XtremeSystems Forums
Reply
Old 09-25-2009, 12:55 PM   #1
Delemon
Question New to WC, about to place some orders
I finally decided to jump on the i7 920 bandwagon and have a list I'd like a second, third, etc set of eyes to make sure I haven't yet missed anything. I already have a D5 vario, i7 920 D0, and an EVGA X58 Classified. Case will be a MM Pinnacle 24 CYO.
Res: EK-Multioption RES 250 rev.2
Pump: D5 Vario w/ EK-D5 X Top
CPU: Heatkiller 3.0 LT
SB/NB: EK-FB EVGA Classified Full Board block
RAD: Swiftech MCR320-QP
Fittings: Bitspower G1/4 Matte Black 1/2in ID barb (x8)
Tubing: PrimoFlex Pro LRT Black Tube
Coolant: Distilled H20 w/ Silver Killcoil
TIM: Indigo Extreme
I think I have enough fittings (2x for CPU, board, pump, and res) though I might have missed something. Figured I could run a fill port to the top of that res so I might need a fill port cap or something.
Going with a single loop, CPU and board only. Going to wait on cooling the GPU for now, though I might go that route in another few months after the next round of ATI and nVidia cards are released. Going fully internal, as this case is huge enough without mounting rads on the outside.
Any glaring omissions or things I might want to consider?
__________________
In Progress:
EVGA X58 Classified w/EK-FB full board block | Core i7 920 w/ Enzotech Sapphire | 6GB Gskill Trident F3-16000CL9T-6GBTD | ATI Radeon 4870 1GB | Hitachi 320GB HD x2 | Hitachi 1TB HD x2 | PCP&C Silencer 750W PSU | D5 Vario w/EK-D5 v2 | MCR320-QP w/cheap Yates (for now)
Delemon is offline   Reply With Quote
Old 09-25-2009, 01:06 PM   #2
faster3200
faster3200's Avatar
Fans? Otherwise, it looks good.
__________________
"Everything is amazing and nobody is happy".
- Louis CK
faster3200 is online now   Reply With Quote
Old 09-25-2009, 01:25 PM   #3
Delemon
Fans: Cheap Yates until the higher speed Gentle Typhoons are available. Will probably get a fan controller to fine tune when I'm gaming vs when I'm sleeping.
__________________
In Progress:
Old 09-25-2009, 01:34 PM   #4
millertime359
Xtreme Mentor
millertime359's Avatar
Everything looks great. It seems you did some research.
The only thought I can add is looking into a Typhoon III for when you add your GPUs.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 09-30-2009, 10:22 AM   #5
Delemon
Quick question on the res... do I need to get caps/stoppers/plugs for the unused ports? I live hours from any place that might even consider carrying something like this, and as I'm a total n00b to WC, I'd hate to get my stuff ordered and then have to sit and wait because I missed something on the res.
__________________
In Progress:
Old 09-30-2009, 10:58 AM   #6
shazza
Xtreme Fan
shazza's Avatar
Good job!
Not 100% sure if the res comes with stop plugs (I believe my EK multi-res did, but that was some time ago). Never hurts to order a couple just in case. They can be handy for other things occasionally. They are readily available at the on-line stores.
The one thing you may want to consider is how you are going to drain the loop. There are lots of options for setting up a drain line - you don't need to be overly concerned about this right now - but good to give it some thought.
__________________
MM#2 : EVGA X58 | i7 920 | Vista 64-bit | Liquid Cooling | Corsair HX1000W PSU | EVGA GTX 285 Tri-SLI | 3x2GB Corsair 12800| WD 750GB | Mountain Mods UFO-CYO
i7 920 on Air : P6T Deluxe | i7 920 | Noctua NH-U12P SE1366 HSF | Vista 64-bit | Corsair HX1000W PSU | GTX 260 (55nm) x 2 | 3x2GB G-Skill PC3 12800| WD 750GB | Maxtor 500GB | Lian Li PC-A20
shazza is online now   Reply With Quote
Old 09-30-2009, 11:10 AM   #7
millertime359
Xtreme Mentor
It's not a bad idea to order extra parts then. Ordering a couple extra 90s and 45s is also not a bad idea. I found when I first set my loop up, I found I was missing one fitting that I didn't realize I needed. It will add some extra money, but it can be a life saver having extra fittings on hand.
__________________
Old 09-30-2009, 11:19 AM   #8
Delemon
I think I'll add a Bitspower G1/4 Temp sensor stop fitting, and a couple of the black stop fittings as well.
Are there any matte black 45 and 90-degree fittings anywhere? I've only found the straight ones.
EDIT: I may go for the shining silver, as I'd prefer them to all match if possible.
__________________
In Progress:
Old 09-30-2009, 11:19 AM   #9
liguhy
liguhy's Avatar
what's the case that this is all going in?
Depending on that answer, a Typhoon III would be perfect since you're going D5 anyway - you wouldn't need the EK top as well with that route. The Typhoon III rocks for putting everything on one loop. It mounts into two 5.25 bays or can be mounted elsewhere with a bit of modding.
As for fittings: get some clamps of some sort if you're sticking with 1/2" ID (inner diamater) on 1/2" fittings. Also, most people have needed some kind of elbow fitting for connecting the CPU and mosfet/nb loop. I've seen the hardcore 90s work, but BP rotary 90s or 45s (best option) will eliminate kinks. Be sure to let your CPU get the water first.
Other than sorting out the fitting specifics and posting some pics/description of your case, it seems good to go.
EDIT: noticed you mentined your case after I posted. MM case - in other words no space problems. I'd go for the Typhoon then
__________________
__________________________________________________
Last edited by liguhy; Today at 1/2 second ago. Reason: You can always edit your writing more...and I'm anal-retentive.
Last edited by liguhy; 09-30-2009 at 11:43 AM. Reason: oops. missed what case you're using.
liguhy is offline   Reply With Quote
Old 09-30-2009, 11:46 AM   #10
Delemon
I'll be picking up one of the Black Pearl cases from Newegg until Mick64 can get his custom case built, or until I get off my arse and build a one-off myself, heh. Less expensive than the MM Pinnacle, and I have experience with Lian-Li cases as I have a V1000B already. Love the quality and can't beat the price on the Black Pearl.
I was going to go the 7/16ID tubing over 1/2" barbs.
EDIT: modified case choice
__________________
In Progress:
Old 09-30-2009, 11:54 AM   #11
Gimmpy224
Gimmpy224's Avatar
Send a message via AIM to Gimmpy224
I think for that price I would go with one of the MM cube cases.
But that's just this guys opinion ^_^.
From what I've seen they are a little easier to work with and extremely spacious.
Again, just an opinion.
Other than that you've got a great setup.
__________________
Originally Posted by freecableguy
I'll come blow on your heatsink for a dollar. Thats pretty ghetto
Originally Posted by Xeon th MG Pony
sorry to sound harsh but so would you if some one asked if nitroglycerin was a good coolant for his car!
Gimmpy224 is offline   Reply With Quote
Old 09-30-2009, 11:55 AM   #12
shazza
Xtreme Fan
shazza's Avatar
Wellllll ... if you're going Black Pearl, you MUST do a work log It seems a bunch of us have Black Pearl build logs going at the moment, and I need some more inspiration 'cause I'm procrastinating a bit.
I think the matte black BP fittings are only available in the barbs and maybe a couple other miscellaneous ones - for continuity, you're best going with the silver as more options seem to be available. I like the Black Sparkle too, but they can be hard to get a hold of.
__________________
Old 09-30-2009, 12:20 PM   #13
Delemon
I'll definitely post a worklog. There are some things I'd change before my components ever saw the insides, heh.
I am seriously considering trying to fabricate that custom design that Mick64 has. Going though trying to sell my house and buy another, so I'll likely be waiting on that fab though.
__________________
In Progress:
Old 10-05-2009, 09:53 PM   #14
Delemon
Ok, have everything ordered... even down to fans and TIM... and every place sold out of the freakin' Heatkiller 3.0 LT. I have a *BACKPLATE* coming, but no Heatkiller
Wonder how long I'm gonna have to wait.
__________________
In Progress:
Old 10-06-2009, 06:31 AM   #15
millertime359
Xtreme Mentor
They out of stock again?
Might be a while, send an e-mail to Gary and ask.
__________________
Old 10-06-2009, 07:11 AM   #16
Delemon
Already sent the email =) He responded pretty quickly when I asked about the EK-FB Classified block when it was OOS.
Even PPC is out of the LT.
__________________
In Progress:
Old 10-06-2009, 07:17 AM   #17
millertime359
Xtreme Mentor
I think their shop is pretty small. They are also overseas and sounds like customs tends to like to hold the shipments on the way over.
__________________
Old 10-06-2009, 07:41 AM   #18
Delemon
I stand corrected! Gary emailed me back right quickly last night! I hadn't expected anything until today at the earliest. Kudos big time for customer support.
Unfortunately, he did confirm being out of the LT, with an ETA of "a couple weeks at least on that block" (Heatkiller 3.0 LT 1366). Perhaps I'll grab an Enzotech Sapphire while I wait.
__________________
In Progress:
Old 10-06-2009, 07:49 AM   #19
millertime359
Xtreme Mentor
There's nothing wrong with that Sapphire.
__________________
Old 10-06-2009, 07:55 AM   #20
Delemon
If I'm correct, I need to purchase one of these Enzotech Type-Z 1366 Retention Module to go with one of these Enzotech SCW-REV.A CPU Waterblock, right?
__________________
In Progress:
Old 10-06-2009, 08:04 AM   #21
millertime359
Xtreme Mentor
Just checked PPC, and they saw it comes standard with socket 775 and AM2 mounting hardware. 1366 requires Z bracket. So looks likes yes you do need that bracket.
__________________
Old 10-06-2009, 08:13 AM   #22
Delemon
Ordered! I wanna get this rig up and running!
__________________
In Progress:
Old 10-16-2009, 11:44 AM   #23
Delemon
Originally Posted by From UPS Tracking
Package Process from Sidewinder
Activity
Oct 16, 2009 06:42 AM UKIAH, CA, US OUT FOR DELIVERY
WOOT! I'm ready to finally (horrible pun coming) get my feet wet, so to speak, with this WC stuff!
__________________
In Progress:
Old 10-16-2009, 12:51 PM   #24
punkrockpolak
Wow, took 10 days to ship? Hope to see some pics when you're done
punkrockpolak is offline   Reply With Quote
Old 10-16-2009, 01:54 PM   #25
Delemon
There was one piece that they were missing (dealing with the move still I think), so that delayed it a bit. Gary emailed me though and let me know. Top notch customer support!
__________________
In Progress:
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
