XtremeSystems Forums
Reply
Old 09-26-2009, 10:00 AM   #1
Jonni Nitro
My Temps are officially not good. UPDATE!
After all that work I finally get my loop running and I am disappointed by my temps. In fact, there must be something wrong. I am not sure if I have just over loaded my loop or if I mount my block wrong. I followed the intructions and everything seems right.
I am idling around 38-40C with ambient of about 75-78F. Also, my gpus are idling at 3-4C lowering then my cpu. I am afraid to tighten down the cpu block more. When loaded temp jump up about 10-12C
My loop specs and order:
Res
655
2xMCR320s stacked with S Flex 75CFM fans and spacers
HeatKiller 3.0 LT
MCW30
MCW60
MCW60
Res
I know there is a lot in this loop, but i really didnt think my temps were going to be this bad. Is it really just too much heat for these rads?
__________________
Main Rig:
Custom A+ Black Pearl
Seasonic M12 700W
Asus Rampage Formula Bios 0701
Q6600@3.7
4x2gb Patriot Extreme Performance
2xSapphire 4870 1gb
2X500gb Mator Raid 0
Watercooling:
HeatKiller 3.0 LT
MCW30
2xMCW60
2xMCR320 stacked w/6 75cfm fans push/pull
MCP655
BP Matte Black 1/2OD fittings
Jonni Nitro is offline   Reply With Quote
Old 09-26-2009, 10:09 AM   #2
Bojamijams
Bojamijams's Avatar
Your CPU temps just to 52C at its highest on load and thats not good to you?
There's only so much you can get from a 3x120mm with 4 blocks on the loop including two GPU's known to be hot. Your temps are quite fine.
__________________
Computer:i7 920 @ 4.0Ghz Turbo ON| X58 Classified @ 200 QPI | OCZ Platinum 6gb @ DDR3-1600 6-7-6-16 1T | D-Tek v2 CPU and Koolance 5850 FC Block| D5 pump w/ EK Top| HWLabs 480 GTX | Silverstone TJ07-BW|
Video: XFX 5850 @ 1025/1200 | Samsung T260 |
Audio: Asus Xonar Essence STX => Audioengine A5
Portable Audio: iPhone 3GS => JH|13 Pro
Bojamijams is offline   Reply With Quote
Old 09-26-2009, 10:26 AM   #3
millertime359
Xtreme Mentor
millertime359's Avatar
What are you using to get load temps? I don't see anything wrong with your temps either, especially with ambient hitting near 80.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 09-26-2009, 10:38 AM   #4
malkiewicz
malkiewicz's Avatar
Yeah... the 6600 can handle higher temps easily (I would consider it a workhorse)... For some reason your build should have lower temps because my ambient temps hit 80+ and I was able to keep it well under 55C with 1 360 radiator...
__________________
BenQ FP241W Black 24" LCD
Lain-Li PC v1200 Plus II Case w/ Window
EVGA x58 Classified Bios 000
i7-920 @ 4.2GHz - 1.352v Temps (23C-54C)
Windows 7 64 Bit
6GB Muskin DDR3 2000 (PC3 16000) @ 8-8-7-24 1T - 1.65v
EVGA 8800 Ultra x2 "OC" w/ Danger Den Water Block Temps (35C-54C)
EK-Supreme / 2 Alphacool Laing DDC-Pump Ultras + Extras
Power Supply / Crosair 1000HX
Seagate ST3500631NS 500GB x 3
Crosair SSD 128GB x 2
malkiewicz is offline   Reply With Quote
Old 09-26-2009, 10:41 AM   #5
Jonni Nitro
I used Intel Burn Test. I know that Prime95 is better, but I am just doing testing right now. I was really thinking my temps are horrible, but maybe not. What can I use to load the gfx cards? I ran 3DMark Vantage and my gfx cards never went over 45C.
__________________
Main Rig:
Seasonic M12 700W
Q6600@3.7
2xSapphire 4870 1gb
Watercooling:
HeatKiller 3.0 LT
MCW30
2xMCW60
MCP655
Old 09-26-2009, 10:53 AM   #6
millertime359
Xtreme Mentor
I thought F@H puts some stress on the GPU.
Your temps are plenty fine then. I wouldn't worry about it.
__________________
Old 09-26-2009, 10:55 AM   #7
faster3200
faster3200's Avatar
This (these?).
Your temps seem fine and what you state seems perfectly normal. The only thing that jumps out at me are the stacked rads with that fan combo. Stacked rads really need strong fans to be effective and those are quite weak. If you really want to improve temps I would start there and give us a breakdown of how many you are using.
You can't cross compare temps like that. There are too many variables to call a comparison of setups accurate.
EDIT: For GPU temps try Furmark or OCCT GPU test.
__________________
"Everything is amazing and nobody is happy".
- Louis CK
faster3200 is offline   Reply With Quote
Old 09-26-2009, 11:01 AM   #8
malkiewicz
malkiewicz's Avatar
faster3200... Your right.... Sorry... If I'm going to compare I need to be more specific / detailed.... I was just trying indicate that his temps are okay but it's possible to get lower temps ...
__________________
Windows 7 64 Bit
Old 09-26-2009, 11:04 AM   #9
eponymous
eponymous's Avatar
Hehe, when the fan failed on my 6600, the temp rose to around 140 degrees for about 5 minutes (with a nice burning smell). I attached a new fan and it's still going strong :P
__________________
[Project] : Altair | A Lian-Li PC-P80, dual loop, all internal build.
Hardware
Core i7 920 D0 | Corsair Dominator 1600MHz CL8 RAM | 2x EVGA GTX 285 SLI | ASUS P6T Deluxe V2 | ASUS Xonar D2X
2x Intel X-25M SSD | WD RE3 1TB (WD1002FBYS) | Corsair HX-1000W | Lian-Li PC-P80 | Dell 3008WFP 30"
Watercooling Gear (Dual Loop)
Koolance 350AT (CPU Loop) | 2x Koolance VID-NX285 (GPU Loop) | 2x Laing DDC 3.2 / XSPC Acrylic top Rev. 3 | 2x EK Multioption 150 Res Ver. 2 | 2x Thermochill PA 120.3 |
6x Scythe S-Flex 1200 RPM Fans | 7/16" Primochill Pro Green LRT | 7/16" Primochill Pro Blue LRT | B.P. Silver Shiny 1\2" Barbs | Alphacool Ball Valve / B.P. M-M Rotary fill-port / drain | Bitspower Black Freezer AIX58NS NB/SB (GPU Loop)| Black Freezer MOS AMOSII POM Version (GPU Loop)| Bitspower Black Freezer MOS AMOSIII POM Version (GPU Loop)
eponymous is offline   Reply With Quote
Old 09-26-2009, 11:07 AM   #10
NaeKuh
Post Soapbox Destruction
NaeKuh's Avatar
Do you honestly think your gpu's and cpu should idle at the same temp?
do you know how water works?
The coolant temp is considered your floor. We call that ground Zero.
From ground zero, the only way your other blocks can read ground zero, is when there OFF.
When there on, its like you lighting a little match. How bright the fire is, depends on how much power your component draws.
So no there is aboslutely nothing wrong with the specs you gave us.
Your just trying to compare your temps with someone else on the forum who probably has a lower ambient then you do.
Or has a much more expensive system then you do.
__________________
Nadeshiko: *Undergoing Rebuild*
Haruhi: i7 975 12GB DDR3 eVGA Classified *Haruhi -> Nadeshiko*
Lind: Dual Gainestown 3.07
NaeKuh is offline   Reply With Quote
Old 09-26-2009, 11:16 AM   #11
malkiewicz
malkiewicz's Avatar
Yeah... I cooked one of my Q6600's & 8800's before when my pump failed... The liquid in my CPU block actually started to boil.... I sold it to my friend last year and it's still running strong.... That's why I run dual pumps now...
__________________
Windows 7 64 Bit
Old 09-26-2009, 12:45 PM   #12
BrokenArrow
BrokenArrow's Avatar
Did you use a backplate for the CPU block? If not, the bending of the mobo may lead to poor contact.
BrokenArrow is offline   Reply With Quote
Old 09-26-2009, 12:55 PM   #13
NaeKuh
NaeKuh's Avatar
*sigh*
there is no poor contact.
first off his ambient is around 25-28C check..
So if i use math i can assume his coolant levels are roughly around 30-35C. Now lets Check by assumption and see if his deltas are alright...
So his CPU is idling 38-40C... which means he has a delta of 8 as his low. That sounds okey...
Now his GPU is idling at 34-35 which has a delta of 4 low...
That sounds okey again...
Why? cuz his gpu is drawing less power then his cpu is, and therefore his cpu is hotter.
So whats wrong with his system again?
Oh his only problem is he didnt pay enough and split his loops up with more radiators or he didnt put his rads in front of an AC.
But i dont think that would fit in his budget or objective.
__________________
Old 09-26-2009, 01:15 PM   #14
Spawn-Inc
Spawn-Inc's Avatar
either un stack those rads, or get 9 fans going for better temps and performance.
__________________
CPU: Core2Quad q6600 G0 3.5GHz@1.4v (highest so far 4.2GHz)
GPU: XFX 9800GTX @ 850/1230
Ram: Samsung 4GB (4x1GB) 700MHz PC5300
Mobo: EVGA-NF68-A1 680i (P32)
PSU: Enermax Galaxy 850Watt DxX
HDD:WD5001AALS, ST3250410AS, ST3500410AS, ST3500320AS - 1.75TB
DVD: LG H26N,LG GH20LS10 both sata
LCD: Samsung 32" LN32A450, Samsung 226BW 22" wide
Sound: Logtiech Z 5500/Razor Barracuda HP-1 / AC-1
CPU & GPU: 3x Swiftech MCR320, 2x MCP655, MCW60 R2, Dtek Fuzion V2, 18 high speed yates @ 5v
3Dmark06:17,814 AquaMark:190,865
Spawn-Inc is offline   Reply With Quote
Old 09-26-2009, 01:36 PM   #15
Zigosity
Zigosity's Avatar
Those temps look fine to me. O_o. My rig at 3.6 right now is getting like 64-65 under load and idles at ~40-43... Not to mention you've piled a whole bunch of stuff into one loop, which is going to give you less than ideal performance.
-Zigosity
__________________
Asus P5Q3 Dlx || Q9450 @ 3.6GHz || OCz DDR3 ReaperX 2x2Gb 1333 6-5-5-20
2x Sapphire HD4850 CrossfireX || WD VelociRaptor 300GB || Antec Quattro 1kW PSU
Cooling:
D-Tek FuZion v2 || Swiftech MCR320 || MCP355 w\ XSPC Res Top || Scythe S-Flexes || Indigo Xtreme TIM (Amazing stuff, this...)
Zigosity is offline   Reply With Quote
Old 09-26-2009, 01:40 PM   #16
BrokenArrow
Originally Posted by NaeKuh View Post
*sigh*
I was trying to help. Please do not try to look down your nose at me with a comment like *sigh*.
Old 09-26-2009, 01:59 PM   #17
Jonni Nitro
Thanks for the comments guys. I will agree that these fans are probably to weak and I could have either split the loop or add a 3rd rad before the gpus. Next time I break downt he loop I am going to change my fans for sure and probably add another set. I was trying not to overload my fan controller, but then I ended up with one channel free. I might consider a push/pull with a shroud in between next time.
I am using a backplate, btw.
My rads. The bottom fans are the actual fans. Top ones are gutted for shrouds. I should have cut the bottom of the case and got taller feet for better intake. Live and learn.
__________________
Main Rig:
Seasonic M12 700W
Q6600@3.7
2xSapphire 4870 1gb
Watercooling:
HeatKiller 3.0 LT
MCW30
2xMCW60
MCP655
Old 09-26-2009, 02:25 PM   #18
millertime359
Xtreme Mentor
You can always go and get some sticks of wood and use them to jack the case up. It won't be pretty, but will get you by till you get the time to tear down again.
__________________
Old 09-26-2009, 05:48 PM   #19
Edward88
If you want to improve your temps use more fans! you have only 3 of them
I would do something like fan|rad1|fan|rad2|fan
Edward88 is offline   Reply With Quote
Old 09-26-2009, 06:19 PM   #20
NaeKuh
NaeKuh's Avatar
Dont take it personally...
i tend to sigh a lot.
There isnt anything wrong with his system.
And im trying to save the op from tinkering with it b4 he does break something.
we wont really know if that will fix his wants either, without a coolant test.
For all we know it could generate too much noise and the OP might not want that.
__________________
Old 09-26-2009, 09:23 PM   #21
Jonni Nitro
Noise is a concern, but I still have two open channels on my fan controller. I dont mind noise I just want to control it if my pc is just sitting there.
Do my fans just not move enough air or is it also velocity? What would have been some good fans to run? I have thought about adding another set of fans to the top of my rads, it easy to get to and wouldnt take much to make it work.
__________________
Main Rig:
Seasonic M12 700W
Q6600@3.7
2xSapphire 4870 1gb
Watercooling:
HeatKiller 3.0 LT
MCW30
2xMCW60
MCP655
Old 09-26-2009, 10:25 PM   #22
NaeKuh
NaeKuh's Avatar
First off we need to do a coolant test to see what is your true delta.
A Coolant test means u take your water temperature and compare it to the air temperature thats coming into your rads.
This delta represents what i said was called ground zero. There are many ways to do this if you dont have a inline probe.
If your rad capacity is indeed limited then...
The problem is in your stack.
Unless you can get enough air to your second rad, you will starve it off 2 MCR320's.
There are 3 ways to fix this.
1. You can put another set of fans ontop of your rad like the person recomended, and do whats called a push/pull on the top rad.
This would indeed give you some benifits, but could double your noise.
2. Get a thicker set of fans in the middle. Which means more powerful fans, and that will also lead to increased noise.
I have a simular stack with San Aces on Shrouds...
3. Add another layer of fan on the bottom and then again on the top (exactly what the person recommended).
So you would have a total of 9 fans.
This will allow you to "cheat" static, and hence you could downvolt them all to a comfortable level, maybe...
Well 9 fans is a lot of noise, i dont know if there is a comfortable level.
But you would have one thick stack.
__________________
Old 09-26-2009, 10:52 PM   #23
skinnee
Addicted to Pie!
skinnee's Avatar
Naekuh, you cannot post any more photos until you sign up and complete an amateur photography class at the local Community College. Oh yeah, and buy a can of compressed air already.
__________________
skinnee labs test schedule:
In Testing: Too much to list.
Writing Reviews: finally getting my backlog cleaned up too.
Planned Tests: Plan, what the heck is a plan.
skinnee is offline   Reply With Quote
Old 09-26-2009, 10:54 PM   #24
Jonni Nitro
This is sorta of a dumb question, but all my fans should match correct? If I went with a higher cfm fan on top my rads now I am sure it would have a wierd effect on the other fans.
__________________
Main Rig:
Seasonic M12 700W
Q6600@3.7
2xSapphire 4870 1gb
Watercooling:
HeatKiller 3.0 LT
MCW30
2xMCW60
MCP655
Old 09-27-2009, 02:01 AM   #25
zeropluszero
zeropluszero's Avatar
Send a message via MSN to zeropluszero
i would think that you would. i wouldnt go push/pull with different rated fans.
__________________
Cosmos S - Q9550 E0 - EVGA 780i FTW - 4GB Dominator 8500 - SLI GTX280 - 150GB Velociraptor - Enermax 85+ 1050W
Parallel Loop using EK MultiLink Reservoir
CPU Loop: Heatkiller 3.0 CU (Nickel plated) - Feser 360 (S-Flex G) - MCP350 + EK Plexi Top - EK Reservoir
NB/SB + GPU Loop: EK 280 Nickel Plexi - Bitspower 780i Fullcover - Feser 240 (S-Flex G) - MCP355 + EK Plexi top
zeropluszero is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
