Can u pls tell me where can i find a brand new PA120.3, but with the original spacing not the newer 15mm one.
It seems like they disappeared...
__________________
Asus Maximus II Formula
Intel Core2 Duo E8400 E0 Q828A Malay @ 4.50GHz (8.5 X 530mhz) WC'ed
2 x 2GB Mushkin XP2-8500 @ 1060MHz (5-5-5-15)
Asus 4870X2 @ 850/950MHz WC'ed
150gb Western Digital Velociraptor | 2 x 320gb Western Digital Caviar SE16 sataII
SoundBlaster Audigy4 | Logitech Z-5500 | LG W2600HP 26" TFT
MountainMods UFO | Zalman ZM-850HP psu
Watercooling setup:
1st loop -> Radiator: ThermoChill PA 120.3 | Pump: Laing DDC Ultra with Alphacool top | CPU: Swiftech Apogee GTX CU |Chipset: Swiftech MCW-NBMAX | Tubing: PrimoFlex 1/2" Pro LRT
2nd loop -> Radiator: Swiftech MCR-220 | Pump: Laing DDC Pro with Alphacool top |GPU: EK FC-4870X2| Tubing: PrimoFlex 1/2" Pro LRT
The thing is that i can't find any. That's why i wanted your help...
__________________
Watercooling setup:
Parallel Loop using EK MultiLink Reservoir CPU Loop: Heatkiller 3.0 CU (Nickel plated) - Feser 360 (S-Flex G) - MCP350 + EK Plexi Top - EK Reservoir
NB/SB + GPU Loop: EK 280 Nickel Plexi - Bitspower 780i Fullcover - Feser 240 (S-Flex G) - MCP355 + EK Plexi top
I've already contacted MM and waiting for their answer. The new spacing really sucks for us old MM owners...
If anyone else has a suggestion pls let me know...
__________________
Watercooling setup:
You could try contacting the manufacturer directly?
Sadly, we've cleared out all old stock, you're best bet is to just e-mail round all the distributors too see if any of them have the older version kicking about.
That's what i've started doing. Hope i'll find one...
Thanks for the help. If i find anything i'll post it.
__________________
Watercooling setup:
__________________
Watercooling setup:
