XtremeSystems Forums
Reply
Old 09-25-2009, 04:10 PM   #1
xREDMAN
removing puny screws
from gtx 295
i need a screwdriver and i don't know which one to get
__________________
Red Addiction:
EVGA P55 FTW
i5 750 @ 4ghz
4GB CORSAIR XMS3 ddr3 1600mhz
HD5850 stock
300gb VelociRaptor
1tb WD Caviar Green
Topower 900w
xREDMAN is offline   Reply With Quote
Old 09-25-2009, 04:43 PM   #2
millertime359
Xtreme Mentor
millertime359's Avatar
just go to a Home Depot or Lowes. They have everything you could ever want for tools.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 09-25-2009, 04:58 PM   #3
faster3200
faster3200's Avatar
Buy a good precision screwdriver set. You won't regret it
__________________
"Everything is amazing and nobody is happy".
- Louis CK
faster3200 is offline   Reply With Quote
Old 09-25-2009, 06:08 PM   #4
Caoder
Caoder's Avatar
Send a message via MSN to Caoder
my fav tool ever my precision screw driver set
__________________
Core i7 920 D0 @ 4.2 | 2 x GTX 260 | EVGA x58 SLI | 3 x 2 gb GSKILL Perfect Storm 17066CL9|
CPU under WC/ gtz + 2x mcr220
Caoder is offline   Reply With Quote
Old 09-25-2009, 06:43 PM   #5
Spawn-Inc
Spawn-Inc's Avatar
get one that works
jewelers screwdrivers work great for those small screws on cards.
__________________
CPU: Core2Quad q6600 G0 3.5GHz@1.4v (highest so far 4.2GHz)
GPU: XFX 9800GTX @ 850/1230
Ram: Samsung 4GB (4x1GB) 700MHz PC5300
Mobo: EVGA-NF68-A1 680i (P32)
PSU: Enermax Galaxy 850Watt DxX
HDD:WD5001AALS, ST3250410AS, ST3500410AS, ST3500320AS - 1.75TB
DVD: LG H26N,LG GH20LS10 both sata
LCD: Samsung 32" LN32A450, Samsung 226BW 22" wide
Sound: Logtiech Z 5500/Razor Barracuda HP-1 / AC-1
CPU & GPU: 3x Swiftech MCR320, 2x MCP655, MCW60 R2, Dtek Fuzion V2, 18 high speed yates @ 5v
3Dmark06:17,814 AquaMark:190,865
Spawn-Inc is offline   Reply With Quote
Old 09-26-2009, 02:14 AM   #6
cx-ray
V
You need a phillips drive size 00. Get one of high quality. Often people blame lousy screws for stripping, but most of the time it's the quality of the drive that causes it. A good tool will maintain proper form under torque and grip without marring. Something by PB, Wera, or Wiha in the $6-8 range for that size should be fine (sorry don't know good US brands).
cx-ray is offline   Reply With Quote
Old 09-27-2009, 03:43 PM   #7
eth0s
eth0s's Avatar
This is good advice: never cheap out when buying tools.
OR just Smash the puny screws! (any Hulk fans out there?)
eth0s is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
