XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 09-25-2009, 05:34 PM   #1
HexiumVII
IFX14 or Cogage True Spirit
I’m building a new i7 system with a 920 and P6T that supports 775 heatsinks. I have a friend moving out of town and he is giving me the choice of either an older IFX14 or a cogage true spirit. The cogage stock fan seems to be pretty good as shown on Hardreviews. I currently have a few Yate Loon D12SM-12 fans to pair with the IFX, will these provide enough airflow? I’m using the upside down Lian Li V1000 case so I will probably need to mount the IFX vertically as it won’t get airflow from the bottom if I mount it in the optimal horizontal way. What do you guys think would be the best option? Thanks for any advice!
HexiumVII is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
