liquid revamp
give a man some juice and he has juice for a day, give him a juicer and he will have juice for life if he has something to juice
Check the fan speed and the GPU temperature, I'm guessing that the video card is just letting the fan speed faster than it needs to, you should be able to correct that with RivaTuner.
