XtremeSystems Forums
Reply
Old 09-25-2009, 12:10 PM   #1
Barso
What loop would be best?
I have purchased a block for the chipset of my classified and already have a heatkiller 3.0 on the cpu.
I currently have: RES-CPU-RAD-RES but would I be better with in the new setup:
RES-RAD-CPU-CHIPSET-RES or RES-CPU-CHIPSET-RAD-RES ?
Thanks for all help and replies.
Barso is offline   Reply With Quote
Old 09-25-2009, 12:14 PM   #2
Caoder
Caoder's Avatar
Send a message via MSN to Caoder
doesn't matter.. whatever looks best
__________________
Core i7 920 D0 @ 4.2 | 2 x GTX 260 | EVGA x58 SLI | 3 x 2 gb GSKILL Perfect Storm 17066CL9|
CPU under WC/ gtz + 2x mcr220
Caoder is offline   Reply With Quote
Old 09-25-2009, 12:16 PM   #3
cky2k6
cky2k6's Avatar
I'm assuming your res is a res/pump combo? its always better to have the rad immediately before the cpu, not a huge difference, but no reason not to unless its easier with the tubing.
__________________
Core i7 920 3849B028 4.4ghz cooled by gtz | 12gb gskill ddr3 1600 | Sapphire HD4870x2 cf cooled by xspc fc | Asus Rampage II Extreme | 600gb Velociraptor Raid 0 / 1tb + of storage | Modded Rocketfish case + 1200w toughpower | mcp 655 pump + mcr 320 + black ice pro II
cky2k6 is offline   Reply With Quote
Old 09-25-2009, 12:28 PM   #4
millertime359
Xtreme Mentor
millertime359's Avatar
As long as res is before pump, doesn't matter
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is online now   Reply With Quote
Old 09-25-2009, 12:35 PM   #5
Barso
Thanks for the help.
Yes, it is a combo.
I will rad after res then.
I was contemplating swapping my rad around as it sits at the top of my cosmos s in the case and if I swapped it around 180 degrees the inlet/outlet would be closer to the res that is in the drives bays at the front.
Also if the rad leaked at the inlet/outlet it would not drip onto my GPU.
Thanks Miller, you're always here answering my questions.
Thanks to evreryone else too.
Now just to sort the bloody stuttering problem I have with my GTX295.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
