XtremeSystems Forums
Reply
Old 09-25-2009, 09:26 AM   #1
Barso
3/8"ID-5/8"OD 45 degree compression fitting?
I am looking for this type of compression fitting for my heatkiller3.0 as the ordinary compression fittings do not fit.
I am swapping the barbs for compression fittings.
Does anyone know where I can get these?
Thanks.
Barso is online now   Reply With Quote
Old 09-25-2009, 09:31 AM   #2
millertime359
Xtreme Mentor
millertime359's Avatar
here. or comp fitting and 45 degree rotary.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is online now   Reply With Quote
Old 09-27-2009, 01:59 AM   #3
zeropluszero
zeropluszero's Avatar
Send a message via MSN to zeropluszero
thats what i'm running on my heatkiller with the same size tubing.
__________________
Cosmos S - Q9550 E0 - EVGA 780i FTW - 4GB Dominator 8500 - SLI GTX280 - 150GB Velociraptor - Enermax 85+ 1050W
Parallel Loop using EK MultiLink Reservoir
CPU Loop: Heatkiller 3.0 CU (Nickel plated) - Feser 360 (S-Flex G) - MCP350 + EK Plexi Top - EK Reservoir
NB/SB + GPU Loop: EK 280 Nickel Plexi - Bitspower 780i Fullcover - Feser 240 (S-Flex G) - MCP355 + EK Plexi top
zeropluszero is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
